dasbulliwagen
    3
3 Followers
    Asheboro, NC
dasbulliwagen's Achievements
MJ Maniac
MJ Maniac (8/11)
  1. Just something to think about. I'm pretty sure that the 4.0 belhousing bolt pattern is the same as the AMC V8s. 304, 360, 401?!? And it's been a long time, but I think I remember someone in the build section doing a Chrysler 318/360 swap trying to use mostly all factory made parts. Just a couple of other options for you. I looked into the diesel 4BT swap a long time ago, but the costs got a little ridiculous fairly quickly. The little 2.5 in mine is pretty much the only thing I've never had to touch on my truck, and as long as it keeps going, I'm not going to worry about it. Yeah it's slow, but I've come to terms with it.
  2. One odd leak point I've seen on two of them is around the big electrical connector that goes through the firewall on the left side. The seal dries up and shrinks allowing water through. I've been fairly successful in adding flowable clear silicone sealant to get the leaks to stop.
  3. Here a VW mini Camaro kit car my grandfather built in the '70's. It's on a Beetle chassis that's been shortened 24 inches. He kept it until the '90's when my dad got it. He and I got it going again back then, but it got put back in storage until my dad gave it to me. I trailered it from Michigan to North Carolina back in April. I'm cleaning it up now for a local car show next weekend. I still need to go through the brakes and fuel system, but hopefully I'll have it going again next year. Until then, I have it where I can drag it around locally.
  4. I too like 1969. 1969 Kaiser Jeep M715. 1969 Ford F250 Highboy. 1969 Mustang Mach 1, 428 Cobra Jet. 1969 Porsche 911T. 1969 Volkswagen Karmann Ghia convertible.
  5. I was going through my old threads and found this. I thought I'd share a little update. I did end up with the AT3's. I had a little over 30,000 miles on the Grand at the time. The tires have been awesome in all conditions. They've worn smoothly with rotating them every oil change. I'm coming up on 90,000 and they still have a little life left in them. I was thinking about having to replace them later this year, but I'm wondering if they'll do good for us until next year. Also, Cooper has redesigned their all terrains again, but they have great ratings too, so I'll probably get another set. Here's a pic from April when I towed this Uhaul trailer with my VW kit car on it from Michigan to North Carolina.
  6. High school, I started out in my parents cars, 1985 Ranger, and 1985 Caprice Classic station wagon. I had bought a 73 Beetle to work on in Vo-ed auto body, but never got to drive it. Then I bought a 64 Beetle which was the first car really mine that I got to drive to school. It was a rust bucket with no heat in a Michigan winter, but it drove good. Then before going off to college I bought a 72 Beetle. I sold that bug before graduating college in order to buy a 72 Karmann Ghia. Good times in the early '90's!
  7. It's been just over a year since my last bump up with the assistant Fire Marshal where I got my wagoneer front end messed up. This morning I got rear ended at a stop light. No one was hurt, as the hit was at relatively low speed. At the intersection, I was second in line, stopped, with another car stopped behind me. A young man in a Corolla must not have been paying attention, and rear ended the car behind me, pushing her into my truck. I had my tailgate down carrying an 8' piece of plywood. Her CRV went under my tailgate and into my Krusyballer hitch which had a ball in it. I'm pretty sure the ball and hitch took the brunt of the hit as I have no visible damage to anything on the rear of my truck other than paint rub on the ball from her bumper. I'm glad it wasn't bad and that everyone is ok, and that I won't have to deal with making a claim. I'll add a couple pics below.
  8. Another 2.5 guy here. You most likely won't notice anything with the weight difference or size difference on anything up to a 235. I too started out with 205's then on to 235's, then on to JK takeoffs measured at close to 32". I didn't notice any difference up to the 235's. I think you'll be fine with what you're planning on. To add to that, on the smaller sizes I had the 3.55 axle in it, and when I converted to 4wd I went to 4.10's with the JK wheels and tires, which helped but 5th gear is almost unusable with the 2.5's power.
  9. My experience with replacement welded aluminum radiators for the 2.5 is that ones advertised as two core are actually still a single core, but it's twice as big as the original single core. That threw me off when I first got mine. I can't remember the brand but I bought it on Amazon. I tried searching my orders and it shows that I purchased it in 2014 but the information on the rad is no longer there. I run mine with a single electric fan with an aftermarket controller. As long as the fan is actually working, I have no issues with overheating.
  10. Didn't some forest service or police package XJ's come factory with the bench? The buckets are cool, but a regular cab truck really needs a bench, and having a bench in the front of an XJ is no different than the old days of having a bench in a wagon, which is basically what an XJ is. Post some pics when you get this done, we'd love to see it.
  11. If I remember correctly, that EV1 was donated to a college, who abandoned it, at which point it was towed, and the tow company put a mechanics lean on it and was able to get a title for it through that process. I don't think GM could legally do anything at that point. The tow company sold it for around $100,000 if I remember correctly. There are one or two different YouTube channels that are covering it's restoration, including The Questionable Garage.
  12. I did the same with my 87 Sportruck. I started out by adding a p/s box from an 86 Comanche, because that's what I had, but later installed a ZJ box. It has a quicker ratio. Lock to lock from the 86 p/s box to the ZJ box went from 3 1/2 turns lock to lock, to 2 1/2 turns. There is a connector already in your engine bay harness for the p/s pressure switch. It's plug and play. It will turn up the idle when it sees pressure too high. Beyond that the 87 2.5 had a remote reservoir pump, that at the time I did mine the reservoir was unobtainable. I do have to say though, that adding p/s is the best upgrade I've ever done.
  13. When I first got my truck, it had a stumble/ power loss that took me forever to get rid of. I finally replaced the O2 sensor after trying a ton of other things, and its been fine ever since (the last 20 years). I was still able to get a factory one back then, so that's what I installed. It's worth a shot if you haven't done it yet.
  14. Other than the classifieds here, a junkyard or pull a part places, or marketplace for parted xj's. 86 is an odd year for Comanches, mostly considering the wiring. They started changing some of the connectors in 87 and later. Same year XJ's work too for dash parts, but all other interior trim is different than Comanches.
  15. Yes, the seat needs to come out to install the carpet. If you have the new carpet, it will need to be trimmed on all edges to fit, as well as cutting the holes for the seat mounts, the seat belts and shifter. It's not horrible to do, but it does take patience.
