Javelinmania
Javelinmania's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. let me know if you are going to do more - I could use one in "Sand".
  2. I looked at my PDF and sure enough, I had two page 58s. I inserted the page provided above into my pdf.
  3. I want to thank everyone who responded. I found a used set on eBay. Hopefully will put them on this month. Mark Fox
  4. Looking for sources of the front Inner Protective Fender. Does anyone still make them? 5500 1890 - PANEL, Inner Protective, Right (Inner Fender) 5500 1891 - PANEL, Inner Protective, Left (Inner Fender)
  5. Thanks - I will look at the liberty
  6. do you cut the mounts off the old D35 and weld onto the Liberty axle or do you obtain them form another source? Lots of Libertys in the junk yards.
  7. I like the D44 for the ease of installation. The spring mounts are exactly the way they need to be. I don't know what it would take to modify one of the other options you mentioned. The easier they are to install the more I would be willing to switch.
  8. I am wanting to upgrade my Comanche to have a Dana/Spicer 44 rear end. I will be towing a boat and want a stronger unit. I will upgrade the unit to a 4.10/4.07 if it is not already set up. I am in South Carolina, but can pick up any location east of the Mississippi River. Would consider crossing the river if not going too far.
  9. Don't know if they made them but would like to put a front hitch on my Comanche to make it easier to park my boat.
  10. Thanks - My local AutoZone has a box, and I will pick it up Monday.
  11. These are for the fuel injectors.
  12. I lost one of the clips on the right - but I found these on Ebay. I want to extras of the one on the left - but I can't find them or have the part number. Anyone have a part number or know of a source?
  13. current price with shipping for the seat brackets?
    1. krustyballer16
      krustyballer16
      $115 shipped for a set.
  14. I will be putting in fuse panel soon. Here is what is inside. The wires are different gauges. The longer wire is a thicker gauge than the shorter one.
  15. When I look at the electrical manual, I do not see them on the starter relay and placing them on the battery would unclutter the area some. Too many wires in a tight location. They could easily go back to the relay. Any thought on the amperage of the fusible link? I am looking at the wires and I think several need to be replaced as the wires are not in the best of condition with missing insulation. Some black tape could help to resolve the issue.
