watchamakalit
Everything posted by watchamakalit
  1. Years ago I worked with a guy who had one. I got to use it a few times. Seemed to work ok. bits were definitely sharper after.
  2. That's a good question. I have always thought it was just too much color.
  3. Also needs a new lower steering shaft. Speeds above 45mph are sketchy.
  4. Took longer to get insurance than I expected. Yesterday we took her to town, just to fill the fuel tank..... 75 miles later we came back home. We never left the county as I didn't want to deal with a long distance recovery should Betty decide to keep things. Made it back home with only some minor things to First is a leaking distributor base gasket. It's making a mess of things. Second I have a fresh leak of brake fluid out of the lid for the master cylinder. I'm guessing the master is about shot, it's been leaking this way awhile judging by the rust and damage on the inner fender. Third thing is the front passenger hub\brakes need my attention. Not sure if the brakes are hanging or a bearing is going, but the hub was about 50 degrees warmer than the others when I parked it. Sorry no pics.... Voltage and oil pressure gauge need looked at. I'm getting in correct readings from both. could be simple could be complex. Gotta dig in and see. Last but not least I need to reattach the driver front fender flare. It likes to Jeep wave at people all the time. lol Overall not too bad for the first bit of driving it's seen in 10+yrs.
  5. I don't have pics but they are essentially sheet metal with some "dented" sections for rigidity, a couple bends to match the door contour where the mirror sits and 2 nuts welded on a 90 degree bend to mount through the holes in the bottom of the door. Could be replicated, but I think getting all the holes to line up with the mirror mounts could be challenging. I wouldn't run tow mirrors without the braces. After installing my tows, it became clear there is zero chance the door skin would handle the stress.
  6. Mine was a smogged 305 with an auto. I was not a fan. it was ok for everything, but not good at anything. Not a car, not a truck. Just an odd bastard child.
  7. My first was chosen by dad. I don't agree with his taste and still don't. I beat it like a redheaded stepchild untill I destroyed it. Then bought my cj. Anyways it was dark grey with red trim, sorry no actual pics but it was a 79 like the pic.
  8. Don't forget to pull the door braces from inside the doors.
  9. Only time mine don't leak is when they are empty. Lol
  10. I prefer the k9 namesake. Never had a dog give me diabetes.
  11. It truly an honor to share a name with a beloved K9.
  12. Real jeeps are built not bought. Its truly funner that way.
  13. Muffler and tailpipe installed last night. Took it for about 5-6miles of country road cruising. So far all is well, would love to run it to town and back (10mi round trip), but no insurance yet limits how much I wanna be driving it. Top and doors came off today, hoping to get the insurance taken care of monday.
  14. There is a special bleeding methid for comanches due to the load sensing valve in the rear.
  15. Thats tempting. But its not gonna be a road trip vehicle. Small trips to town and such will be the most it sees.
  16. Got the new fuel filler and vent hose today so I put the tank back in and changed the oil. Fired right off thanks to the previously installed electric pump. I was shocked to find a keyed gas cap, not because its keyed, but because its key matched to the hardtop and doors. Let her idle and come around a bit before taking a lap around the yard followed by a trip down the road and back (just a mile). Drives like a cj, rides like a cj, sounds like a cj, I'm in love again. Next one the list is a transmission service, transfer case service, and a muffler and tailpipe are in order. Them its time to figure out why 45 feels less like "shaking hands with danger" and more like "climbing in the back sat of an old plymouth at the drive in with danger". Not exactly something I want to let the wife drive yet. It was definitely "exciting" to say the least. Every bump in the road was a direction change, you just can't tell which direction or how fast it was gonna happen. 87b6aa32-dc05-4003-b9f0-90d36a71ee68.mp4
  17. D300 for sure. Feed her some 80/90weight and got for its. Great case.
  18. I seem to recall a mber using closed cell foam to fill the gap between the fender and lower a-pillar in front of the door hinges to help with wind noise. Not sure who or when though.
  19. When I had leaky vent windows in always just glued a penny to the frame under the latch. I suppose a guy could drill and tap the latch then thread a panhead screw in it to work as an adjuster of sorts.
  20. I believe the shims will only fit one way due to their shape. The shims go between the starter and the block to help maintain the correct distance between the starter gear and flywheel.
  21. Vector end of discussion.
  22. The wiper arms will interchange without modification. The newer motor is supposed to be faster if believe.
