Everything posted by Gojira94
November 2026 - A College Restoration
Gojira94 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Well deserved. Great work and great truck, congrats! -
If you're leaning toward head gasket leak, OEM Tools 57145 combustion leak detector can be rented at Autozone, equivalents at most other parts house stores. Easy to use.
Weird exhaust Popping when decelerating
Gojira94 replied to Big_Mark's topic in MJ Tech: Modification and Repairs
YES!!!! -
Long term fuel trims will come around with the new injectors. Short terms are already starting to pull fuel out to correct. Since you didn't reset by disconnecting the battery (which is fine and probably more entertaining to watch it adjust and come around), the ECU will learn the new injectors in multiple subroutines, i.e. acceleration enrichment, deceleration enleanment, power enrichment, etc. Deceleration enleanment and deceleration fuel cutoff are the ones you've been noticing all the pop pop pop in, because the ECU couldn't trim enough to get excess fuel to a manageable level with low MAP and closed throttle. Within a week or so of regular driving, you'll notice quite a bit more torque and throttle response coming in, and noticeably better fuel mileage, and that popping will go away altogether. Congrats!! -
Bosch 0280155887 is 18.1lb/hr | 4 hole | V-spray | 191cc/min @ 3 bar | 14.5 Ohm. Those should work quite well. I've been on the fence about how using a V-spray injector in a 4.0 might work vs a conical spray - it might make zero difference. It's also completely possible they swapped the metering plate with a conical while they had them apart (which would be clever/ cool). -
Small cheap updates - battery tray/ top bracket/ t-bolts New pair of bezels for $19 - the streak on the trans bezel is a reflection... Knock-off pair of QDs - sway bar angle is much happier now. Rattling noise in low speed cornering is gone with the old links...
I'm a little late but here's what I know about the Toyota 1.8 - Misfire codes are common. Coils aren't the actual problem a good deal of the time. Common scenario 1: cam carrier cover/ valve cover develops leak(s) and flow down to the intake gasket rings. Usually but not always the middle 2 cylinders. Intake gasket/ ring(s) develop leaks and cylinder(s) show it as lean condition misfires. Oil can also pass into plug tubes from old carrier cover plug tube seals and foul plug(s) and coil(s). Solution: reseal cam carrier cover and intake runners, assess bottom(s) of coil(s) for swelling from any oil contamination. (Less) common scenario 2: Factory Denso Laser Iridium plugs go past their 105,000 mile service interval, well into the 130-150,000 mile range and begin to show occasional misfire(s). Solution: Replace plugs with either the same Denso as original plugs (around $28 apiece) or alternately an NGK IX Iridium (around $15 apiece, 60,000-ish mile plug). And check cam carrier cover/ intake gaskets for emerging leaks. Denso coils are far superior to any parts house brands. Do not throw them away unless they're 100% confirmed bad. The ignition coils on my 2003 Accord EX are also made by Denso and are original with 383,000 miles, if that tells you anything. I've seen NGK coils in the aftermarket but have no personal experience with them. Any spark plug other than Denso or alternate NGK IX Iridium is a no-go. Granted, a brand new plug of any brand will work better than a worn out one, but for how well and how long is anyone's guess.
If AI had a raw hexadecimal dump of a Renix ROM, it could probably sus out the parameters for tables, flags, scalars and constants with some human help. Someone with some EFI tuning experience would be able to recognize where one parameter ends and another starts, though it takes some time and patience. Then give the AI feedback on what tables are what (like spark tables, VE {fueling} tables, lookup tables for AE and DE routines). Then ask the AI to write a definition file in XDF file format, which it should be aware of. A human can do this by getting a hex dump of a ROM and converting to integers. Flags (yes/no, true/false, on/off) are the tricky ones to spot, as they’re just hexadecimal for 0 or 1. You spot them because they don’t fit in with values that precede or follow them in the code. Given an editable calibration in XDF or other human-readable definition format, all you’d need would be emulator hardware similar to Ostrich or QuarterHorse that alters calibration values on the fly to effect alteration of the ‘tune.’
Adding 94-96 XJ A/C to 87-90 MJ - Slow Thread
Gojira94 replied to Gojira94's topic in MJ Tech: DIY Projects and Write-Ups
I already had all the 4.0 Renix harnesses, that came with the project. Motor, trans and transfer case are from a low miles 93 YJ that got LS swapped. I added quite a few later HO-era upgrades along the way. Electrical work is my fetish anyway lol... and donor XJs are getting hard to come by where I am. -
The Ultimate "While I'm In There" (Advice Needed)
Gojira94 replied to Backpacker's topic in MJ Tech: Modification and Repairs
What part of central NC are you in? I'm in the central NC area too (Clayton). I can't say I've got a lot of things left over from my build, but anything I've got that you can use, you can have. Shop looks like the one at Wake Tech... -
Primary mission accomplished. Sunset gathering at the point in Emerald Isle is a daily thing down there.
