Jeeper1093
2 Followers
    NC High Country
Jeeper1093's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. The pinion is very small on 5:13 gear for a Dana 30 and prone to breaking under stress. I would go with 4:88
  2. Agreed on the regear!
  3. I need a renix version. Anybody still have one?
  4. It did the last time that I was driving it regularly, but that was year before last. It has been parked and stored while I've been redoing the interior. As soon as I can get it driveable I will take it to the shop and dive into it a little deeper.
  5. Thank you guys! I will check that this evening if I get time
  6. put the old cluster in and did the same thing. Did some testing and I believe that the sending unit has gone bad.
  7. Upon further testing, I can manually move the needle to empty and turn the ignition on and the needle goes slowly to full and stays there even if the ignition is turned off
  8. everything seems to be working but my gas gauge. I get no movement in the needle when turning on the ignition. Any thoughts?
  9. 😆 😆 🤣 Got it! Thanks for the help. From what I've read I need to turn it all the way to the left correct?
  10. is this the adjuster screw?
  11. Thank you for the info guys! Much appreciated. I am planning on swapping both the cluster and cable so hopefully I will be good. I have a feeling that my tach is not adjustable but I will see
  12. I also have the speedo cable from the 87. Can it be swapped as well?
  13. I have a cluster with tach from an 87 with a 4.0. Can it be swapped into and 86 with a 2.5?
  14. WOW! That's some seriously strict inspections! I guess Canada wants everything to be pretty! We have inspections in North Carolina but it is just a safety inspection and emissions in some county's
