May 2022-Project Uncompahgre
May 2022- @USN_JeepMJ's 1989 Project Uncompahgre
Build Thread-
CC: https://comancheclub.com/topic/59991-project-uncompahgre-19891999-mj/
IG: @usn_jeepxj
Year/Model -
1989 Jeep Comanche Pioneer 2x4 (cab shell, bed, tailgate, and a few interior pieces)
1999 Jeep Cherokee Sport 4x4 (fenders, grill, doors, body harness, interior)
1999 Chevrolet Corvette (engine, PCM, drive by wire)
Drivetrain-
5.7L LS1 (60K mile w/ good compression)
Novak LS engine/trans mounts
Holley high-mount accessory drive system
Sanderson/Novak ceramic coated headers
Custom full stainless 2.25-3” exhaust system w/ Borla ProXS muffler and Magnaflow cat
New AX-15 w/ adapter and GM bell housing  from Novak
Rebuilt NP231 (new seals, bearings, chain)
Novak transfer case shift cable
Adam’s Driveshaft rear driveshaft
Rear Currie Dana 60 (JK width / JK flanges) w/ 4.88’s and Auburn E-locker
Front Spicer Dana 44 crate axle (Artec axle brackets) w/ 4.88’s and Eaton E-locker
Cooling-
Novak KryoFlow HD aluminum radiator
Novak fan and shroud assembly
Electrical/Ignition-
Novak modified LS engine harness
Reworked/modified XJ body harness
Suspension/Steering-
Front:
Iranman 4x4 Fab 4-link front long arm
ACOS spacers (set to +2”)
Clayton 4.5” coil springs
Clayton track bar bracket
Custom track bar
ADDCO sway bar
JKS quick disconnect end-links
Fox JK remote reservoir 2.0 shocks (6.5-8”)
Rear:
General Spring 4 leaf replacements (factory rate)
Clayton adjustable shackles (set to +0”)
Steering:
PSC big bore steering box (ported for hydro steer)
Metalcloak JK tie-rod
Metalcloak JK drag link (trimmed to fit the MJ)
Fox steering stabilizer
Interior-
97+ XJ full interior swap (painted in SEM black)
B&M short shifter (modified for trans position)
Twisted ShifterZ stainless steel shift knobs
WJ Grand Cherokee Overland steering wheel
Custom upholstered interior panels and steering wheel
Corbeau Trailcat seats w/ heat
Corbeau seat brackets (shortened)
H3R HalGuard fire extinguisher
Dynamat on all interior surfaces
ACC carpet and floor mats
Jeep JL/JT pedal covers
TJ instrument cluster
ZJ overhead trip computer wired through a ZJ BCM
JCR center console bracket
Double din dash bezel
Alpine W987HD stereo
F+R HD cameras
Kicker 12CX6005 amplifier
Kicker KS 6 1/2 component system
Kicker KS 4x6 rear speakers
Kicker 46HS10 subwoofer
Brakes-
Wilwood JK BBK in Competition Blue (6 piston fronts and 4 piston rears)
Inline Tube stainless hard-lines
XJ parking brake handle w/ JK parking brake lines
Lighting-
JW Speaker LED headlights
JW Speaker TS4000 driving lights
Rigid DOT fog lights (amber)
Rigid diffused lights (rear bumper)
All exterior lights converted to LED
One Way Light interior LED conversion
Exterior-
97+ full facelift (including firewall)
BMW Austin Yellow (B67) paint
Jeep 5.9L ZJ hood vents
Raptor Liner bedliner
Notch Customs fender flares
Custom aluminum inner fenders
Custom expanded sheet metal grill
CRL Duo Vent 4-panel sliding rear window
JCR Crusader front bumper
JCR rear bumper
JCR classic rock rails
JCR spare tire carrier
Pelican BX90 Cargo Case
Powertank 15lbs CO2 tank
HiLift jack
Wheel & Tires-
Mopar JL/JT satin carbon 17x8.5” wheels
BFGoodrich KM3 37x12.5x17
Gorilla lug nuts
Misc-
R4 compressor with modified XJ a/c lines (34° at the vents)
Wilwood master / Novak slave cylinder clutch setup
Warn M8000S winch mounted behind the front frame rail (plated in 3/16” steel)
Braille G30 lithium battery (with a custom bracket)
New MJ fuel tank
MTS Jeep MJ sending unit w/ a Walbro 225 lbh pump and a TJ fuel level float
All AN fittings and push-lock line
Corvette fuel pressure regulator and filter
Best MJ story-
I had a 1987 Comanche Sport in High School (2.5L, 4spd, 2wd, zero options) that I painted yellow and was so sure I’d convert to 4wd that I went ahead and threw some factory 4x4 badges on it after the repaint. I drove it all through HS but never did the conversion. After getting stuck in a foot of snow one winter I decided I needed 4wd and ended up getting rid of it in favor of a XJ followed by a ZJ. That was over 20 years ago. Last time I saw that Jeep driving around my home town, it still had 4x4 badges all these years later. Now I’ve owned 15 or so Jeeps and decided it was time to go back to where it all started!
CC is Awesome! Why?
Comanche Club is an excellent resource for information and I don’t think I could have done this project without referencing previous LS swap write-ups!
B3C4B128-3BCD-48C4-966E-B19408B56BE6_1_105_c.jpeg.d2cef17aa872a6ef817a07b18a63661b.jpeg
F4E4226D-8876-4866-ABEB-093E0153D625_1_105_c.jpeg.b4c175084d79252ebc259fa0ad5b2538.jpeg
233442E5-9114-4215-9019-D88F8C11153F_1_105_c.jpeg.7bc4551fecc29f0c32fab307fe9df427.jpeg
F77B28C7-AB04-4EB1-AA70-A3001649D517_1_105_c.jpeg.b7d92596592ca6283df7815f7d4907e0.jpeg
This is a fantastic looking truck. You earned this, @USN_JeepMJ. I really like the color. It's unusual, but turned out fantastic.
  • 4 months later...
  • 5 months later...
