kook911
    DFW TX
2144 profile views
kook911's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. If you ever need the code there is a Reddit form for rockauto where people post their codes to be used.
  2. It might be worth a shot to throw the question and script in Chat or Gemini and see if either one can fix the problem.
  3. kook911
    scaled down MJs
    https://makerworld.com/en/models/1507489-jeep-comanche-tailgate-key-hanger#profileId-1577841
  4. kook911
    scaled down MJs
    I really like this one and it can be configured to hold 6 keys. The user name, TDI_Manche shows he was once a member here but hasn't been on since 2022. But big props to him for making this
  5. kook911
    scaled down MJs
    Check out a site called yeggi.com and search for Jeep Comanche. There are a ton of different models for our trucks but you have to have a 3D printer. Most libraries have them to use if you don’t have one.
  6. Never knew people buy rock auto magnets.
  7. You got any pics of the classic cowl hoods? Would like to see before I commit to one.
  8. I printed these in black and they came out wonderful. I also have the gray color that matches the Jeep interior. https://www.printables.com/model/842931-jeep-cherokee-xj-2door-seat-lock-trim
  9. I'm going to have to go rent the equipment again from the parts store. I’m assuming that they were open due to them holding vac but I could be wrong.
  10. Update and even more problems. Did the switch and pulled vacuum on the system. Held at 27 mg for an hour. Then when I went to put the r134a into the system I could not get the system to charge. I made sure that I had power going to the compressor plug and got 12v. Then check the low pressure switch and got 11v. I jumped the low pressure switch just to make sure the compressor actually works and it kicked on with the low pressure switch jumped. So I went out and bought a new low pressure switch and still can’t get the system to charge. So I don’t know what’s wrong and I’m about to just pay a shop to get this ac working.
  11. I believe this is the hose you wanted as I just replaced both hoses that were attached to the condenser. All four ac hoses can still be ordered and I included the other part number for the ac hose that attaches to the condenser. UAC HA 111291C A/C Refrigerant Liquid Hose UAC HA 10051C A/C Refrigerant Discharge Hose
  12. One valve spring sits on the drier side and the other sits in the hose. The flat face brass faces each other. This hose is connects to the expansion valve on the left side. If needed I can take them out as I haven’t put any 134a into the system, but right now they are in the lines. Thanks for helping with the gray lines. Hook up and good to go.
  13. I am replacing all the parts except for the evaporator core and the hoses attached to the expansion valve. My question concerns the two spring parts located on one of the hoses and the drier. Some forums suggest these parts are unnecessary, while others say they are essential. Are these parts needed, or are they obsolete for the R12 system? Additionally, I have a gray plastic hose coming out above the expansion valve that is capped on my truck (highlighted yellow). What is this hose for, and do I need it for the AC to function properly?
  14. Can someone take and post a pic of how the cable is supposed to attach to the clip. I knocked my cable out and can’t figure out how to attach it back. All the photos on google look like they were taken by a potato and none of them are clear. The pic I am posting is showing what I need.
