shelbyluvv
Moderators
    3
Everything posted by shelbyluvv
  1. I got my dash painted up and my double din installed. This is a donor dash that I use for mock up. The cup holders are in the truck on that dash. I can't wait to be driving this thing looking at that blue, column shifted 97+ dash!
  2. I honestly don't know. I pulled the stock interior out and never looked back. I am debating modifying a 84-96 HVAC suitcase to use the 97+ vacuum canisters for the controls. That could solve a lot of the welding issues on a 97 conversion.
  3. Damn Rich great progress!
  4. I just ordered a few cans. Can't wait to have a blue, column shifted 97 converted truck.
  5. I am almost positive I'm going with blue interior in my truck. That looks great!
  6. Today I finally found 3 more pieces of the puzzle. I can finally get to finishing the interior now that I have them. I found a junkyard on www.car-part.com That had a rear fixed rear window for $75. I made the trip today to get the glass and it wasn't cut out of the truck yet. I told the owner I would go get it because I had just driven 3 hours to pick it up. He was mad because the kid he hired never did it and told me to go ahead and pull it and take anything else I needed. I ended up with a perfect gasket, fixed glass and a headliner for $75! If anyone in middle Georgia needs any other parts the truck is there. Tailgate is trash and taillights are gone. Yard is called Mitch's Automotive in Barnesville GA.
  7. Tired of paying the "Comanche tax" for MJ specific drip rail molding I decided to try and modify some XJ moldings. A little work with a cutoff wheel, heat and some bending I had new moldings.
  8. I'm wiring them into the OHC wiring as it has the 12v constant, door trigger and ground. I will post the pics so you can have them though.
  9. Nothing spectacular that hasn't been done before. I got my Euramtec dome lights fitted to the B pillars.
  10. Thank you! Pete, it could work on a older dash if you're creative enough. Thank you Rich, I appreciate it. Thank you, I am very pleased with how they turned out.
  11. I have been out of town traveling for a bit. When I got home I set out on a mission. The entire reason for the column shift was to get everything off of the trans tunnel and clean up my floor. This lead to removing the center console that had my cup holders. Not wanting anything on the seat or the floor I had to get creative. I discovered VW hidden cup holders. A lot of cutting and filing to the 97 dash I had them installed. They work perfectly and look stock in the dash. Yeah I lost my cigarette lighter and 12v outlet. I can easily add a outlet to the dash or hide it and a couple USB ports in the dash. My radio has a USB port that will charge my phone so I'm not concerned at this point. Here's a video of them in action https://m.youtube.com/watch?feature=shared&v=7mib8xrbrFw
  12. I got the dash put back into the truck just in time to check my handy work. What's the glow between the radio and column? Ah, that's right. It's the gear indicator.
  13. Thank you kindly
  14. Thanks Ben, I appreciate you saying that. Your builds are amazing as well.
  15. You're welcome anytime Pete
  16. I messed with the dash a little more tonight. Because I have a column shift there is no longer a gear position indicator. I decided to fix it. I modified a Durango PRND21 indicator and my dash to accept it. I am going clean up the widow a little and mold some clear acrylic in it be flush with the dash. The final step will be to get a light mounted to light it up at night. I plan to use the old floor shift bulb to get that done. This column install has been one of the most satisfying things I have done to this truck.
  17. I had the great idea to put a 1999 Durango column shift column in my truck. Getting the actual column in the truck was the easiest part. Then came the process of getting all the wiring for the the horn, ignition, wipers, turn signals, four ways and so on working. I was even able to get the key "bling ring" working. A function check revealed that the delay for the wipers did not work. This lead me back to doing more research. The 97 XJ delay is controlled by the actual switch. The 99 Durango delay is controlled by the BCM. Then I remembered the 84-96 XJ used a separate delay module. I went to the local junkyard and stumbled on a RHD 96 XJ. As of it was destined to be the connector was exactly the same as the 99 Durango! A little more re-pinning and splicing of wires and my mission was accomplished. The final step is to get the column connected to the intermediate steering shaft and it will be complete.
  18. Let's just say Nick is excited about this also...
  19. There is a 1" LED shift position indicator being made as we speak. The plan is park ard reverse will be red and the other positions will be blue.
  20. It's finished! This was a very fun and challenging project. I had to re-pin everything in the column to work with the Jeeps wiring. It is worth it to me to have the only true, full 97 conversion with a column shift. Yes there are guys who slapped the new dash in and kept the old column and wiring. I don't do things that way. I will finish taping and routing the wires down the column once it stops raining. To say I'm proud is an understatement! VID_20231011_135801790.mp4 And the shifter changes the gears like it should. Wait until you see the gear indicator being made!
  21. Here it is! The initial fit up is going great. I just need to find a shifter cable and splice wiring together where needed and it will be done.
  22. 97-99 Dakota/Durango looks like a promising source. We'll see once my column arrives.
  23. I have a 97 dash in my truck and in my quest to be different and totally piss off the Jeep world I have decided to do something off the wall. I put a "couch" out of a El Camino in it to start with. I have modified some Rover speaker pods for my doors. I already have a cut down XJ OHC in it. So what's next??? I am going to make it a blue interior, velour bench seat, column shifted, 97 MJ. That should be different!
  24. I actually took the 97+ bumper off and went with a old style. I like it better.
  25. In my quest to have a unique 97+ interior I added some speaker pods/map pockets to the doors. They needed the top part trimmed off and the corner molded to clear the dash. They fit perfectly beside the El Camino seat.
