2
Bonkers's Achievements
Comanche Addict (5/11)
Bonkers changed their profile photo
Ive been reading through the old posts and there are a couple of questions i now have about this kit before i buy it. On several pre-2018 threads it says the 210 kit do not fit the 15" Turbines. They also say the backing plates and brake cables provided do not work with the Mj setup. And lastly, that the Kits are Teraflex patented brand and that there are no options for buying Rotors or Pads except from them. Has any of this changed since then? I can't imagine it would come with these issues and still be for sale 6+ years later. My Gracie is a simple driving truck, no real mods, i was just hoping for a one- size-fits-all solution to my never-ending drum brake nightmare...
Purchased this as a parts truck in October of 2016 to pull the HO for a swap into my other Mj. After investigation I decided it was not worth the effort and sold it to a gentle- man from PA to turn into a buggy. Had about 225,000 when it finally left.
After many years of searching i accidentally ran into Gracie again at a gas station. I gave the new owner my contact information and after a couple of months he reached out looking to sell. I picked her up from Kennett Square Pennsylvania on August 22, 2014 with 174,370 showing on the dash which should be the corrected mileage. She is currently at home in Georgetown Delaware and slowly... very slowly... being rebuilt back to mostly stock condition and as of this post has 181,432 on the dash. Current Repairs: (Battery) - Economy - 58RV - 06/04/2023 (Oil) - Mobil 1 Oil 10w-30 - 10/31/2022 (Repair) - Dorman 23.5g Fuel Tank - 576-660 - 10/20/2021 (Repair) - Dorman Fuel Tank Vent Valve - 911-060 - 10/20/2021 (Repair) - Duralast Fuel Filter - FF676DL - 10/20/2021 (Repair) - Fairchild Fuel Tank Vent Valve Gasket - F4111 - 10/20/2021 (Repair) - Goodmark Fuel Tank Strap Hook - GMK2111749681 - 10/20/2021 (Repair) - Spectra Premium Fuel Tank Strap Kit - ST117 - 10/20/2021 (Upgrade) - MTS Fuel Sender - JPSU-6P4.0 - 10/20/2021 (Oil) - Mobil1 Oil 10w-30 - 02/17/2021 (Oil) - WIX Oil Filter - 51626 - 02/17/2021 (Repair) - Crown Ballast Resistor - 33ddd682 - 02/17/2021 (Repair) - Map Sensor Bypass - 02/17/2021 (Repair) - Fel-Pro Throttle Body Gasket - 60742 - 01/16/2021 (Repair) - Walker CPS - 235-1096 - 01/16/2021 (Used) - OEM Throttle Body - 01/16/2021 (Used) - Tailgate Handle - 07/01/2019 (Repair) - Sylvania LED Bulbs - 1157 - 06/17/2019 (Upgrade) - JPN Wj LCAs - SCARK640773 (2x) - 05/18/2019 (Oil) - Mobil1 Oil - 10w-30 - 03/17/2019 (Oil) - WIX Oil Filter - 51626 - 03/17/2019 (Repair) - Dorman Headlight Adjusting Screws - 42185 - 02/25/2019 (Repair) - Dorman Headlight Adjusting Screws - 42185 - 02/25/2019 (Repair) - Crown Auto Header Panel - 83506616 - 02/10/2019 (Repair) - Crown Auto Accelerator Cable - 53005201 - 02/01/2019 (Repair) - AIP Elec TPS - TPS258 - 12/24/2018 (Repair) - Mopar Clutch/Master Cylinder - 52104110 - 10/21/2017 (Repair) - Mopar CPS - 33004761 - 10/21/2017 (Upgrade) - Warn Trans4mer Winch Carrier - PN29394 - 11/01/2016 (Upgrade) - Warn Trans4mer Grille Guard - PN39563 - 09/19/2016 (Upgrade) - Warn Trans4mer Grille Guard - PN39637 - 09/19/2016 (Used) - Rear Bumper - 09/10/2016 (Upgrade) - Scarborough Custom Hitch - 08/07/2016 (Labor) - Driveshaft Shortened 2.25in - 12/05/2015 (Repair) - ACDelco