A-man930
    3
Everything posted by A-man930
  1. Nice build dude.
  2. It's SOA time! http://i.imgur.com/vXf6L0Gh.jpg http://i.imgur.com/p0ymehbh.jpg http://i.imgur.com/p6adTEzh.jpg
  3. I ended up buying a stick of this stuff from mcmaster carr for the rebound clips. Time will tell if its hard enough, but it won't rust!
  4. Well I had a crappy time with the sandblaster, forgot to apply the primer, and decided to just slop the stuff all over them instead... but they're done! Hopefully the stuff holds up.
  5. We're kindred spirits with the wiring mate. Excellent build.
  6. Are these upgrade parts or factory? Seems like the TDi crowd likes to smoke clutches.
  7. It'll be in a WK not a WJ, but yes an entire powertrain swap would be your most realistic bet. I just wonder how difficult it will be to fool the theft deterrent... The CDI (engine controller) will no doubt need to communicate with the instrument cluster, ignition switch, etc. and who knows if anybody out there fools with the software on that... I can't recall how wide the engine is; its a weirdo 72* design so height might be more of an issue than the width.
  8. That's an OM642 iirc. Not sure how many have tried to swap one of those. The computer side of that might be the toughest part...
  9. Well I'll be doing this. Good writeup!
  10. I agree. SOMEBODY needs to make these available. Perhaps even re-styled to mimic the 97-up XJ tails...
  11. How much are the OEM ones going for?
  12. -I was just looking to see if the bushing that comes in the Ford kit the OP tried happens to fit our spring eye. -I'm not too convinced this Express/Savanna shackle isn't the one you're thinking of. No dimensions on Dorman's website, I'm waiting on an email back from them. I found the Automan listing on ebay first which led me to check and see who else offered a replacement shackle for the Express/Savanna; hence the Dorman # FWIW I can't say I've had too much trouble with "Dorman junk" over the years. In my general experience Dorman hard parts are more often a "hit" than a "miss"...
  13. Could be. Apparently they're a truck parts company. I'm gonna order both and see which ones are sturdier (if they're any different at all).
  14. I'd like to throw another candidate in the mix; Dorman 722-006 They're listed for 1/2 ton Chevy Express or GMC Savanna vans and they appear to be a tad bit narrower on the spring eye side and even closer to our stock 4 3/8" length. I've found ones made by Automan on ebay too. Pending a confirmation on the dimensions I'll probably be buying the Dorman ones via NAPA since I get a discount there, but the Automan ones on ebay look like a good deal!
  15. I've got my seat bottoms switched L-R. The only thing that is on the wrong side is the little elastic loop that holds the seat belt buckle. And as I'm typing this I'm realizing that you're also wanting to switch the seat backs... Well yea then the recline and "fold forward" lever would be switched.
  16. This stuff is where its at; super handy for all kinds of things in the garage. I keep it in the beer fridge. Get plastic from whatever suits your fancy
  17. Intewesting...
  18. So that's three of us. Shweet! I guess I still don't see where evguy's left engine-side mounts attach to the block, and weather or not Jetta ALH accessories will have to be moved at all. His black XJ on the website uses a BEW (pd) engine so I'm guessing the accessory drive is totally different?? johnj92131 are pictures of your 1Z in a Passat gonna be of any use to me? If only I were a VW guy maybe I'd know some of this, lol.
  19. johnj92131 what does your accessory drive look like compared to an ALH? I'm REALLY wanting to leave it all stock but it seems like everybody struggles with it. Especially the ac
  20. Knock on wood I've been running around with an internal slave setup since I've owned the truck (almost 8 years) and haven't had anything besides a master cyl. fail. Granted its only been pushing on a stock pressure plate but still its not quite the ticking time bomb like everyone would like you to think. My $.02:Just keep fresh-ish fluid in there and save your money
  21. Why the ScanGauge2? Why not just get the factory Jeep senders into the TDi somehow? Might have to get creative with the tach, but the oil, coolant, and volts should be as easy as some thread adapters.
