Location
Rathdrum, ID
3110 profile views
Airborne Janitor's Achievements
Comanche Addict (5/11)
Awesome, thanks!
Airborne Janitor started following AX15 Bellhousing cover bolts
This is specific to my 98 XJ with a 4.0L and an AX15. I have misplaced two bolts for the bell housing cover, one is circled in the photo and the other is bottom dead center, opposite the motor drain plug. I don't know the exact size but they are standard bolt heads with a tapered threaded section, kind of like a big sheet metal screw. They are not to mount the tranny to the motor. If anyone can help me that would be awesome, Thanks.
Well it's with a heavy heart I've decided to sell my MJ. It's been a fun project over the years, but I got two kids and I can't fit them both in the truck with me so that takes the fun out of it too. Anyone who is interested here's the link, she's been running and driving great now, someone just needs to finish the body work and paint. https://www.ebay.com/itm/177831567952
Overheating problems
Airborne Janitor replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
I was in a somewhat similar situation after having the head rebuilt on my 4.0. Truck would reach operating temps, then slowly creep past 210* until it went up to 245*. I replaced every part of the cooling system: Flowkooler water pump, new hoses, new Mopar temp sensor, new 195* tstat, new e-fan, until it turned out my Mishimoto radiator was not holding pressure 100% but wasn't producing any leaks. I took the other Mishimoto I had in my XJ and swapped it in, not it doesn't go past 200*. Hopefully this may help? -
Wow, has it really been almost 2 years since my last project update? Long story short the MJ is running well and is currently being used as a 2nd vehicle, but still not finished... Ended up getting the head rebuilt after the head gasket started leaking. Then ran into overheating issues, which was eventually solved with a new thermostat and fan clutch.... Recently I installed the Key Parts "chrome-trim" tail light lenses. I had a pair of sacrificial tail lights that were broken but the housings were good. I used The Right Stuff silicone to completely bond/seal the lenses to the housings. They came out really nice. My next goal is to finally get the 4.56 gears installed. Although I was planning to do the gears myself, I had to sell my place and downsize (divorce) so I may just pay a local shop here in the next month to do that for me. Before my move I was able to chop up a parts MJ I had and pull off the entire cab corners, so body work and a paint job is on the horizon. Maybe by year's end? We'll see.....
Overhead Console with lights ideas
Airborne Janitor replied to knever3's topic in MJ Tech: Modification and Repairs
head liner again but different
Airborne Janitor replied to Aussiemj's topic in MJ Tech: Modification and Repairs
I have an extra headliner in good shape, I'm willing to sell it if you're willing to pay the shipping.... -
Off Road/Grid Comanche Camper Project
Airborne Janitor replied to Airborne Janitor's topic in Member Projects: Your Comanches
Thanks! Generator is an idea. I'm definitely putting a 40" wide tool box up front but I'm playing around with idea in regards to heat. I was going to use propane for heat and mount w 20lb propane bottle on the platform, but I'm worried about the fumes inside the bed. Considering maybe a diesel heater... -
Got the Flowkooler water pump installed along with a high-flow 180* thermostat. Pulled the magnetic drain plug from the Mishimoto radiator and found a ton of rust/debris on it, so I flushed the radiator and the water jacket. Was unable to properly use the vacuum purge/refill kit, I couldn't keep vacuum pressure consistent, then realized the thermostat had moved out of its seat when I bolted the housing on when coolant started pouring out, oops. Temps ranged from 180-210* after the install. Although I'm happy it's running cooler it's still doing that 30* shift when revs fall/rise above 2000rpms. Even though the fan clutch was just replaced (by the shop who did the head work, not me) I'm going to throw another fan clutch on. I have an OEM one with some miles on it I'll bolt on just to see if there's any performance change.
I have to wait until December to get trailer registered due to schedule conflicts. In the meantime I got the camper shell on with a friend, which was a total pain because of how high the bed sits! The camper shell needs a good hose down and paint job. I think my next step is to take the trailer over to Maaco and have them do the bodywork for me, pulling all the dents, straightening the sheet metal, removing all the rivets, and putting down a coat of primer. From there I think I am going to use that Raptorliner spray-on bedliner and shoot the entire bed myself.... -
Maiden voyage complete, nothing fell off! I'm still dialing in the proper height of the hitch set up, it is a little high here. Took her to the power wash station to get cleaned up, then went to a CAT Scale to get weighed. 1150lbs, well under the 2k limit. Next step is to go get her titled and registered, wish me luck! -
20x50mm, or 3/4 x 1 15/16"
So they should be really easy to find, right?
