A-man930
    3
Everything posted by A-man930
  1. We have a place in St. Louis http://www.saintlouisspring.com/
  2. Wow. Lots of misinformation in this thread. In short, something likely happened during the install or you've had some kind of catastrophic failure (i.e. main bearing). Do some research (from a trusted resource) on multi-grade oils and viscosities.
  3. Bummer, I've always wanted a set of the browndog mounts :cry: That being said, I don't know what my threshold of "vibration annoyance" really is. I've already got the less than ideal poly trans mount and stock rubber engine mounts combo and I survive...
  4. This is a new one for me... why did you install the pump in the first place?
  5. This is not listed on their website... Very, very intrigued :popcorn:
  6. And we also need to see detailed pictures of the exhaust.
  7. See, I'm a sucker for wiring projects. And I want wideband control and LS coil packs :yes:
  8. Alright so You've got me intrigued... How exactly does a C5 Corvette T56 fit itself between a 5.3 and a transfer case...
  9. Bitchin' I'm likely to MegaSquirt my Renix 4.0 at some point.
  10. Looks good. Any better pics of the front bumper?
  11. I've got the control arm drop kit on mine. Can't complain.
  12. This is quite interesting. I'm with Eagle; sounds like the high-flow water pump is of little benefit if you just end up choking it with a restricter...
  13. I've been toying with disassembling my starter (full of mud). Glad I found this thread.
  14. I love that in-depth article!
  15. I have had Herculiner only on mine for almost 6 years now and I don't ever regret it. Sure, it's hot in the summer, but it's not THAT hot. It isn't the easiest to keep pretty (takes soap and water w a bristle brush to really clean it), and I did have to touch up where my heels sit for the clutch and brake pedals. I would do it again.
  16. This is exciting. Glad somebody is doing this
  17. I hear ya there. I, for one, appreciate a project with little details like this. Keep on overcomplicatin!
  18. Gotcha. I was going to try and squirt some brake clean through it with the valve out.
  19. 2 more questions: -does anybody know if the seals in the MJ valve are replaceable and where to get them? -And again on the MJ valve, was there not a concern that the emergency bypass ports aren't drilled correctly? I thought I remember one of the cutaways showing an incomplete passage...
  20. You can crank the engine while you're racing and use it like a cheater NOS set up , kill 2 birds with one stone
  21. Got it. I'm pretty well sold on retaining the stock MJ dist. block if for no other reason than to keep a brake warning light, but I might even entertain retaining the emergency bypass circuit feature... Any reason not to do this? I do have an adjustable prop. valve like this one waiting for the overhaul. The stock block, the adj. proportioning valve, and a 10psi residual pressure valve in the primary line to the rear should aside from the automatic adjust-ability of the height sensing valve be an upgrade, no?
  22. Back from the dead! I've added some labels; do I understand the factory MJ distribution block correctly?
