TheSiLvAPython
1 Follower
    Pierce county WA
657 profile views
TheSiLvAPython's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Dang, okay thank you. Yeah I have a dana 35 I forgot to mention that. Sucks that 3.07s cost way more than some other ratios.
  2. My truck came with 3.07 gears in the rear axle, can I buy a new ring and pinion that is 3.55s and install without issues or do I need a new carrier?
  3. Thanks for the heads up,. Wait the raidiator core is welded in? The "core", is that the main support holding the radiator in place? It's not the radiator itself welded in right?
  4. I just read that thread, answered many questions and i see the firewall diffences without the engines in the way. Thanks for sharing.
  5. Could I use a later model hood and front end?
  6. I know the firewall is said to be different in 1986 compared to 87+ because the 4.0 wasn't an option/made yet(although yes amc had other inline 6 engine, but the 4.0 itself wasnt manufactured/put into the jeeps until 87. I have had my 89 side by side with an 86 and the firewalls looked IDENTICAL. I didn't measure it or anything but i was curious if anyone has ever done the swap. I believe somewhere on here I read that it can be done with some persuasive hammer massaging to the firewall but I have searched the internet and comanche club and can't seem to find any info on whether or not anyone has successfully done the swap.
  7. Thank you. Been wondering this for quite some time. Need to put a new ring and pinion in mine. I know the spider gears and axle shafts are different because I purchased the wrong spider gears once. I'm guessing the drum brakes are different too? But everything else is the same for sure?
  8. Are the ring and pinion gears the same for non c clip and c clip axles? And are the interchangeable?
  9. Still looking for black b pillars?
  10. Did you ever get the ECU?
  11. okay yeah that would be great.
  12. I am in puyallup area. I would also like to convert to 4wd. I was just talking to my uncle about doing a conversion and he said it isnt hard i just need the axle and a 4×4 transmission.
  13. i do not have an answer for this but a question, would you consider parting with one of those ax15s?
  14. much more is missing from this truck now. these are old pictures.
  15. you're in luck(with the shift linkage because yes it is from a manual MJ) there is a few manual Cherokees there as well. I know one is after Chrystler switched from the threaded clutch master cylinder to the(I believe plastic) O ring press fit style hydraulic line. I think there are four manuals ONE MJ THREE XJ and then there is four automatics 1 MJ 3 XJ hey that's not bad (not sure how far along the rot of your sheet metal is) but 900 is a steel.. haha. I think they are one of those (get it while you can) things.. odd I think I have read that exact sentance on this website before. hows the humidity out there in Virginia/Georgia? is it bad? like, get out of the shower and never dry off bad? I never even knew what a comanche was until 2014. Randomly saw one drive by and ever since I have wanted to get one. Finally got one and I didn't use any logic at all when I got it. I seen it, seen that it ran, talked the guy down to 1500. (now with what I know I probably could have gotten it for less) but I was starstruck haha the previous owner kept trying to warn me I probably shouldn't daily drive it because it needs work and all I did was nod my head and say whatever it is I will fix it.(having no experience working on vehicles other than basic oil change, brake pads, spark plugs, upper control arms all on an acura.) then I got this truck 5speed manual which I have never owned a manual. (can never go back to an automatic now) yeah I too just wish I knew then what I barely know now. I love this truck but damn I had no idea what I was getting into haha. really thankful I found this website though. first thing I read was the "Tips every MJ owner should know" thread and immediately I started over thinking and the found (the man, the myth, the legend) Cruiser54's mostly renix tips and one thing led to another and now I'm addicted to working on my truck... If I'm not working on the Job, I'm working on my truck..... my bad I got carried away.. hows it in spokane? I have wanted to go drive out that way but just been so limited by my Jeep(how often do you hear that haha) its only 287 miles from where I live. I drive more miles than that on an average worknite( I do deliveries) but I have also had to have my truck towed three times so I would like to get all of the surprises taken care of so then I am not a huge distance from home with a truck that needs to be towed that I can't afford. although it is better now that I replaced the dash harness and fuseblock as a result of a power to ground short circuit that melted everything from the fuse block to the tail lights. but now I am going to need to rebuild my transmission soon. Have you heard of/been to palouse falls? thats out that way. that is where I want to go. sorry i really got carried away digitally rambling.
