Pete M
Administrators
    114
Everything posted by Pete M
  1. rylee beat me to this one, but a lot of our best threads are located in the link in my sig.
  2. that's a reused code. the code is correct for your truck, but the description is for a Renegade I believe.
  3. creative! that'll be a hoot driving down the road
  4. Pete M
    1J7FJ26LXLL274679
    you've got more gumption than I. I could not have sold that beauty. glad you're able to keep it in the family!
  5. make it reliable before you buy a single lift part.
  6. nothing quite like the smoothness that comes from fixing a vibration. it's like a whole new ride!
  7. dang that truck is lookin' goooooooood...
  8. I keep telling guys they don't have to jump right to the welder to fix dents. that's some fine rough body work there.
  9. so when do the car shows start?
  10. straight -up rebuild? or adding some tweaks?
  11. been there, done that. many times with many projects.
  12. should sound fantastic as an alternative idea, I put my tweeters in the doors to keep them closer to the mids.
  13. custom front axle installs tend to make the list
  14. check the Vendors section of the classifieds for Dakota's printed holder for your REM
  15. wow, what a time capsule!
  16. eep! when going around the block is that level of adventure, maybe it's a good day to stay home.
  17. yeah, so I've ducked my head in a couple dozen fords now and they all seem to be missing this part.
  18. it's been sitting for a while and I need it out of the drive so I can bring over the camper to work on it so I fired it up and put it into reverse. got 20 feet before I heard a horrible clunk sound and the engine shut off. fearing the worst I cranked the engine a bit and all sounded normal so I fired it up. sounds fine. out it into reverse again and all was well so I finished reparking it. came back to it later to fire it up and shift back and forth into reverse and drive. perfectly normal, but I didn't move anywhere. pulled codes and came up with P0736 "Gear ratio error in reverse". asking around to other CRD guys it appears this might be an issue with not enough fluid in the TC which caused it to lock up and stall the engine. but it could also be that the computer sensed the issue and shut it off. mildly concerning either way. tomorrow I'll look more into it. ran out of daylight today chopping wood.
  19. I've always wanted a speedo sans Kilos.
  20. the 35 came in 2 flavors of drum size
  21. the possibilities are endless
