Pancho975
    Denver, CO
  • Interests
    Travel, stunts and snow.
1259 profile views
Pancho975's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. That thing is bad asss. About $900 tho huh?
  2. Any progress on reproducing one of those factory brush guards? Sure would like one of those... FYI almost ready to install the sliders . Was a busy winter haha...
  3. Yup I got your PM, just replied. No, never had it off. Not sure about the bolts, tank itself looks pretty rusty on the outside...
  4. I have a LWB gas tank skid plate on my truck maybe you can check it out when I stop by.
  5. I really liked the old front bumper/winch set up you had. DO you remember what that originally came from or what brand it was?
  6. Crazy to see where this thing started and where it is now!
  7. Nice! Got the same lift on mine. Love the way it handles now. Can you post a pic of the modified exhaust and the way it fits around the spare? I currently have the stock spare underneath the bed, but starting to worry on the trails about getting a flat at some point so planning on getting a big spare to match. But wondering is there's a way to run it under the bed still rather than having to make a custom mount for the bed, take up bed space, yada yada yada...
  8. Copy that thanks! Although it's kinda weird how the OEM cap is like permanently sealed on there with those metal tabs. Do you have to pry it off to replace it?
  9. Hey quick question for you: I noticed in your signature you have the HO 4.6L engine. I read on cherokeeforum.com that 91-92 Comanches were available with a 4.0L I6 MPI "Power Tech" HO (High Output) - 190hp @ 4750 rpm, 220 ft lb @ 4,000 rpm. Is there any way to tell this engine apart from the regular 4.0L EFI? I'm assuming yours is not stock but thought you might know...
  10. Yeah I don't how the hell those holes got there! Anyway, replaced that, Napa had the part for $25 easy fix... Pushed it hard on the trails yesterday and it's only reaching near the red zone (about 250 degrees) under the most extreme climbs. Had to kick the heat on again from time to time. New res tank seemed to help some but not completely. The radiator cap is sealed tight so that's not the issue. All the hoses look okay so that's good news too. What I think it is actually is the engine fan clutch is bad. Correct me if I'm wrong, but when the engine gets to normal operating temp and you shut the engine off, you shouldn't be able to spin the fan freely at that point with one finger. There should be some tension there right? Anyway, going to replace that and see what happens. A full system flush probably wouldn't be a bad idea either. Also, was reading this today and it says the off-road package (which I'm pretty sure I have due to the skid plates, Dana 44 rear, etc.) also included a bigger radiator. Can anyone verify this? "The optional 4x4 Off-Road Package included high-pressure gas shocks, front tow hooks, a heavy-duty radiator, and front skidplates. There was also an available Trac-Lok rear diff for the 4.0L (if the truck had the fullsize spare)." http://www.fourwheeler.com/project-vehicles/154-0610-jeep-comanche-mj/
  11. Damn that roll bar in Silver is beeeyuuutiiful! Exactly what I'm looking for. Thanks for the info B.
  12. I've been overheating the last couple days as well. Checked my Haynes Manual for trouble shooting, but it says that Comanches/Cherokees have a closed system with the reservoir cap acting as a pressure cap as well. My truck definitely does not have that system. In fact, it has two, possibly even four small holes in the reservoir tank that fluid leaks out of now when the engine is turned off and coolant flows back into the tank. Engine fan is running, coolant is filled to "fill" line. A very recent problem, just started the last few days. Any ideas? It almost looks as if holes were drilled into it? Maybe there was a label or something on there originally that fell off or something? Are there supposed to be holes? Doesn't look right to me...
  13. Fixed my drivers side door lock last week that was broken from a screwdriver break-in that happened many years ago. The old one was just sitting in the bottom of the door when I pulled the panel off, clearly beyond repair. Cheap fix with a standard Chrysler $10 door lock from eBay. Was kind of a pain in the @$$ to get everything reattached, took a zip tie and some rubber bushing to replace some of the plastic pieces that broke but got it working! Then had an alarm put in for extra security. Finally, ready for some sound! 11 years I've been driving around with blown speakers haha. Decided to go with the Infinity Kappa 5, a five channel bluetooth amp. This way I could bypass the stock head unit and did not have to mess with the dash or anything. Would be kinda nice to have a working cassette deck, but not worth the trouble. With this amp, you can stream directly from the phone to the amp. Both the front and rear speakers fit right in and replace the stock ones, 5 1/4 components for the front and 6 x4 for the rest. Ordered almost everything from Crutchfield. Also replaced the original battery terminals which were in bad shape. Still running the zip tie battery strap too, put that on the list haha. The amp sits nicely behind the passenger seat with the bluetooth controller run into the center console. The 8" JL Audio CP108LG-W3v3 "Micro Sub" is a perfect fit behind the seat as well. Crutchfield has it for $269, but I found a local place having a sale on it for $199. It lays down nice behind the driver seat as well. Ready to rock!
  14. Ran some trails in Arapahoe National Forest south of Idaho Springs yesterday. Devil's Canyon, Old Little Bear Creek Road and Barbour Forks. Devil's Canyon is a fun little 5-6 mile loop off CO 103. Fairly easy dirt and rock roads with only one fairly steep, very rocky section that you can go around if needed. Great views of Mt. Evans and down range from the top. After that I headed down to Echo Lake Lodge, had some lunch and then continued on 103 which turns into Squaw Pass Road. Took the shortcut north back to Idaho Springs on Little Bear Creek Road. Just a mellow dirt road with fun switchbacks and nice views. But, Old Little Bear Creek Road bypasses the switchbacks along the mountains. Explored that as well and it was really fun. Finally, hit up Barbour Forks 4WD recreation area. Some really cool stuff with technical rock sections. I've been wondering why there's not more articulation in the front, I assume it's because my sway bar disconnects aren't actually disconnected? Forgive my naivety but I'm new at this rock crawling stuff... It was more for that reason I didn't complete the entire loop. Just drove up to the covered picnic area and explored the trail up into the woods a bit. It's a cool zone, definitely an area worth returning to.
  15. Hey I gotta ask just curious, what is the reason for this truss on the axle?
