Everything posted by watchamakalit
Make it something hot water capable at that point. Hot water is a game changer in pressure washers. And if I'm not mistaken a "hot water"pressure washer can be used with cold water also with no changes.
*Not a pressure washer expert. Gas over electric, and the highest pressure and flow you can afford. I think they are all very similar as far as build goes. Motor pump and a hose, not much to them. I purchased a Coleman(?) Several years ago from tsc. Honda motor on it, the whole unit has been a home run. I'd buy another today if needed.
My 85 cj 258 came factory with v-belts.
Could you share info on that alignment jig? And as always your work yields amazing results. I for one am extremely jealous of your attention to detail. Truck looks top notch.
This is something that has always interested me but I have yet to take the leap. What would be a good starting point for someone who has no idea what he is doing? Website suggestions on where to begin the learning curve? Suggestions for a decent quality beginner printer? Is there even such a thing or is it a buy once cry once kinda thing? I have no cad experience, except for about half a highschool semester, 30 yrs ago. And a very basic understanding of machine and machine work.
Took the wife for a birthday dinner last night. (sorry no pics). Hoping to get it to the squirrel woods for a little tree rat shoot this afternoon. Trying to enjoy it before the salt trucks make me put it away.
There is a company still making them (I just bought mine a couple years ago). I don't remember the company name. Would have to check my binder. Edit: It seems I am mistaken, core shifters no longer seems to be producing a shorty. My apologies.
Sounds like a good excuse for a short throw shifter....... Hurst I mean.
Don't let me get in your way,. I decided I don't need another divorce...🤣🤣
Your not helping me to convince myself I don't need this truck. And I'm on the right side of the country, just a ways north.
I hauled a lot of firewood on trailers with my mj. Mostly local (30-45mins) from home. It will tow fine, you just have to remember it is a midsize truck built during the fuel crisis. It is definitely not good for heavy trailer loads but will handle smaller stuff just fine. I have to agree with everything else that was said. MJ's rule the truck world.
Have we firmly established the gender of said truck? Can play a big role in the naming process.
Can I send $5 for the one on the left in the first pic?
I'm soo sorry. I completely forgot about glad you found one.
Engine Cooling - Master Thread
watchamakalit replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
Our cooling systems will work fine in stock form for a stock truck. start lifting or adding bumpers and you effect the capability of the cooling system. I run a stock system with the exception of a mac's aluminum tank (fancy open system swap). No other mods. Clutch fan with stock aux. electric fan for the a.c. No issues. If your having cooling problems it's most likely a sign of underlying, bigger issues. If I could obtain a good plastic expansion tank I would have been satisfied with the closed system. The mac's tank seemed to be the simplest and most bulletproof solution. So far so good. -
Good chance I still have mine although, mine was a tj shifter which is taller. I will try to remember to look when I get home.
Replicating MJ Bumper Caps
watchamakalit replied to White_Comanche's topic in Vendors- members making products for MJs
This is getting exciting..... I mean it was already exciting, now is more exciting....... Anyways, I'm excited. -
Coolant Loss. Dip stick clean, and no leaks
watchamakalit replied to RG67MA's topic in MJ Tech: Modification and Repairs
I had a small leak at my water pump to lower hose connection for years due to a faulty hose clamp. Didn't find it till I pressure tested the system. It never dripped on the shop floor. It was only evident by mysteriously disappearing coolant. I even did a probably unnecessary head gasket trying to fix it. -
"It's all in the Door Knob, Knob!"
watchamakalit replied to SGTSnacks's topic in MJ Tech: Modification and Repairs
I don't know if there is room but I wonder if you roll the window down and pull the window sweep off, will that leave enough room to reach down in with a wire\tool and hook the opener rod? Short of that it sounds like your pulling a door panel with the door shut. This is not a fun undertaking. I did it to an xj once in the junkyard. I hope I never have to do that again. -
Running and driving is a huge success in cj ownership. once that hurdle is cleared the rest is all gravy.