Pro U-Joint Clamp Kit - 45U0504 - 12/05/2015 (Repair) - ACDelco Pro U-Joint Clamp Kit - 45U0504 - 12/05/2015 (Repair) - LuK Clutch Kit - 05-901 - 11/01/2015 (Repair) - LuK Flywheel - LFW194 - 11/01/2015 (Repair) - Omix-Ada Clutch Fork - 16914.07 - 11/01/2015 (Repair) - Omix-Ada Pilot Bushing - 16910.04 - 11/01/2015 (Repair) - Sachs Clutch Master/Slave Assembly - SPH011 - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Used) - Ax-15 Transmission - 11/01/2015 (Used) - LWB Roll Bar and Brackets - 06/26/2015 (Repair) - Omni Hub Assembly - PBR930049 - 05/15/2015 (Oil) - Mobil1 Filter - M1-207 - 03/21/2015 (Oil) - Mobil1 Oil - 10w-30 - 03/21/2015 (Repair) - RainX - Latitude 18" (x2) - 03/21/2015 (Repair) - Depo - Foglights - 03/1/2015 (Tires) - Goodyear Duratracs - 235/75/15 - 03/1/2015 (Used) - Replacement Rear Window - 11/01/2014 (Used) - Used Bumper Brackets - 11/01/2014 (Repair) - Standard IAC Valve - AC12 - 10/10/2014 (Used) - Window Regulator - 10/10/2014 (Repair) - Crown Auto Hood Prop Rod Holder - 55027404 - 09/14/2014 (Repair) - Crown Auto Parking Lens Screw Set - 6034204 - 09/14/2014 (Repair) - Crown Auto Radiator Grille [Black] - 55013145 - 09/14/2014 (Repair) - Door Panel 13-PC Fastener Set - 34201681 - 09/14/2014 (Repair) - Evan-Fischer FLH Bumper Bracket - EVA18072015354 - 09/14/2014 (Repair) - Evan-Fischer FLH Bumper End - EVA17172010446 - 09/14/2014 (Repair) - Evan-Fischer FRH Bumper Bracket - EVA18072010428 - 09/14/2014 (Repair) - Evan-Fischer FRH Bumper End - EVA17172010445 - 09/14/2014 (Repair) - Evan-Fischer Radiator Fan - EVA24572042267 - 09/14/2014 (Repair) - Front Bumper Face Bar - CH1002169 - 09/14/2014 (Repair) - Omix-Ada Bumper Guard - 12035.34 - 09/14/2014 (Repair) - Omix-Ada Bumper Guard - 12035.35 - 09/14/2014 (Repair) - Omix-Ada Headlight Bezel - 12419.09 - 09/14/2014 (Repair) - Omix-Ada Headlight Bezel - 12419.10 - 09/14/2014 (Repair) - Omix-Ada Serpentine Belt - 17111.04 - 09/14/2014 (Repair) - Side Marker Screw Set - 34201406 - 09/14/2014 (Repair) - Sun Visor Clip Set - DF49JS1 - 09/14/2014 (Repair) - White Knight Bulge Acorn Lug Nut - 1704S-20AM - 09/14/2014 (Used) - OEM Gas Tank Skid Plate - 09/14/2014
1988 Base LWB 4x4 4.0 - I am the current owner (again.) I named her Gracie. I bought Gracie from a Chrysler Dealership in Bridgeville Delaware on January 22, 1999 with 113,555 on the odometer. I was told she was a trade in from a gentleman from Philadelphia. Due to hardship i was forced to trade her in to a Dealership in Townsend Delaware for a work truck. I immeditately regretted it. On December 03, 2000 the use of Amsoil caused the motor to blow up which resulted in a full motor rebuild. During that time i replaced the faulty odometer with a replacement full cluster. It changed the odometer from 138,715 to 117,645. At the time of sale she had a showing mileage reading of 131,732 or 152,802 (adjusted.) The repairs done during this ownership period were: (Oil) - Mobil 1 Oil 10w-30 - 09/17/2003 (Oil) - Mobil1 Filter M1-207 - 09/17/2003 (Repair) - Mopar Headlamp - L00H6054 - 09/17/2003 (Used) - AX15 Transmission - 06/4/2003 (Oil) - Mobil 1 Oil 10w-30 - 05/31/2003 (Oil) - Mobil1 Filter M1-207 - 05/31/2003 (Oil) - Mobil 1 Oil 10w-30 - 05/19/2003 (Oil) - Mobil1 Filter M1-207 - 05/19/2003 (Used) - Steering Wheel - 02/19/2003 (Labor) - Manual Transmission