Dzimm Posted June 6, 2020 Share Posted June 6, 2020 What have you guys put off fixing and what did it look like when you finally fixed it? I put off the front end clunk in my 95 XJ for quite a while, probably over a year. Finally got around to fixing it because I was fairly certain it was the U-joints and that can be dangerous. Turns out I was right. Rust sucks. The needle bearings were either gone, crushed into a powder, or completely rusted into a solid chunk in the cap. Also broke my only working 1/2" drive ratchet taking the axle nut off. All the bearings and joints in the front end are being replaced now because they are either just as bad or I destroyed them getting everything apart. Link to comment Share on other sites More sharing options...
89 MJ Posted June 6, 2020 Share Posted June 6, 2020 I’m putting off swapping the motor. When I dropped the oils pan last year, I could wiggle the rods front to back about an eighth of an inch. Link to comment Share on other sites More sharing options...
Minuit Posted June 6, 2020 Share Posted June 6, 2020 On 6/6/2020 at 2:43 AM, 89 MJ said: I’m putting off swapping the motor. When I dropped the oils pan last year, I could wiggle the rods front to back about an eighth of an inch. Expand Normal. My 91 currently has a chrome, powered passenger side mirror and a black, manual driver side mirror. It's also missing the passenger side kick panel due to a secret project I haven't felt like working on yet. Link to comment Share on other sites More sharing options...
Pete M Posted June 6, 2020 Share Posted June 6, 2020 a-yup. those joints are toasty. I'm just going to post a pic of the Liberty, as the to-do list is loooong and other things keep cropping up that bump it down the list. Link to comment Share on other sites More sharing options...
Smokeyyank Posted June 6, 2020 Share Posted June 6, 2020 Life........ Honestly at this point I feel like a plumber fixing busted pipes. Which one is leaking the most gets the attention. Needless to say if I was in a ship taking on water I'd be sunk. But in the plus side no boring days! Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 7, 2020 Share Posted June 7, 2020 i have been putting off the basic run down maintenance of the jeep. Like topping off fluids after checking it to be empty. oops. also cleaning up and fixing lights and wiring issues. nice to finally have had a few days to just work on the wiring and ensure its all neat and mud proof. Also goiing to take my time and wrap my headers and see about knocking some of that heat down in the engine bay. heat soak is a mother. Link to comment Share on other sites More sharing options...
Torq_Shep Posted June 8, 2020 Share Posted June 8, 2020 Everything? Van: A/C Clutch, Struts, TREs, and front brakes all need to be done. Jeep: Way way too much $#!& to even list. Needs rear main done ASAP before I can daily it. Right now its a drywall hauler. House: The MJ may be in better shape... Link to comment Share on other sites More sharing options...
ComancheKid45 Posted June 9, 2020 Share Posted June 9, 2020 Green truck needs the frame patched on the Right Rear. Otherwise nothing too bad with any of mine (for now) Link to comment Share on other sites More sharing options...
Crash Posted June 9, 2020 Share Posted June 9, 2020 Rms and finish 4wd swap. Link to comment Share on other sites More sharing options...
thecodemonk Posted June 9, 2020 Share Posted June 9, 2020 A lot of things, but the main thing right now is the B pillar lights. I have the Euramtec lights, I just...haven't gotten to it. Maybe this weekend. Link to comment Share on other sites More sharing options...
87MJTIM Posted June 9, 2020 Share Posted June 9, 2020 The list is shorter for what I have done, rather than what I still need to do. Link to comment Share on other sites More sharing options...
Dzimm Posted June 13, 2020 Author Share Posted June 13, 2020 Got the front end back together and was swapping the winter wheels/tires and noticed something else I inadvertently put off.. Probably shouldn't put this one off though.. Link to comment Share on other sites More sharing options...
rylee144 Posted June 13, 2020 Share Posted June 13, 2020 I need to fix my AC and my B pillar lights. But they keeping slipping down the list. I need to cut off my front bumper and mount my new one. Link to comment Share on other sites More sharing options...
AeroNautical Posted June 13, 2020 Share Posted June 13, 2020 Floors... I bought the truck in 2011 and still haven't done the floors.. But I did just fix both manual window regulators, they go all the way down now! Link to comment Share on other sites More sharing options...
Comanche1 Posted June 13, 2020 Share Posted June 13, 2020 I too should have a look at my universal joints as I’ve been feeling a small vibration/resonance at higher speeds that I know isn’t tires. Just being lazy. Link to comment Share on other sites More sharing options...
Pete M Posted June 13, 2020 Share Posted June 13, 2020 I guess I need to retract my previous statement. Link to comment Share on other sites More sharing options...
gogmorgo Posted June 13, 2020 Share Posted June 13, 2020 Canoe rack mods. Just getting onto this. The weight of the canoe had been slowly pushing the one arm down. The rack was off the truck with the canoe on it over the winter, and it’s now warped down far enough that when I put the rack back on the truck this week, it’s touching the cab roof. I’m replacing the 2x4 rails with a longer 2x6, hanging some off the back end of the truck because I wasn’t happy with the main rail just ending at the rear upright. I still like the aesthetic of the brown pressure treated, but really starting to hate working with the organic cellulosic foam... almost none of the pieces of the rack are quite the same shape they were last fall when the rack came off. Link to comment Share on other sites More sharing options...
shelbyluvv Posted July 4, 2020 Share Posted July 4, 2020 My cracked block. It still runs though and has for 2 years.Sent from my moto g power using Tapatalk Link to comment Share on other sites More sharing options...
EvilMJ Posted July 24, 2020 Share Posted July 24, 2020 Replacing the inner axles seal AGAIN on the front axle... Last time I replaced it I broke a u-joint the next day acting stupid. Upgraded the axles, but was too lazy to pull the chunk and fix the seal. Its a slow leak, the mud guards keep most of the oil in, and I just check the level from time to time. Next time I'm going to go riding I'll have to fix it... Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 27, 2020 Share Posted July 27, 2020 Several things keep getting put off. The exhaust leak from the manifold... I have a new aFe manifold to put on, it needs a tune up after 12 years, inside cab lights, new carpet to install, front axle disco cable kit to install, High Lift jack setup to install..... stuff like that. I have made progress with things though. The front and rear hitches got installed, the front light bar and lights got done, though I still need to permanently mount the switch, made a new plate mount and new plate light too. Right now I'm fighting with the cooling system. Got a new all alum rad installed and a new Derale fan, but now its pulling more amps than before and it keeps burning out relays in the fan controller. I need to rig that up next, along with a new ground cable from the battery. Link to comment Share on other sites More sharing options...
