War_Pony89
    Roanoke, Va
  • Interests
    Family, my truck, motorcycles, fixing stuff
War_Pony89's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. Which kicker sub are you using? Amp size? I had one 8" and 300W going to it but I'm thinking of going to a 10" or maybe two 8"s. That slot in the middle behind the seat worked great, box never moved when banging around in the bush and with a little design, two could fit back there.
  2. This is not a bad idea piecing together, I'm hoping some parts can be salvaged. I did like the ride I had, firm but not too hard on edges. I see in your profile you have a 'bumping system'. What did you have? Mine was stolen a few years ago during Covid, I miss it dearly and want to put one in better. I had an old Kicker Solobaric that did well and moved a lot of air, but they do not sell that model anymore, so I feel like I'm starting over.
  3. Thanks for the 411, I'll look them up. Just spoke to the insurance company today, waiting on their papers, they offered 13K with buy-back. may be what I need to get it back on the road?
  4. Two weeks ago, a septuagenarian totaled my '89. Still working with insurance, but also planning ahead. I have a Skyjacker 3" lift with disconnects I installed it in 2004, but I do not see if offered today? Did they discontinue it? Sites I go to only go back to '91 and no Comanche's. In case it is discontinued, what are the general recommendations these days for mild lifts and a good ride?
  5. Is it best to open up with the firehose or do a slow build into a raging inferno? I've been told its okay to be 'That guy' in this case....just coming up with a game plan.
  6. I fear my Comanche was totaled last week, it is pending insurance review currently. Has anyone else had to do this recently and have any advice? I'm trying my best to determine market value, but finding a bit more uncertain with a classic. For reference, I have an 89 Pioneer 4x4 long bed, regeared axels, Detroit rear end, custom bumper, lifted and recently painted in 2022.
  7. After 325K my steering is not safe anymore, I'm going with the ZJ drag link mentioned in this article. I did not see mention of the Tie Rod, is the stock OEM okay with the ZJ drag link, or is it a good idea to get both ZJ drag link and Tie Rod? Sounds like any year ZJ drag ling is compatible?
  8. After supper, put the clutch knob unit into the cup, this time, and had pressure on the clutch! Drove until warmed and shut off to retest. Started! so Think I nipped this issue of not starting after warmed. Thank you to y'all who chimed in before and recently.
  9. Okay, appreciate the reassurance, I may try a zip tie on the boot to give it a bit more staying power. Rubber is not as spry as it once was. Was thinking I should just give it a go since I've got everything cleaned and primed with oil.
  10. In uncharted territory, removed slave to fix something else. Pressure inside the unit blew the piston out the end. Problem is I don't know what should be there on the to hold the spring tension where it is covered by the boot. Looks to me there should be something, but I can't find any parts or schematics on this thing. It's from Advance Adapters, and I guess I need to buy a new unit? Hoping someone has some experience to provide some guidance if it can be fixed?
  11. CPS is replaced, took 2.5 hrs. Ended up taking off the cross member and lowering the drivetrain 2 inches to make room. Question for anyone, I removed my external slave cylinder to have room to swing the ratchet.I put it in and had no clutch pressure. When I pulled it off again the slave cylinder exploded. Is there an end cap on the end under the dust boot? Seems like there should be and I think its in the bell housing? Can anyone confirm this?
  12. AC, Hope your project is progressing, i found it is not the fuel pump installed last year. Working great, PSI checks out. However on the Cherokee forum and I think here I saw it too. If the CPS is going out, it will cut off the spark to the coil and distributor. I can start mine when cold, Ohms check out, but when the warmed , I can't restart. At least that is my guess, cause ohms when warm is zero. So replacing my Crankshaft PS and will post updates, once I find my 1/2 to 3/8 adapter.
  13. Acfortier, I'm feeling your angst. Most of what has been said started happening two days ago out of the blue. Idling while figuring out if soccer practice got cancelled, it just died. Started next day, when I went back first crank. I found same thing, let sit, starts up. Has not died while driving but today after getting gas and going to walgreens would crank but not start. I had noticed upon my first re-start the fuel pump was noticeable. When It died at the soccer field, I let pressure out of the line a couple times to make sure not a fuel pump. However, I did not recall hearing it prime again at that time. After cranking for few minutes, no fuel in the exhaust smell either which seemed odd given the number of cranks I put it through. I know there is a lot of grounds to check, which I cleaned all last year when I replace the fuel pump with the Bosch unit. I'm going to chase the fuel presser pump issue first thing I get it back home. Anyway, thanks y'all for contributing, I have my list from the article to go through.
  14. Barracuda, How'd you end up sorting this out. Looking for manual regulators and seems like everything new is electric. Little nervous 'bout pick'n up a used one with stripped worm gear, and that 'cash for clunkers' idea is really hurting finding used parts where I live.
  15. I'm doing resto work on mine, albeit slowly, Since my Renix is running good, its the last thing I plan to touch. AX 15 is a good idea, my BA10 crapped out around 204K, so needed upgrade, while its out good time to do axles. Head unit sounds cool, I'd just be concerned about fit and having to modify for a touch screen. That may be harder to undo as parts getting scarcer. Anyway, I fixed what was broke then focused on the body, even found the stock decals to keep it period correct. I've thought about buckets, but bench is more practical so kept it, for when I have to carry kids around. So like Jdog said, suit your needs.