Service - GL5 - 01/12/2003 (Oil) - SuperFlo Oil 05w-30 (Jiffy Lube Lewes, DE) - 01/12/2003 (Oil) - SuperFlo Oil 05w-30 (Jiffy Lube Lewes, DE) - 10/27/2002 (Repair) - Excel Alternator - 7902 - 10/5/2002 (Labor) - Turn Signal Repair - 09/20/2002 (Used) - Seat Belt - 09/19/2002 (Used) - Side Mirror - 09/19/2002 (Used) - OEM AM/FM Cassette Radio - 08/19/2002 (Repair) - Anco Wiper Blade - U-18R - 08/18/2002 (Repair) - Anco Wiper Blade - U-22R - 08/18/2002 (Upgrade) - ARB Snorkel Install - 08/14/2002 (Battery) - Astrolite Battery - 58-60 - 08/13/2002 (Repair) - AMGauge Hose Clamps - 10 (2x) - 08/13/2002 (Repair) - AMGauge Hose Clamps - 32 (2x) - 08/13/2002 (Repair) - AMGauge Muffler Clamps - 225 (2x) - 08/13/2002 (Repair) - Walker Catalytic Converter - 15634 - 08/13/2002 (Repair) - Walker Front Pipe - 44320 - 08/13/2002 (Repair) - Walker Gasket - 31362 - 08/13/2002 (Repair) - Walker Gasket - 31519 - 08/13/2002 (Repair) - Walker SoundFX Muffler - 18113 - 08/13/2002 (Repair) - Walker Tail Pipe - 47605 - 08/13/2002 (Upgrade) - 8-Ball Shift Knob - 08/13/2002 (Repair) - A1 Cardone Brake Booster - 50-4071 - 07/26/2002 (Labor) - Front Bumper Removal - 05/01/2002 (Labor) - Oil Change - 05/01/2002 (Labor) - Slave Cylinder - 05/01/2002 (Labor) - Steering Wheel Removal - 05/01/2002 (Labor) - Turn Signal Repair - 05/01/2002 (Oil) - Kendall Oil 10w30 (Jiffy Lube Lewes, DE) - 05/01/2002 (Oil) - NAPA Proline Oil Filter - SFI21626 - 05/01/2002 (Repair) - Dorman Clutch Master - 39645 - 05/01/2002 (Repair) - Dorman Clutch Slave - 37916 - 05/01/2002 (Repair) - NAPA Turn Signal Socket - LS6447 (2x) - 05/01/2002 (Repair) - Sosmetal Drain Plug Gasket - 323224 - 05/01/2002 (Repair) - Sylvania Bulb - 1157 (2x) - 05/01/2002 (Repair) - Sylvania Bulb - 1157NA (2x) - 05/01/2002 (Repair) - Autolite Spark Plugs - 3924 (6x) - 04/08/2002 (Repair) - Champion Plug Wires - 780409 - 04/08/2002 (Repair) - Fram Air Fliter - CA3901 - 04/08/2002 (Repair) - Standard Distributor Cap - FD169 - 04/08/2002 (Repair) - Standard Distributor Rotor - FD308 - 04/08/2002 (Labor) - Motor Rebuild - 12/15/2000 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 11/12/2000 (Oil) - Fram Oil Filter - PH3985 (Jiffy Lube Lewes, DE) - 11/12/2000 (Labor) - Engine Flush - 07/03/2000 (Repair) - Sylvania Headlamp - H6054 - 05/16/2000 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 04/20/2000 (Oil) - Fram Oil Filter - PH3985 (Jiffy Lube Lewes, DE) - 04/20/2000 (Labor) - Rear Differential Service - GL7 (Jiffy Lube Lewes, DE) - 12/7/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 12/7/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 10/22/1999 (Tires) - Alignment - 10/15/1999 (Tires) - Bridgestone Dueler APT - 225/60R16 (4x) - 10/15/1999 (Tires) - Tire Install Z - Sears Dover Mall - 10/15/1999 (Upgrade) - JCW 8-Ball Shift Knob - 81DN7445B - 09/09/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 08/31/1999 (Brakes) - Brake Adjustment - 08/25/1999 (Brakes) - Front Brakes - 08/25/1999 (Labor) - Serpentine Belt - 07/07/1999 (Repair) - Serpentine Belt - 07/07/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 06/22/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 04/27/1999 (Repair) - Fuel Filter - 3/18/1999 (Repair) - Mopar PVC Tube - 4762592 - 03/18/1999 (Repair) - Mopar Vacuum Harness - 053004838 - 03/12/1999 (Repair) - Mopar Vacuum Harness - 053004868 - 03/12/1999 (Oil) - API Oil 10w-30 (Jiffy Lube Lewes, DE) - 03/04/1999 (Repair) - Autolite Spark Plugs - 3924 (6x) - 02/04/1999 (Repair) - GE Bulb - 2057NA - 02/04/1999 (Repair) - Standard Distributor Cap - FD169 - 02/04/1999 (Repair) - Standard Distributor Rotor - FD308 - 02/04/1999 (Oil) - Amsoil Oil - 10w-30 (Jiffy Lube Lewes, DE) - 01/28/1999 (Oil) - Fram Oil Filter - PH3985 - 01/28/1999
