Pete M
Administrators
    114
Everything posted by Pete M
  1. don't give up! a lot of us have been in your shoes
  2. absolutely it's all just steel after all.
  3. just needs a bit o' steel added in. not the first, won't be the last.
  4. perfect for my april fools MJ
  5. does it shift into gears with the engine off?
  6. great choice. I love that shade of blue
  7. the older years didn't have them on the benches. eventually they decided that the back glass was a poor preventer of whiplash and included them. not sure why your 92 wouldn't have them. should have been standard by then. I will of course be hanging on to the bench for future Concours d'Elegance showings.
  8. the only time I've ever had spraying oil is from a bad oil filter (if I remember right the crimp had failed)
  9. this is so blatantly april fools laughable I can't even post this with a straight face https://www.quadratec.com/c/blog/jeep-announces-2dr-gladiator-truck?fbclid=IwAR3XRM7KNRyoXe-_eZC1g1VsW5Q3YEe_gM8X0VVyM2KpKFjItafmfRSLmeE
  10. cranking = turning over = engine is rotating after proper starter engagement ballast resistor:
  11. is it in a vehicle that you'd be buying/storing whole? or an engine block that will then be sitting on the floor in a corner of a shed for a couple years?
  12. that's going on my xmas wish list I've grown tired of listening to my throttle body whistle
  13. yup, exhaust shops can be quite affordable
  14. If that's the only thing that has changed, maybe something is wrong with inside the filter? maybe? I mean, I've heard of plenty of other parts being bad out of the box, but not a fuel filter.
  15. any chance the filter is on backwards?
  16. I'm pretty sure my lawnmower has a better carb than the stock one on a 2.8L
  17. they look fantastic
  18. WD40 isn't a rust penetrant at all. but yeah, brake fluid can work wonders on rusted bolts! just be sure to wipe it off of paint asap. (same with WD40 for that matter). I haven't used it yet, but I've heard good things about CRC freezeoff.
  19. I guess you could extend your bump stops a whole bunch. or weld a clearanced section into the corner of the tank. I've seen that done before on hotrods.
  20. car-part.com might be of help with junkyard searches be sure to flesh out your forum signature with what you have. and you should start build threads on each of your Jeeps! MJs here: https://comancheclub.com/forum/8-member-projects-your-comanches/ other cool stuff here: https://comancheclub.com/forum/40-member-projects-other-cool-stuff/
  21. do the headlights come on? is the air filter dry?
