NickS
    Columbia, SC
1650 profile views
NickS's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Not necessarily... Flare nuts on front are rusty, passenger is completely rounded, driver is on its way. I am in process of installing a lift, so I need extended soft lines. Instead of dealing with the flare nuts I decided it might be easier to run new lines. Figured id do rear at the same time. I'm not a very experienced mechanic but I just can't help but think these 36 year old brake lines could use replacing.
  2. @cruiser54 Is it possible for you to post pictures of your setup? I am looking at upgrading my booster to a WJ dual diaphragm and while I'm doing that I figured id remove the load sensing valve and run new front/rear brake lines. Sounds like I should remove the MJ prop valve while I'm at it.
  3. Beautiful truck! The mirrors are interesting. What was done to fill the holes from existing SporTruck mirrors?
  4. I really like that bumper. Can't wait to see it painted!
  5. Look forward to seeing more videos!
  6. Ended up buying some I found on the book of faces.
  7. PM Sent
  8. Looking for rear speaker brackets for my 88 SporTruck. Located in Columbia, SC but I don't think they would be expensive to ship.
  9. NickS
    1JTMP6314JT018018
    1988 Base 4.0L 4wd Got it from TN (originally sold from Sherwood in Johnson City?) in May 2018. Now in Columbia, SC.
  10. I have the same issue and I am scared to try this Edit: Hello from Columbia!
  11. So you are saying that airdams normally serve a purpose but in Comanches it doesn't do much?
  12. I'm either going to attempt to straighten mine out with a heat gun or just not put it back on and trim the very bottom piece of fender flare so it doesn't look like something is missing. Decisions decisions... If I fail at straightening it and decide I still want one I may be interested HOrnbrod.
  13. Thanks! I'll see if I can find something online. Do you know if it is supposed to be straight/flat?
  14. What the hell is the plastic trim piece underneath the front bumper called? I tried to get one from a Cherokee at pull a part but they were all already taken. Mine is all wonky so I wanted to replace it. Are they supposed to be flat or have some curve to them? Thanks!
