Everything posted by watchamakalit
NP229 rebuild or any T-case really.
watchamakalit replied to eaglescout526's topic in MJ Tech: Modification and Repairs
I've never been into a np transfer case, but I have homebrew twinsticked a couple of d300's years ago. Part of the twinstick job was removing a very similar pill to allow independent movement of the shift rails. This allowed for control of the front and rear out put separate from each other. That said I'm not sure it will work the same for the np case due to a single shift point and not 2 separate shift rails. I would be very apprehensive about leaving that pill out. The homebrew twin sticks had an issue with the concept that would allow an inept user to put the case in high and low gear range for the opposite axles. This resulted in rapid tcase disassembly, usually at unwanted moments. -
ax15/np231 rebuild questions
watchamakalit replied to watchamakalit's topic in MJ Tech: Modification and Repairs
Sounds like I need to look into Luk. Fortunately my ax is external slave which has been recently replaced. -
Thanks for all the responses. Any suggestions for a good clutch kit? I don't wheel the truck but it will see some trailer pulling, but mostly just street driving. -
A little back story is necessary. I bought my ax15 used out of a 96? wrangler (was a long time ago before I learned to write things down). It had an occasional grind going into 4th. The seller was open and honest about it and said it had been doing it for a while with no other issues. The price reflected the issue and I purchased it knowing it would eventually need a rebuild. Well the time has come the grind has not changed and it will shift smooth if you allow the engine to slow between shifts. It also has begun to pop out of 3rd upon clutch release. I am beginning the process of collecting parts and info for a rebuild. From what I have read I want to go with the Crown or transparts rebuild kits as they seem to be the most complete. Has anyone else rebuilt their ax15? Any suggestions or common issues I need to be on the lookout for? I also plan on a clutch replacement while I am in there. Suggestions on the best clutch? I don't wheel my truck, it mostly sees street miles with a good bit of firewood hauling, but honestly she is becoming more of a shop queen lately. lol Planning to rebuild the 231 while its out also. Suggestions on a kit for it? Anything in particular I need to watch in there?
Advice on 2006 jeep tj
watchamakalit replied to MariaManche's topic in MJ Tech: Modification and Repairs
Did you have the flywheel resurfaced when you changed the clutch? -
Good one Pete. I'd like to add blue "disposable" shop towels. I keep a roll in each vehicle and several in the shop. They are like a cloth paper towel. Wonderful to have on hand for everything from an oil check to a good nose blowing. Lol
91 MJ auto convert 2WD to 4WD - trans?
watchamakalit replied to 91Pioneer's topic in MJ Tech: Modification and Repairs
Just an fyi mj odometers can be changed without removal from the cluster. Meaning you can make the replacement cluster match the mileage of the old. -
Alloy wheels ok on Metric Ton?
watchamakalit replied to EUREKA's topic in MJ Tech: Modification and Repairs
I took am in the category of overloading my mj on alloy wheels without issue. -
It will slow the process but our climate is not steel friendly. Coatings exist but nothing is fool proof other than garage kept except for the nicest summer days.
Back history first. 88XJ auto engine harness swap. Never had any cooling issues since I bought it. I have never seen the electric fan come on. This started with an O2 sensor change to replace a non responsive factory unit. After r&r of the exhaust manifold to repair a buggered up thread for the O2 sensor, I come across this tucked away in the corner. Which set is the fan and coolant temp sensor and what are the others? One set comes from the large loom the other from the small. Also any ideas on what the red wire wired to the red with black trace in the small harness would be about?
I had the same issue with my race installer from Amazon. I have previously installed races with a drift and hammer. Precision fit between the race and driver are not necessary. The important part is not damaging the bearing contact surface and be sure it's seated. Try flipping the cup piece on the driver and see if the back side is a closer match the the race size.
From my limited understanding of plumbing, there's probably not much at all going on. 😂
'89 Base "Golf Ball" First Truck Build
watchamakalit replied to Warren99's topic in Member Projects: Your Comanches
Worth every dime. Imo -
I ran a YJ shifter for several years while searching for an xj/mj shifter. Someone on here (forgive my poor memory) showed me the short throw shifter formerly made by hurst. Wish I would have done it years ago. https://core-shifters.com/products/core-hurst-shifter-1989-1999-jeep-cherokee-comanche-6-cyl-w-ax15-5-speed
