114
Everything posted by Pete M
Suspension and Tire options
Pete M replied to CptVanGuard's topic in MJ Tech: Modification and Repairs
a front axle with drum brakes? dang that's an old one.- 26 replies
- suspension
- lift kit
(and 1 more)
Tagged with:
any luck finding time to model the tailight fixes I suggested?
89 Pioneer Project Gandalf (the Gray)
Pete M replied to jeepmjga's topic in Member Projects: Your Comanches
getting close! -
be sure to snag the VIN somehow so we can see the build date.
What transmission do i have it has no part number
Pete M replied to RyanJ1775's topic in MJ Tech: Modification and Repairs
AX-15 will be aluminum. and whomever worked on it apparently screwed something up inside. maybe missed a retainer. no such thing as a 4spd AX-15. -
I do believe the 4th digit would be an M for a Metric Ton. the 4th digit is the GVWR.
Need Help - Dashboard Replacement and Adding A/C
Pete M replied to VintageJC's topic in MJ Tech: Modification and Repairs
if you alter them in any way on a PC they should upload correctly. meaning you double bluffed it on the ones you rotated upside down because now it uploaded them correctly, but they were upside down. -
8 nuts/bolts. those are easy. it's the other things that take the most time. in a junkyard I can pull a bed in under 20 minutes. but I can cut through anything that doesn't release easy.
locked until someone provides some prices
they changes a lot of things in 91, but kept the overall feel. in 97 they did a complete redesign. apparently right down to the grille dimensions. good to know.
the 87-90 parts manual contains no mention of an MJ hitch. only a lightduty and a heavyduty for the XJ and a pintle hitch for the J series. leads me to believe that the hitch might have been like the sunroof.
might have something to do with the MT altering the GVWR and that would be in the VIN. oddly enough, the 87-90 parts manual has a slightly different order of the VIN explanation.
is there a mopar part number for the hitch?
@VintageJC out of curiosity, are you using a phone or a laptop to upload? if phone, apple or android? were all the pics taken with the phone/camera in the same orientation? -
is the thick center plate between the front half and the rear half made of steel or aluminum? hit it with a magnet real quick. -
I can't seem to find a photo from the back side, but the 2 tails of these 2 AX-15s are different. (ignore the circled peugeot) maybe early AX-15s or maybe dakota AX-15s had a different tail piece? a side photo should clear this up in a heartbeat. -
been a while since I've thought about it, but shouldn't the cap fail first?
for sale: https://www.ebay.com/itm/1988-Jeep-Comanche/224408483715?_trkparms=aid%3D1110010%26algo%3DHOMESPLICE.DISCCARDS%26ao%3D1%26asc%3D20200220090753%26meid%3D8bc64e3f6ff84f7a981f9d5019a7c565%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D324560137733%26itm%3D224408483715%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDiscOrganicBase&_trksid=p2047675.c100009.m1982
that's some messed up quality control right there.
was this an old part or a new part?
getting close!
a 110v fan. one that runs non stop so as to keep air circulating and thus prevent crap from growing on the various plastics and leathers the cab of my truck. stupid southern moisture.