I purchased this same truck again on March 03, 2014 from an Auction House in Lincoln Delaware. She had 136,589 on the odometer. She was in rough shape and my intention was to restore it, but for the second time i lost my job and was forced to sell her. She never got back on the road with me, but i did do several repairs in the meantime. I sold her to a guy in Owens Mills Maryland on March 28, 2020 who said he was going to swap an LS and drive it - he did not an parted her out. If the cab/frame still exist somewhere i would like the truck back. She had 136,672 last i saw her. Repairs i did during this ownership period: (Used) - Tailgate Handle - 03/28/2020 (Used) - Steering Column - 03/28/2020 (Used) - Headliner - 03/28/2020 (Repair) - ACC Carpet Kit - 8019-Mist Grey Plush Cut Pile - 03/28/2020 (Labor) Fuel Pump Rebuild - 03/13/2020 (Labor) Driver Floor Patch - 03/13/2020 (Oil) - Wix Oil Filter - 51626 - 04/10/2019 (Oil) - Mobil1 Oil - 10w-30 - 04/10/2019 (Repair) - ACDelco Battery Shims - 04/08/2018 (Upgrade) - Speed Dawg Shift Knob Adapter Kit - 09/25/2017 (Upgrade) - American Shifter Red 7 Billiard Shift Knob - 96052 - 09/25/2017 (Repair) - ACDelco Battery Cable - 4BC41X - 07/05/2017 (Repair) - Mopar Wiper Breaker - 56001110 - 07/05/2016 (Brakes) - Wagner Brake Hose - BH113144 - 06/13/2016 (Brakes) - ACDelco Brake Wheel Cylinder - 18E1342 - 06/13/2016 (Brakes) - ACDelco Brake Wheel Cylinder - 18E1337 - 06/13/2016 (Brakes) - ACDelco Brake Spring Kit - 18K562 - 06/13/2016 (Brakes) - ACDelco Brake Adjuster Kit - 18K7 - 06/13/2016 (Brakes) - ACDelco Brake Adjuster Kit - 18K6 - 06/13/2016 (Repair) - Dorman HELP! Jeep Vacuum Harness - 46004 - 06/01/2016 (Repair) - Dorman HELP! Jeep Vacuum Harness - 46003 - 06/01/2016 (Repair) - Dorman HELP! Crankcase Vent Tube - 46005 - 06/01/2016 (Brakes) - 3/16 CNC Brake Line - 06/01/2016 (Upgrade) - Depo Foglights - 04/01/2016 (Repair) - BCP 5 Weatherproof Electrical 2 Pin Way Connector - 04/01/2016 (Repair) - 2P Male Black 20 AMP Connectors - 04/01/2016 (Used) - Eliminator Door Panels - 03/20/2016 (Repair) - Omix-Ada Windshield Molding - 12035.58 - 03/20/2016 (Repair) - DB Electrical Alternator - ADR0026 - 03/20/2016 (Repair) - Dayco Serpentine Belt - 5061025 - 03/20/2016 (Repair) - Windshield Adhesive - HAH000004 - 03/20/2016 (Repair) - Windshield - DW01140GBN - 03/20/2016 (Oil) - Mobil1 Oil - 10w-30 - 03/21/2015 (Oil) - Mobil1 Filter - M1-207 - 03/21/2015 (Repair) - TeamXj Sun Visor Clip Set - DF49JS1 - 09/13/2014 (Repair) - Omix-Ada Serpentine Belt - 17111.04 - 09/13/2014 (Repair) - Omix-Ada Bumper Guard - 12035.35 - 09/13/2014 (Repair) - Crown Auto Radiator Grille [Black] - 55013145 - 09/13/2014 (Repair) - Crown Auto Parking Lens Screw Set - 6034204 - 09/13/2014 (Repair) - Crown Auto Hood Prop Rod Holder - 55027404 - 09/13/2014 (Repair) - Walker U-Bolt Exhaust Clamp (x2) - 35413 - 07/05/2014 (Repair) - Walker Tail Pipe - 46701 - 07/05/2014 (Repair) - Walker SoundFX Muffler - 18387 - 07/05/2014 (Repair) - Walker Hardware Insulator - 35750 (2x) - 07/05/2014 (Repair) - Walker Exhaust Pipe - 44320 - 07/05/2014 (Repair) - Walker Exhaust Gasket - 31362 (2x) - 07/05/2014 (Repair) - Walker Catalytic Converter - 15634 - 07/05/2014 (Repair) - White Knight Bulge Acorn Lug Nut - 1704S-20AM - 06/27/2014 (Repair) - TYC Pass Side Marker Lamp - 18-3183-01 - 06/27/2014 (Repair) - TYC Driver Side Marker Lamp - 18-3184-01 - 06/27/2014 (Repair) - Parking Light Bulb Socket - 06/27/2014 (Repair) - Parking Light Bulb Socket - 06/27/2014 (Repair) - Omix-Ada Flasher Relay - 12411 - 06/27/2014 (Repair) - Dorman Parking Brake Cable - C93591 - 06/27/2014 (Repair) - Dorman Hood Release Cable - 912-008 - 06/27/2014 (Used) - Tilt Column (Tan) - 03/20/2014 (Used) - Taillights - 03/20/2014 (Tires) - Scrub Tires - 03/20/2014 (Repair) - Magnecor Wire Set - 6044 - 03/20/2014 (Repair) - Fram Fuel Filter - G3641 - 03/20/2014 (Repair) - Fram Air Filter - CA3901 - 03/20/2014 (Repair) - Champion Spark Plugs - RC9YC (4x) - 03/20/2014 (Repair) - Champion Spark Plugs - RC9YC (2x) - 03/20/2014 (Repair) - Accel Distributor Cap - 120330 - 03/20/2014 (Oil) - Mobil1 Filter - M1-207 - 03/20/2014 (Oil) - Excel Oil - 10w-30 - 03/20/2014 (Repair) - Dorman Wiper Blade Arm - 03/10/2014
1988 Elminator (I would be interested in purchasing this truck back) I named her Scarlet I first purchased Scarlet from a Private Seller in Long Neck Delaware on June 05, 2001 with 89,995 miles on the odometer. She was my daily driver until July, 05, 2002 and was sold to an Electrical Contractor in Ellendale Delaware with 115,968 showing. During that time i did the following repairs: (Oil) - Mobil1 Oil - 05w-30 - 04/13/2002 (Repair) - Standard Distributor Rotor - FD308 - 02/15/2002 (Repair) - Standard Distributor Cap - FD169 - 02/15/2002 (Repair) - Autolite Spark Plugs - 3924 (6x) - 02/15/2002 (Repair) - Autolite Plug Wires - 86624 - 02/15/2002 (Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 01/21/2002 (Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 01/16/2002 (Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 12/27/2001 (Repair) - Fram Air Filter - MA3901 - 12/1/2001 (Oil) - SuperFlo Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 12/01/2001 (Used) - Brush Guard - 11/30/2001 (Repair) - Mopar Speedo Cable - 04897729AA - 11/9/2001 (Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 11/01/2001 (Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 10/25/2001 (Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 09/17/2001 (Battery) - Battery Install - 09/10/2001 (Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 09/07/2001 (Tires) - Correct Rim Install - 08/27/2001 (Labor) - Muffler and Steer Shock - 08/20/2001 (Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 08/19/2001 (Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 08/01/2001 (Labor) - Clutch Repair Z - 07/17/2001 (Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 07/06/2001 (Repair) - A/C Repair - 07/05/2001 (Repair) - A/C Repair - 06/20/2001 (Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 06/08/2001 (Labor) - Radiator Flush - 06/08/2001 (Labor) - Rear Differential Service - GL6 - 06/08/2001
