EUREKA
1 Follower
    Nor Cal
2851 profile views
EUREKA's Achievements
Comanche Addict
Comanche Addict (5/11)
  1. Got an email for their black Friday sale and I have to have this, Renix Fuse Panel Bracket DIY Kit (Eliminate Fusible Links) What do you guys think?
  2. Oh $#!& I might have made have made a horrible mistake. I bought an iron rock off-road 3 link kit for my truck. All the research I did indicated that a well designed 3 link is just as stable on the highway or while towing. In fact many seem to believe that longer arms that are more parallel to the road ride better period. I might be misunderstanding the differences here. I had always thought that a 3 link could be stable on the highway and while towing as long as the geometry was set up correctly. Things like link separation, caster, track bar angle, and joint condition seem to matter a lot for how the front end behaves under load. It makes sense to me that a poorly designed or worn 3 link could feel loose, especially with tongue weight on the back of the truck. But I had assumed that a well laid out long arm 3 link would track straight and handle towing without any drama. If there is something specific about the 3 link layout that makes it inherently less stable at highway speed or with a trailer, I would actually like to understand that better. I'm still trying to wrap my head around what part of the geometry would cause that.
  3. Well it looks like I'm buying this as a parts rig today for $300.
  4. This has the 21 slot grill, which I see list for quite high prices. Also has the upper and lower header panel trim that I need to rebuild my truck. I was just wondering whats up with the location of Jeep logo? Did someone bondo the original mounting holes and stick this badge on?
  5. Great build! Congrats
  6. You have a 3 link right?
  7. How do you like the iron rock off-road 3 link? Any noticable improvement in handling or just suspension articulation?
  8. So the fan clutch from the ZJ will be slightly more parasitic and slight louder buy cooler better? I do have a 136 amp alt but yeah i think I will not go with the 3 fan set up. I found my flowkooler to be a decent upgrade.
  9. I think this is the route I will go. My clutch was at most 5 years old but both of my fans toast from the car wreck, as well as the shroud for the mechanical fan.
  10. Even at low engine rpm? Maybe I'll stick with the stock fan set up.
  11. Due to a auto accident I have to replace my radiator and AC condenser. My aux trans cooler appears undamaged. I do tow every week. Sometimes nearing 5000 pounds. I was considering eliminating the mechanical fan ans getting an all aluminum radiator with e-fans. Any recommendations? Thanks
  12. Working on a parts list. Looking for opinions and advice. My goals are a small lift, account for added weight of winch bumper, improve handling and braking, and improve off road performance in terms of traction (I've installed Detroit Truetracs jeeps in other jeeps Ive owned and loved them).
  13. Thanks Trey!
  14. I Thanks for the info. I think I'm going with the iron rock set up.
