boxyjeep
Everything posted by boxyjeep
  1. Cameron Hill in Apple Valley can and will do this for a reasonable fee. Recently had him install on my MJ.
  2. Yes, need to update website. keep an eye out
  3. EGR plate and adjustable FPR can help. The ECU is just so bad you need to “tune” around it. I’m running a 4.6L Renix stroker. It I had to do it all again, I’d 110% go LS.
  4. Good chance the needle has over-rolled. Rotate it counterclockwise by hand and see if it works properly thereafter.
  5. This! I almost want to buy this cluster for myself lol
  6. That looks about right. They are a tight fit
  7. Share some pics of how you installed it--it may be backwards.
  8. Scuff with 3M pad extensively. Clean with acetone. Self-etching primer. Then black top coat. I’d do semi-gloss or flat.
  9. The screw packs that I sell will work. Along with the MJ B pillar caps.
  10. We did stop making these.
  11. I stock a few of these. Take a look. https://boxyjeep.com/products/84-96-gauge-cluster-bezel-clear-acrylic-cover
  12. Thanks! I haven't tested it on the B-Pillar but believe it should work.
  13. Screw assortment: https://boxyjeep.com/products/interior-screw-assortment-jeep-xj-mj Caps: https://boxyjeep.com/products/interior-trim-bolt-hole-caps A Pillar Retainer Fix: https://boxyjeep.com/products/a-pillar-trim-repair-domes
  14. Sold all of them locally in 1 day minus the gold diesel and my original blue. These things go fast!
  15. Selling off some of my tailgate collection to fund other projects. Located in Orange County California (southern CA). $200-300 each depending on condition (excluding the mint diesel tailgate--$800 obo for that). Will include one of the BoxyJeep Wall Mounts as well if you want it.
  16. @Parei_doll_ia Did this EGR tube pass smog for you in CA?
  17. No internal reinforcement brackets :-(
  18. Finally available! https://boxyjeep.com/products/renix-adjustable-fuel-pressure-regulator
  19. The time has come. We now offer an adjustable fuel pressure regulator that is direct fit for Renix fuel rail and intake. It utilizes a variety of custom-machined AN fittings and brackets, in addition to a standard Aeromotive universal bypass regulator. Available on our website! https://boxyjeep.com/products/renix-adjustable-fuel-pressure-regulator
  20. Apparently they are missing some critical parts that the seller fails to mention. https://www.facebook.com/groups/290347454873553/permalink/1904574196784196/?
  21. Just swap out the 87-90 full cluster. It's plug and play. Would also suggest converting to an electric speedo with our kit!
  22. I don’t think it matters so much. I haven’t tested it personally, but likely both routing options are fine. HOWEVER, if you have an old heater core and switch it without replacement, it may loosen up some residual gunk that may end up in your cooling system…
  23. Very nice! And that engine bay looks mint!
  24. That bracket is different for different years. Cut yours off from your OE cover and attach to the new cover with rivets. That being said, it's not super necessary unless you're running a mini console.