1988 SWB Pioneer 4x4 I named her Carmine. She was purchased from a private seller in Norristown Pennsylvania on October 15, 2006 and sold to a gentleman in West Virginia on June 29, 2007. She came with 142,820 on the odometer and left with 143,833. In my care she had the following repairs: (Used) - Wj Control Arms - 05/31/2007 (Repair) - Rear Main Seal - 10/3/2006 (Tires) - Used Tires - 10/1/2006 (Repair) - Window Seals - 09/1/2006 (Repair) - Floor Pans - 09/1/2006 (Repair) - Wiper Blades - 08/31/2006 (Repair) - Sylvania Bulb - H6054 - 08/31/2006 (Brakes) - UBP Brake Shoes - 151R - 08/26/2006 (Brakes) - Raymold Wheel Cylinders (2x) - 08/26/2006 (Brakes) - Raybestos Spring Kit - H7064 - 08/26/2006 (Repair) - Walker Tail Pipe - 46701 - 01/4/2006 (Repair) - Walker SoundFX Muffler - 18113 - 01/4/2006 (Repair) - Walker Catalytic Converter - 15634 - 01/4/2006 (Repair) - AMGauge Muffler Clamps - 225 - 01/4/2006 (Repair) - Walker Gasket - 31519 - 11/25/2005 (Repair) - Walker Gasket - 31362 - 11/25/2005 (Repair) - Walker Front Pipe - 44320 - 11/25/2005 (Repair) - Monroe Steer Shock - SC2928 - 11/25/2005 (Repair) - Dayco Idler Pulley - 89006 - 11/25/2005 (Repair) - Bussman Fuse - 552 - 11/25/2005 (Repair) - Dorman Vacuum Harness - 11/4/2005 (Tires) - Used Tires 10/27/2005 (Repair) - Mopar Water Pump Gasket - 53020420 - 10/27/2005 (Repair) - Mopar Water Pump - 4626215AB - 10/27/2005 (Repair) - Mopar Thermostat Gasket - 53020547AC - 10/27/2005 (Repair) - Mopar Coolant Overflow - 758977K - 10/27/2005 (Repair) - Crown Auto Thermostat - 83501426 - 10/27/2005 (Oil) - Oil Change (Jiffy Lube Lewes,DE) - 10/27/2005 (Repair) - Standard Rotor - 10/17/2005 (Repair) - Standard Distributor Rotor - FD308 - 10/17/2005 (Repair) - Standard Distributor Cap - FD169 - 10/17/2005 (Repair) - Standard Cap - 10/17/2005 (Repair) - Fram Fuel Filter - G3641 - 10/17/2005 (Repair) - Autolite Wires - 10/17/2005 (Repair) - Autolite Spark Plugs - 3924 (6x) - 10/17/2005 (Repair) - Autolite Plug Wires - 96624 - 10/17/2005 (Repair) - Autolight Spark Plugs - 10/17/2005
For whatever its worth, this truck was in Georgetown Delaware from January 29, 2006 to July 31, 2006 before being sold to John. She was bought from a farmer in Bridgeville Delaware at 125,260 miles and left for Texas with 125,286.
Truck starts up, runs for 10 seconds, dies
Bonkers replied to Bonkers's topic in MJ Tech: Modification and Repairs
Ive tried randomly swapping relays, but i havent had time to figure out which one is the fuel pump on the 5bank setup. -
I'm not sure what you mean by "trying to call out." There are splices and cuts all over this harness, but the relay connections travel directly into the loom, the splicing is (mostly) connected to the starter relay and some kind of jumper harness. It rained today, but ill try to get better pics tomorrow... -
Any of you guys ever see this before? It looks original, feels original, but for the life of me i have no idea where it came from if it didnt come from the factory... -
The truck in question has 5 relays, theyre all hot when i turn the ignition on... -
Doesnt change the stall, but if i press the pedal down while cranking, it will not start. -
The vacuum tubing is mostly new and i don't see any breaks or dangling lines. I can keep the motor running a few seconds longer with starter fluid. If i turn the key off and start it fires right up. If i leave the key in the on position and try to start it again, it will not start.
