gai092460
1 Follower
    Edgewater New Jersey
  • Interests
    Vehicles from. the eighties
1117 profile views
gai092460's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Thank you for your response quick recap Options 1) I can retain my 89 BA 10 trans upgrade the Slave Cylinder and the master Cylinder same part as used on AX15 that should work ,with simple hook up no revision required ? 2) Upgrade my complete trans from 89 BA 10 to 1994 or older AX15 trans ,are there many modifications required with this upgrade ? Has this been performed many times with other members of the club ? Kind Regards George
  2. Sorry 1989 4.0 L 182K on original motor
  3. Hello Jeep Comanche Family I am baffled with challenge of replacing my Slave cylinder 3 times in 3 years ( Using LUK parts ) any suggestions ? Other threads I read suggest later model trans ,prefer not go that route ,there must be a better choice Kind Regards George
  4. 1989 seat belt cover cap ,is it still available ? Need one
  5. Are you able to adjust the valves on 4L engine
  6. Hi Pizza man I used Millers oil 15W 40 with Zinc
  7. Hi Fellow members My 1989 4L with 181 K on the odometer started with a slight valve tap that with in 5 min would disappear ,its now permanent tap any inexpensive solutions ( Oil changes I do every 2 thousand miles ( Just completed one last week the tap started ) I also tried using oil with Zinc thought that would help as well Mystery marvel nothing so far helped Thanks George
  8. My 89 Comanche has terrible squeaking noise whenever I. go over smallest bumps in road ,any idea on how stop it
  9. Jeep MJ Comanche OEM Mud Flaps Included Are Remanufactured Metal Mounts | eBay
  10. I. can send you photos
  11. Hi All Let me know if anyone is interested in Jeep MJ. rear mud flaps in very good condition ,with 2 right brackets ,unfortunatley I purchased a set on this site ,from member with poor business ethics ( He sent me of the same side ) Thanks George
