watchamakalit
Everything posted by watchamakalit
  1. Avoid semi metallic pads. Ceramic much better braking and alot less dust. can't speak for rotors. You could get some fancy drilled and slotted rotors to help with heat disapation, however I don't feel it nessecary. In my meager experience over torqued lugs are more often the cause of warped rotors on the xj/mj platform.
  2. He has a full set. https://fortwayne.craigslist.org/wto/d/spencerville-chrysler-jeep-wheels/7551997545.html
  3. I don't say much but check daily for the updates. Your work never ceases to amaze.
  4. Battery sawzall + metal blade = road sign removal kit. Id give $50 for one. Lol
  5. I am an android user and had tapatalk for a while but ditched it due to issues with viewing and uploading photos to cc. I now have a bookmark set to take me directly to the new posts here. Wouldn't go back to tapatalk for much less that about $50000/yr. Lol
  6. Snow Chili: beans or not
  7. watchamakalit
    CC cookbook
    By special request from Mrs. Watchamakalit: 3lbs largely diced potatoes. Rinse and placed in large pot. Add enough water to cover potatoes. (Can also use 1/2 water, 1/2 chicken broth.) Add garlic and onion salt. Bring to boil and cover. Boil till you can poke with fork, but not fully fork tender. Turn down to simmer. Add 1 block cream cheese, diced melts faster. Once melted, add 1 can cream mushroom, 1 can cream celery, 1 stick butter, 1 cup milk. Continue to simmer until potatoes are fork tender. Scoop into bowl and add freshly shredded cheese and bacon bits.
  8. watchamakalit
    CC cookbook
    Unfortunately, I'm not the cook in the house. Its potatoes, and some other tasty stuff in a bowl. Lol
  9. watchamakalit
    CC cookbook
    Sounds like potato soup weather.
  10. watchamakalit
    Dogs!
    They make good chew toys.......
  11. watchamakalit
    Dogs!
    The growth continues..... 7months, 65lbs. Couldnt ask for a better behaved pup. He is gonna make for an awesome buddy. Everyone needs a lab or 3.
  12. Contact the auction company and see if they would be kind enough to contact the purchaser on your behalf. I wouldnt ask for the purchasers info (seems to personal). But see if they can pass a message to the purchaser to contact you and express interest or even pass on the Comancheclub website.
  13. Another vote for water pump. If you haven't messed with that lower radiator hose clamp before discovering the leak, its rare a hose clamp spontaneously fails. I just went down this path about a year ago. I can't play the video to hear the sound but given the signs ive seen i would change the water pump.
  14. I use an old bar style double flare set. No idea the brand but it works well for me. These days if I have steel brake line issues involving rust I simply advise the owner to purchase a full brake line kit from dorman or some other manufacturer. My days of chasing rusty lines to install half a dozen splices are over. If a brake line goes to $#!& on a vehicle, the others aren't far behind. The complete hard line kits make live so much better. No worries about where the next leak will occur. Just my $.02 YMMV.
  15. Indiana does not view a clerical error the same as an absent title.
  16. I swapped a 44 into mine with the metric tons. No need for bumpstops. don't think the chassis would hold the weight it would take to load them that heavy.
  17. Metric tonnes for the win.
  18. It will absolutely handle it. I have a 5x10 that gets loaded to the brim with green wood and the MJ handles that just fine.
  19. Looks to be a Willys product
  20. Intake gasket failure/loose intake bolts would cause a vacuum leak signifigant enough to stop a cylider from firing.
  21. I looked into that a little while back. Do people just put the vermont plates on it or is there a way to later convert the vermont registration into an indiana title?
  22. Entirely possible. I don't know the relationships.
