Jackrabbit41 Posted October 14 Posted October 14 Kinda on a rabbit hole but I’ve read through a lot of old forms on getting more power out of a renix. What all bolt on stuff can do that’s actually worth it? A lot of guys talked about the 60mm throttle body from strokedjeeps but when I go to his website looks like it’s down. Anyone out there sell these still? I’d like to wake this thing up a bit. I have 36 iroks and 4.10 gears which don’t help but I’d like 20-40 more horse if possible. Just a lot of the threads online are so old, the parts don’t exist on the linked websites. Thanks yall
derf Posted October 14 Posted October 14 Honestly, not much of the cheap bolt ons will give you what you are looking for. If your engine is typical, it's likely in need of a rebuild. A slightly upgraded camshaft may give you some more pep. But as far as bolt ons, most really are snake oil. Especially for a low revving, mild motor. A good tuneup wouldn't be a bad idea. Sometimes just fresh spark plugs can make a big difference. Most effective upgrade you can do is to swap out axle gears. Matching the axle ratio to the bigger tires will make a big difference. Some 4.88s would be a good upgrade for 36" tires.
ThatJeepGuy Posted October 14 Posted October 14 Agree on the regear. I had 36 iroks and 4.56 many moons ago as my DD and it was manageable but wanted the 4.88s.
75sv1 Posted October 14 Posted October 14 40 HP would be stroker territory. 20 HP, maybe. The Jeep 4.0L was done fairly good from the factory. Some will say 15-20 HP from the head. Hornbrod did get 12 HP at the rear wheel from a 99+ Intake. So, 16 HP at the Flywheel. His motor was a stroker though. On a stock motor you might see 5-8 HP. That is a might. A bore TB did help with some drivability issues on my lifted '98 XJ. Mainly on incline grades in WV. Regearing to 4.10s with 31's help too.
Jackrabbit41 Posted October 14 Author Posted October 14 Id like to try the intake and TB either way. Question about the TB though, where can you buy a bored one these days?
Eagle_SX4 Posted October 14 Posted October 14 1 hour ago, Jackrabbit41 said: Id like to try the intake and TB either way. Question about the TB though, where can you buy a bored one these days? The 91+ and 98+ intakes don't fit the Renix head very well. The intake ports got moved in 91 for the H.O. motors. If you are going to do a 98+ intake it would be worth swapping the head as well. A 7120 or 0630 casting head would be a good candidate. If you run the newer manifold you can straight bore a H.O. throttle body to 60mm very easily. The only issue is adapting the Renix TPS to the H.O. throttle body.
89 MJ Posted October 14 Posted October 14 I've done a lot of the easier performance mods you can do to a Renix 4.0. I have 4.10 gears with 31" tires as well as a 4.0 and a 5 speed, which I think HO header HO head (actually a whole HO long block, but bottom end differences are negligible) Bored throttle body 4 hole injectors High altitude CPS The big one I have not done is the horseshoe intake swap. Having spent hundreds trying to hop up the 4.0, I can confidently say that they did not add 20 hp to my truck. I would like to do the horseshoe intake at some point so that it will match the intake runners in the HO cylinder head better, but I highly doubt it will add a noticeable difference. If I could do it all again, rather than swap my truck's original rod-knocking Renix 4.0 for a good, low mileage HO 4.0, I should've swapped to an LS and had the power level I was happy with and (likely) better fuel economy.
neohic Posted October 14 Posted October 14 1 hour ago, 89 MJ said: … I should've swapped to an LS and had the power level I was happy with and (likely) better fuel economy. ^This. Even after building a mild stroker, I’d never do more than a quick rebuild on a 4.0 again. The power is nice, but after moving from MN to the higher altitude on CO it just feels more like a brand new 4.0.
derf Posted October 14 Posted October 14 I'm going to be giving a 4.6 stroker a try in my next project. More power and torque without the headaches that come with swapping in a different type of engine. All I have to do is pull one 4.0 block and bolt in a different one.
ghetdjc320 Posted October 15 Posted October 15 Well, I guess just to add to the conversation, after having built many a 4.0 and stroker variations thereof, an LS swap is my go to and I don’t look back. That being said, the best bang for buck was a stock 4.0 bored .060, with an edelbrock head, decked down for an .038 quench and about 10.75:1 compression ratio. That engine build was a few grand but less than my other strokers. With 4.56, my aw4 and 33’s, It performed admirably. But still no where close to a true LS swap. I’d like to try forced induction as well on a 4.0 as it would be a good candidate. But ultimately, it’s a tractor engine with a terribly outdated design. I don’t mean to disparage it to much but realistically, you don’t really notice an extra 40hp on a 4.0 given the power band. And you can sink a ton of money into them with very little to show for it. Even at 300hp, still feels like an anemic boat anchor. Forced induction, gears, or an engine swap would be my go to. And gears would by far be the most cost effective of the three.
Torq_Shep Posted October 16 Posted October 16 I struggle so much with this. My 4.7 stroker is a dog but it's tuning and exhaust I think. It's starting to make noises that I would hope are top end but I am nearly certain are bottom end. The unbeatable low end torque of the 4.7 is awesome. It's so good. But it's not a revver. Basically useless after 3.5-4k. An LS would be great but I worry that it would ruin the nostalgia of driving the i6.
neohic Posted October 16 Posted October 16 8 hours ago, Torq_Shep said: … An LS would be great but I worry that it would ruin the nostalgia of driving the i6. ^This also. I love my stroker as a 6 cylinder. I’d never build one ever again though.
Porquer Posted October 16 Posted October 16 My advice is to drive a 2.5. Then your 4.0 will feel great!
neohic Posted October 16 Posted October 16 22 minutes ago, Porquer said: My advice is to drive a 2.5. Then your 4.0 will feel great!
Moosieus Posted October 17 Posted October 17 ZF 8HP70 transmission swaps have been gaining traction. Aftermarket controllers are on the market now as well as adapters. Google trends shows interest has especially taken off in 2024, for what that data point’s worth. The advantage there is necessarily a lot more gearing than crank horsepower, but I think for daily driving conditions that’d be more desirable. A lot of newer sport cars have venerable 0-60 times and aren’t all too different from a 4.0L equipped MJ in terms of power output and weight. What they have is dramatically more gears and better driveline efficiency. That said it’s still largely uncharted waters, far from plug and play. Not even sure if the dimensions would work, but they seem close.
boxyjeep Posted Sunday at 09:37 PM Posted Sunday at 09:37 PM EGR plate and adjustable FPR can help. The ECU is just so bad you need to “tune” around it. I’m running a 4.6L Renix stroker. It I had to do it all again, I’d 110% go LS.
fiatslug87 Posted Monday at 12:31 AM Posted Monday at 12:31 AM 2 hours ago, boxyjeep said: I’m running a 4.6L Renix stroker. It I had to do it all again, I’d 110% go LS. But then you couldn’t register it in California.
derf Posted Monday at 12:34 AM Posted Monday at 12:34 AM 2 minutes ago, fiatslug87 said: But then you couldn’t register it in California. You can if you keep all the emissions and jump through hoops.
75sv1 Posted Wednesday at 11:33 AM Posted Wednesday at 11:33 AM On 10/18/2026 at 5:37 PM, boxyjeep said: EGR plate and adjustable FPR can help. The ECU is just so bad you need to “tune” around it. I’m running a 4.6L Renix stroker. It I had to do it all again, I’d 110% go LS. I would wonder about a Late Model wiring upgrade or an aftermarket controller. Or swap in the new Chrysker straight 6.
