stevekop
804 profile views
stevekop's Achievements
  1. Can anyone tell me where the paint code is located on a 1989 Jeep Comanche
  2. Amazon had the best price on a 23 gallon tank and free shipping
  3. I have a 89 Comanche will the sun visors from a Cherokee fit it
  4. How do I determine what size lug nuts I need. Have a 89 Comanche 4wd. Looking to get a set (20) in black
  5. Cold here in the northeast. Comanche not putting out enough heat, air warm at most. Maybe thermostat? Any Ideas
  6. Have to replace my exhaust on 89 Comanche. Will be replacing all the pipes should I also replace the cat. converter. Far as I can tell there is no problem with it.
  7. Need to drain fuel tank on 89 Comanche. Tried to siphon did not work, any questions,
  8. Tank rusted and has holes
  9. I have a 1989 Jeep Comanche Pioneer p/up with a 7 foot bed. How do I tell what size the tank is and were can I get one.
  10. This headlight relay you guys talk about to improve the lighting. Is this a plug in item, if so were does it plug in or is does it need to be wired in. Headlights on my 89 are terrible.
  11. I have a 1989 Jeep Comanche with a leak in the fuel tank. 1. How do I remove the tank it appears to have a skid plate over it 2. I know that replacement tanks are available, but do they make one out of plastic and should I even consider it. Steve
