Everything posted by NickS
Not necessarily... Flare nuts on front are rusty, passenger is completely rounded, driver is on its way. I am in process of installing a lift, so I need extended soft lines. Instead of dealing with the flare nuts I decided it might be easier to run new lines. Figured id do rear at the same time. I'm not a very experienced mechanic but I just can't help but think these 36 year old brake lines could use replacing.
@cruiser54 Is it possible for you to post pictures of your setup? I am looking at upgrading my booster to a WJ dual diaphragm and while I'm doing that I figured id remove the load sensing valve and run new front/rear brake lines. Sounds like I should remove the MJ prop valve while I'm at it.
August 2020-CoastChief’s 1988-White Rabbit
NickS replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Beautiful truck! The mirrors are interesting. What was done to fill the holes from existing SporTruck mirrors? -
Dirtbound manta Ray rear bumper.
NickS replied to kook911's topic in MJ Tech: Modification and Repairs
I really like that bumper. Can't wait to see it painted! -
1987 Jeep Comanche Restoration Project (YouTube Series)
NickS replied to NEO auto's topic in Member Projects: Your Comanches
Look forward to seeing more videos! -
Upgraded Battery Cables!
NickS replied to MeanLemons's topic in Vendors- members making products for MJs
Email sent as well! -
Ended up buying some I found on the book of faces.
Looking for rear speaker brackets for my 88 SporTruck. Located in Columbia, SC but I don't think they would be expensive to ship.
1988 Base 4.0L 4wd Got it from TN (originally sold from Sherwood in Johnson City?) in May 2018. Now in Columbia, SC.
I have the same issue and I am scared to try this Edit: Hello from Columbia!
So you are saying that airdams normally serve a purpose but in Comanches it doesn't do much?
I'm either going to attempt to straighten mine out with a heat gun or just not put it back on and trim the very bottom piece of fender flare so it doesn't look like something is missing. Decisions decisions... If I fail at straightening it and decide I still want one I may be interested HOrnbrod.
Thanks! I'll see if I can find something online. Do you know if it is supposed to be straight/flat?
What the hell is the plastic trim piece underneath the front bumper called? I tried to get one from a Cherokee at pull a part but they were all already taken. Mine is all wonky so I wanted to replace it. Are they supposed to be flat or have some curve to them? Thanks!
Looks much better with that blue gone
3" Lift kit w/o Add a leaf
NickS replied to Chief Falling Rock's topic in MJ Tech: Modification and Repairs
I was eyeing hell creek springs but this has me worried. Do you have the link to the original post? Was there any follow up? -
Looks neat man. Hope to see you riding around town with it!
I'm jealous all your interior work. Did you replace the floor pans? Also that paint looks good man, did you do it yourself?
Headlight Adjustment Screws?
NickS replied to Zenobian_84's topic in MJ Tech: Modification and Repairs
Awesome. I appreciate the help. -
Thanks! Will those work for an 88? Says 91-01. -
Anyone know where these can still be found? One of my headlights keep falling down.
