8
Everything posted by 89 MJ
I was so excited for the release. I love the concept, but I do not find that truck to be good looking.
I don’t think it came on the base/Sportruck trim level
The Ultimate "While I'm In There" (Advice Needed)
89 MJ replied to Backpacker's topic in MJ Tech: Modification and Repairs
My honest advice is don’t cheap out and save stuff for later. Now will be the easiest time to do things like pull the dash to replace the heater core, change suspension bushings, fix all the leaks. It’s all more money, but it’s going to be the cheapest to do now. -
BA10/5's have a 21 spline output to the transfer case. AX-15's have a 23 spline output. Unless you want to change the input shaft of the transfer case, you will need one of those as well.
83 seems right to me too. I’ve heard of 83 Eagles with serpentine setups too, but none earlier than that.
Some of them did. I haven’t found any rhyme or reason to it though. It came out sometime in the early to mid 80s, but never seemed to fully replace the v-belts, at least not until after 88.
A grinder and paint makes me the welder I ain’t! Probably will have to modify the diff mounts for the pinion angle. Why does the pinion angle need to change?
Thanks for the tips!
I'm glad to hear that you 2.0 has been pretty good so far in the time you've had it
Coolant Loss. Dip stick clean, and no leaks
89 MJ replied to RG67MA's topic in MJ Tech: Modification and Repairs
Have you let it get up to temp and then inspected everything under the hood while it’s running? It might be pushing out somewhere while it’s running and the cooling system is pressurized. -
Gotta love seeing an MJ being used more like a truck than most late model trucks!
- 3 replies
- northern california
- keeping warm
(and 1 more)
Tagged with:
I’m glad the shifter is in the same spot, that was one of my concerns when I go to 5 speed swap my car.
Got the front Ranchos in tonight. The Jeep feels a lot more planted on the roads. Sway bar disconnects this weekend or early next week, then I’ll get a report on the dirt. What are people’s thoughts on removing the rear sway bar? I very rarely end up on the interstate.
Let's see some pics and hear more about the truck!
Project distraction... 65 Olds F-85
89 MJ replied to A-man930's topic in Member Projects: Other Cool Stuff
That looks like a super nice car! I'm a sucker for 64-67 A-bodies. -
VIN Registry List: October 2026 Update
89 MJ replied to fiatslug87's topic in Comanche Registry (VIN decoding)
You should be able to send him a PM now. Do you have the VIN for the frame? -
Finally installed those rear Rancho shocks. Still need to install the fronts and the sway bar disconnects. Last weekend, there was a ride to Aliso Springs near Gardner Canyon. Nothing difficult, but it was a beautiful trip.
1989 ba10/5 rear main seal
89 MJ replied to Buffalo Man's topic in MJ Tech: Modification and Repairs
What year is it? That’s a good deal, but an external slave one is better. -
I just saw that yesterday too. I was happy to see it. It would be great for someone who hits trails regularly or tows regularly, but also likes the interstate.
I figured that was probably the case, thanks for confirming
I'm seeing a 33.5 having 602 revs/mile and a 35 having 576 revs/mile on your site. Did you use the actual measurement of a particular 35? At 33.5s, I think I'd stick with 4.10s. For a 35, 4.56s would be my vote.
I do not believe that you have to remove the engine to change the RMS on a 4.0, regardless of engine. Where are you finding that the rebuild for the AX-15 will be $700? Or is that figuring the initial purchase of one that needs a rebuild? I'm seeing rebuild kits for $350. That is assuming that you have the AX-15 crossmember already and that you're clutch and flywheel are in good shape. I would also only do an external slave AX-15 swap, as the internal slave cylinders don't seem to be made well anymore. How do you use the truck? If you do a lot of towing and hauling or like to drive the truck like a sports car, it would be worthwhile to swap to the AX-15. If you just casually cruise around in the truck and don't really use it for truck stuff often, the BA10/5 will do just fine. In fact, my BA10/5 was a much smoother shifting transmission than my rebuilt AX-15 is. How much oil is the truck really leaking? Unless the oil leak is very frustrating to you (I am one of those people that hates leaks) or the clutch is getting oil on it or its causing other problems, you can buy a lot of oil for $700. If the engine also has 220k miles on it, there is a chance that the crank is worn and a new RMS won't completely fix the leak anyways. -
If I were on that side of the country, I'd probably be all over this. Matching dash bezel, tilt column, turbines, all the chrome. It would be a beautiful truck restored. I hope the next owner goes that route.
I've done a lot of the easier performance mods you can do to a Renix 4.0. I have 4.10 gears with 31" tires as well as a 4.0 and a 5 speed, which I think HO header HO head (actually a whole HO long block, but bottom end differences are negligible) Bored throttle body 4 hole injectors High altitude CPS The big one I have not done is the horseshoe intake swap. Having spent hundreds trying to hop up the 4.0, I can confidently say that they did not add 20 hp to my truck. I would like to do the horseshoe intake at some point so that it will match the intake runners in the HO cylinder head better, but I highly doubt it will add a noticeable difference. If I could do it all again, rather than swap my truck's original rod-knocking Renix 4.0 for a good, low mileage HO 4.0, I should've swapped to an LS and had the power level I was happy with and (likely) better fuel economy.
