Xdt
776 profile views
Xdt's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. All, Thank you for the replies, it appears that I will have a full weekend. I will inspect all components as mentioned and let you guys know what I find. Once again it's time to convince the wife that I am saving us money by Investing money in the Jeep. Stay tuned.....
  2. I have replaced both upper and lower control arms with moog replacements. However, I will inspect. Sometimes new parts can be defective. I have not replaced calipers or ball joints. So before I throw more money at the problem, I will inspect hubs and control arms. Keep the suggestions coming. Thanks again
  3. I forgot to mention the Rear brake shoes and drums have been replaced. I will investigate the hubs, thanks for the replies.
  4. Guys, I have an 87 4.0 5 speed 4wd. When I apply brakes the front right side of the truck vibrates. I replaced the rotors and pads and problem remains. There are times while braking at speeds above 50mph I can feel vibration in the shifter. However the steering wheel feels fine. I took the truck to NTB for an evaluation but they could not find root cause. It appears that the problem could be in the drive train but I am not sure. Please provide suggestion if you have experienced similar problems. Thank you
  5. Eagle, Thanks for the reply. I will go by Safelite for a quote.
  6. Guys, I found a puddle of water at the rear of tha cab. Removed plastic trim poured water around where the outer glass mounding touches the outside cab and splashed water onto the face of the glass itself (to check the small out there weatherstripping that appears to keep glass in place. Basically water leaks at the molding and weatherstripping. My questions are: 1) since my glass is in great shape does anyone sell a gasket/weatherstripping kit? 2) If no one sells a kit has anyone used a glass shop to remove/ reuse sliding glass, replace stripping, gaskets/ molding? 3) Is it best to buy aftermarket glass which has the gasket and stripping for shop to install. Thank you
  7. I found the OEM as described above for a Cherokee for $65 on eBay.
  8. Just placed order, thanks guys for your help.
  9. Hornbrod Thanks for the info, I will start a google search for an engine splash shield for XJs
  10. Ok the factory skid plate is what I am looking. I will look for an XJ in salvage yards. Just thought there was a manufacture that made a replacement.
  11. Hello, Does anyone know where to purchase the front under panel for a MJ?. I do not do any serious off-roading however just want to protect the alternator and keep debis from entering engine bay. Thank
  12. Guys, the filter in question goes inside of an opening on the top of the transmission. Once I removed the center console the opening is to the right of the gear shifter. Thanks again for the help.
  13. Guys Thank you for the replies. As stated one of the hoses connect to the transmission. The hose in the link has a filter attached. Does this filter just vent to air? The hose isn't long enough to reach transfer case. The hose is 3/8 Thanks again
  14. Hello, Currently replacing clutch slave cylinder and notice two vent lines. One of the lines attach to the rear of the transmission please identify the second hose/filter and where to connect. Thank you