I found a pair of BOTH trans and TC shift bezels for a 2001 XJ side project for $19 on Amazon. That seller is now out of stock on that deal but I think all these bezels are coming from the same factory in China. I was actually shocked at the quality and fitment being as good as they were.
Wiring under the hood all buttoned up... I'll be using a Sanden SD-709 compressor. It has this style single-pin connector, which I harvested from another 88-94 GM TBI truck: The reason I added a pin to C109 Pin C: Driver side inner fender well cleaned up: Final mounting for C117 and the compressor clutch coil relay: -
Last weekend I got the rear brakes and cables sorted, bled, adjusted and drove it. Hadn't heard it run before then. I have to say it's the smoothest and quietest 4.0 HO motor I've ever heard. 50psi oil pressure at hot idle. Transmission is butter smooth. I also fixed the wobbly console and put new shifter bezels on it. Yesterday it got a new battery tray. She's really happy with everything so far and she drove it last night for the first time. Motor was replaced in 2016, I'm trying to find what the mileage was when that happened. Here's the bad - the front axle really really needs a refresh and the front tires are cupped and chopped and hella noisy. I can tell this Jeep would want to be a wobbler! It'll hold together until spring, no problem. She's going to be driving it short distances at 45MPH or lower, to the Emerald Isle Beach surf access points and occasionally to the grocery store. That's essentially 5-10 mile round trips, tops. I've started trying to source a high pinion Dana 30 to replace the LP. I'd like to build a ready-to-go axle for Springtime after beach driving season is over. At the same time it'll get Core 4x4 uppers/ lowers/ track bar package, Rusty's RX27/RX26 hydro shocks. In the rear, pinion angle is 1* below driveline angle, so that would otherwise be good, but... operating angle of the shaft is 8-9*. Anything above 7 isn't acceptable long-term, so we'll be doing a SYE and Tom Woods shaft for the rear as well.
Everything done and tucked in except the connector for the compressor clutch: MJ looking a little frumpy. Reassembling after the rain stops and I can open the garage door... -
One of the best "thoughtful preservation" jobs I've ever seen. Very clever idea on the window sweeps, for sure. Enjoy your work truck!
Low pressure switch wiring done and tucked away: LP switch and compressor wires route behind the battery tray: Next item is compressor wire tie-in to C109 Pin C. This just ties the A/C clutch relay circuit to Diagnostic Connector D2-6. -
I'll be curious to see what number they send you. Post up the Bosch 0280155xxx number when they arrive. -
My connector for the MT0484 binary switch came from a 5.2L ZJ. The switch and connector are on the high pressure hard line right in front of the throttle body on one of those. I'm sure it can be had on other boneyard vehicles but I found this one in the first 10 minutes. -
Rather than run a wire back to the A/C clutch relay Pin 87 all the way back across, I'm going to tie into the green wire on the Engine Harness side of C103 Pin D. I traced the wire down next to the battery tray, where I'm routing the Low Pressure Switch wire from C117. This will make the pigtail coming off the Engine Harness for the LPS relatively short, routed behind the battery, to the Receiver Drier. I'm going with a Santech MT0484 binary switch on the drier for this. So the system will have both low and high pressure cutoff. And the system will also retain the Thermostat Switch at C238. Santech binary switch MT0484 is closed from 32-335psi. It's open above, as well as below, that range. -
I haven't had the time or opportunity to work on my own junk since the XJ arrived on the scene. I took an available hour at mid-day to get my head back in it... Diode wiring measured for position and mocked up prior to soldering: Next item will be to address diode pin A connections. -
Project distraction... 65 Olds F-85
Gojira94 replied to A-man930's topic in Member Projects: Other Cool Stuff
'65? Buick 225 I-6, Chevy 250 I-6 or Olds 330 under the hood, or did the original get gone a long time ago? Great find! -
Probably good advice. I possess the character flaw of having the conviction that anything can be fixed. So I want to fix it. But I won't. Thanks for talking me back from the edge. Cheapest axle shaft I can get is $45 at my local boneyard, IF there's a D35-equipped XJ. Add about another $35 for bearings and seals and I'd be at $80-90.00.
Carrier and gears on the D35 are fine. Left axle shaft is smooooked. I may find an axle shaft, put bearings and seals in it and see if anyone local wants it for cost of the parts. Backlash is a nice 7.5 thou. 3.55 gears.
