Location
Mooresville, NC
840 profile views
JimiGibbs's Achievements
Comanche Aficionado (4/11)
Got it..... THANKS!!!
THANKS..... Yep it's the ash tray light. Works with headlights turned on. Plus now I know where to look for the floor board plug.
My '89 Pioneer did not come with floorboard lights.... I have the plug pictured but I am not getting any power to it. The dome fuse and dome lights are good. Is there another connection I need to check? Something that needs to be changed since it was an option? Also are there 1 or 2 plugs? I can only find one.....
Driving light wiring help....
JimiGibbs replied to JimiGibbs's topic in MJ Tech: Modification and Repairs
Well.... after I checked the switch , checked the relay and checking continuity of all wires..... It was a bad ground on the lights themselves. -
Yea.... Still doesn't work with the headlights on. About to go start doing some troubleshooting. -
Just wired up my Hella 450driving lights.... When I flip the switch I hear the relay click but no lights. Am I correct to assume I have a bad connection between the relay and the lights? Pretty sure everything else it wired correctly.... THANKS
$65 http://www.amazon.com/HELLA-005860691-Lamp-Kit-Multi/dp/B0049DDQF0/ref=sr_1_1?crid=2XSAPWQ6YHCK9&dib=eyJ2IjoiMSJ9.26Z7vTd_RpOTBqSSH1yIbEBcFlqUt6jhSVT5XRdunv5jgPoEbQ8B5MZY7UUDNGy2SU9v1uD5AUO34oX-xbMyMLzGClQc04mCf5NDykawKyBMe2p0t2EJBoRJRV7O8i7yFOZCDe7rPGPfww0AfLnpGOnbBDZJJ9Ppu_vB_6TYUzYgNrQ35dKilHW7i0zKKrbo_xM0Rfk7TaHRTGU4XKc8tQ9QU_x4fNsswLVgEatjW7z_Zy3XCgv2Z0oazlkJFxAdUfnjLvH_JU1vy8lB3Vg4ZNS-d87ETYKfEnSkFGt2FhY.SuVcrNJ-ZJCc3wtqtpSZN8RgKSbQ1OffKh3UPDdiw9U&dib_tag=se&keywords=Hella+005860691+450+Driving+Light+KIt+H3+12V+ECE%2FSAE&nsdOptOutParam=true&qid=1771361455&s=automotive&sprefix=hella+005860691+450+driving+light+kit+h3+12v+ece%2Fsae+%2Cautomotive%2C197&sr=1-1
My '89 is done...... as if you are ever done.
JimiGibbs replied to JimiGibbs's topic in Member Projects: Your Comanches
It’s the current Jeep Bright White color. -
Have one for sale in NC if you are close..... to heavy to ship. CURT 31084 $100 https://www.facebook.com/marketplace/item/25711790388479464
Ahhhh….. yes. I believe you are correct. Forgot about that.
I assume this is for an option my truck does not have..... Can someone tell me what it is for? THANKS
Thanks for all the replies.... Since replacements do not seem to be readily available I ended up trimming the neck of the fender pins (same diameter) so they fit in the slots on the back trim. Should work fine.
