Everything posted by watchamakalit
Finally found one...Now it has a new floor.
watchamakalit replied to watchamakalit's topic in Member Projects: Your Comanches
So I am awaiting a new clutch master,line, slave combo to arrive. And the mail carrier paid me an unexpected visit. I knew it was on its way but unsure when it would arrive. Now I'm excited to get the clutch hydraulics fixed..... -
May 2022-Project Uncompahgre
watchamakalit replied to 89 MJ's topic in Comanche of the Month (MJOTM)
An inspiration for sure. Your ATD is second to none. -
Clutch Master Cylinder
watchamakalit replied to Torq_Shep's topic in MJ Tech: Modification and Repairs
Ive been thinking about it, I did change the line because I went to an external slave ax15 when it did the 4x4 swap. The while system was new. Apparently something isnt happy by the looks of the juice. I think I might just swap the whole system again and try to stay up on flushing it periodically. -
I didnt replace but flushed it all really well I had read about the fluid issue. Maybe id just be better off with a complete new system. -
So whats the decision on the best? Mopar? Or should a guy just bite the bullet and auto swap? Mine is leaking again after 2yrs. -
mini beast Project: Stock To Beast!!!
watchamakalit replied to MiNi Beast's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Oh new scars. I didn't think about that -
Paint? I never took you as a " make it pretty" kinda guy. -
Its like christmas..... Gm pivot pin puller and lock plate removal tool arrived today too. Maybe I can finish the column tonight. Sure have been glad for the wj backup driver. Treated it too a full tank and a trip through the car wash. Maybe I can have my truck back by the weekend..... -
I think he was asking about the body kit that is missing. The street comanches all had fiberglass body kits that were exclusive to them.
I would really like to make it this year. I'm not definate but will really close.
I believe he meant "flex plate bolt".
Cruiser54.com That site will help with ground issues. I would suggest steps 1-5 at least. Welcome to the addiction.
Glad I could help.
Swap to AMC V8 or to 3.4 Chev or Firebird?
watchamakalit replied to Melmoe's topic in MJ Tech: Modification and Repairs
Or if you really want the V8 I'd suggest an ls swap. -
Fuel injector electrical connector
watchamakalit replied to gvthnks's topic in MJ Tech: Modification and Repairs
Standard Motor Products S697 Pigtail/Socket https://www.amazon.com/dp/B000C81PJK/ref=cm_sw_r_apan_i_M2CF7GMGAQ653JR2077P I had a bad connector on mine a couple yrs ago. This is the route I went. I replaced all 6 with new connectors. I figured if one scrapped out the rest weren't far behind. -
I get a close as I could. Hood and expansion tank are kinda in the way. Hope this helps. I couldn't butt to the hood hinge so I hooked the hole in the firewall for the hinge.
Here is a good before and after. The untouched kickpanel looks like poop compared to the door trim. And after a few minutes of steam. Not great but good enough for a daily. -
Time for an update. The MJ is down awaiting parts. Coming home from work last week I noticed the tilt column was working loose. Not a big deal. Thats an easy evening fix, right? Apparently the snap ring that was replacing the lock spring retaining ring decided it was done. So I am currently waiting on a proper retaining clip to arrive. In the meantime I am taking g the opportunity to give the interior a thourough cleaning. I purchased a steam cleaner and a few cheap " detailing" accessories. The steamer has been a game changer for interior panels. Havent attacked the carpet or dash yet. Just focused on 35yrs worth of gunk on the plastics. -
Project “Tomahawk”
watchamakalit replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
4.0's favorite oil? (and change interval)
watchamakalit replied to brucecooner's topic in MJ Tech: Modification and Repairs
Rotella t4. Got the extra vitimins and minerals built right in. -
AX15 External Slave Cylinder
watchamakalit replied to KANTANKRUS's topic in MJ Tech: Modification and Repairs
That is the master cylinder for the clutch. The slave cylinder is either externally mounted on the trans., or internal to the bellhousing. -
I had planned on picking up about a month ago. Lol. It will probably be in the next 2 weeks.
