3
Everything posted by A-man930
Parking brake pedal refurb.
A-man930 replied to A-man930's topic in MJ Tech: DIY Projects and Write-Ups
Shoot. If your teeth are in reasonable condition I would recommend Cruiser's method before going crazy like I did! I guess your results were good?! -
1991 short bed metric ton DD build
A-man930 replied to mikekaz1's topic in Member Projects: Your Comanches
Who is the push bumper from? -
Here's the other threads I have read: ftpiercecracker1 had this one http://comancheclub.com/topic/34536-diy-e-brake-fix/ cruiser54 your pictures are down and we never got a verdict... http://comancheclub.com/topic/47303-new-parking-brake-fix/ -
Here's another version of the fix: http://comancheclub.com/topic/48483-parking-brake-pedal-fix-unverified/
My primary issue was the pedal having a bunch of lateral play that caused poor teeth engagement with the pawl; and it had been happening for a while (hence the uneven wear that I had to correct). Simply changing how hard the pawl teeth bit into the pedal teeth would have been a band-aid at best in my case. This should be a permanent fix so long as the stud stays put in those lousy threads I tapped. -
Spring tension wasn't an issue on mine. Your repair is what inspired me to go after mine! -
Almost ready to try it out! -
Parking brake pedal pad and bumper
A-man930 replied to A-man930's topic in MJ Tech: Modification and Repairs
I called the local cjdr dealer and they told me the numbers have been discontinued... Looks like its trial and error time! -
I'd like to find an actual, confirmed replacement for the pedal pad and the rubber "stop" piece that keeps the pedal from smacking metal to metal when you release the brake. Any thoughts?
Did you ever have any luck with the bulbs behind the temp controls?
I love seeing people DOING things with our trucks. Keep it up!
Been making progress on the spring refurb and am midway through fixing my parking brake pedal. Check it out! http://comancheclub.com/topic/48483-parking-brake-pedal-fix-unverified/
I'll be looking into this. I'm really afraid of having this lift put me too high in the rear.
- 59 replies
- leaf spring
- bushing
(and 2 more)
Tagged with:
The rust had to go... -
The plate that holds the pawl and release cable came off next; Made a replacement for the smaller rivet removed earlier. Enlarge the hole a wee bit and she just fits in there; -
I then enlarged the hole in the "top plate" piece and a 5/16" fender washer to accept the 3/8" stud; -
Next I drilled the stud to 21/64" in preparation for a 3/8" x 24 tap. Note: do this with a drill press if you have one; by hand it was a bit sketchy especially at the last step where I must have wobbled around too much and made the hole juuuuust a bit oversize. The tap process went real crappily and i really thought about going one size up for the stud, but I don't think there's enough material left for reliable results. It'll get lots of red loctite! -
Next, I cut down the top side of the big rivet down a bit past the original surface. The goal here is to get a nice and flat surface to work with that is slightly shorter than the original setup. Next I marked the center and center punched it; -
By the looks of the teeth on the pedal side I figure that the pawl must be grabbing only the inside edge. I took my chances and decided to attempt "sharpening" them up with a file (not very effective) and a really thin wheel on a dremel... Should work fine :crossfingers: -
After over 5 years without a parking brake I finally bit the bullet and pulled the pedal assembly out in an attempt to fix it. I'm not the first guy to document fixing one of these but I took a little different approach and wanted to share my method and progress with y'all. I didn't take any pictures of the slop the pedal had in it before, but you could shift the pedal left to right with your toe and it would release at random... no bueno for a parking brake! I had to remove the fuse block to get to the bolt at the top right of the pedal; on top of that the nut (welded to the body under the fender) broke free and I had to call in some reinforcements to help get it out. Once the drama was over I hosed the whole thing off with some brake clean and ground these two rivet heads off; http://i.imgur.com/BjcivcJh.jpg?1 http://i.imgur.com/hulgBwoh.jpg?1 After these two are free all the individual pieces can be separated and inspected; http://i.imgur.com/1C2xh2mh.jpg http://i.imgur.com/EaVeRmch.jpg http://i.imgur.com/7TpxgUxh.jpg
Diesel (TDi) conversion discussion & research
300 lb/ft and a bunch of weight dropped off the front axle. Sounds like a winner to me! -
http://gastodiesel.tdconversions.com/
