Moosieus
Moosieus's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Anything can be separated with sufficient employ of implements of destruction As to the spirit of your question, there's some exposed 3mm hex screws on the hinges, but removing them yielded nothing but the screw itself: I peaked under one of those foam blocks what little I could, but I didn't find any hidden fasteners. My superficial assessment is, one may be able to tease it apart with a craft knife set, some pry tools, and maybe a heat gun for potential adhesives. I don't see a means via fasteners alone.
  2. The particular tri-fold I linked uses this style of clamp on the bedside rails. If your bed liner leaves them accessible it'll work, otherwise you may need to modify the liner.
  3. Took the best photos I can, camera lens plays tricks though. Here's the folded configuration. I also have the uncompressed images attached in a zip at the end. The first one is 25" on the money: Here's the next segment: and where the end lands there. bed_cover_photos.zip
  4. While we're on the subject, I feel it necessary to reiterate that the external dimensions of the bedside panels are not square. They taper towards the rear end as pictured below. Here's a photo of the Comanche specific bed cover that came on my truck (gifted to another Comanche owner). If you look closely, you can see it's built square and does not follow the taper. As a practical matter, I don't think any manufacturer ever would on account of the complexity. So it's just the way these trucks are at the end of the day :)
  5. Throwing this thread together quickly on how I sourced a tonneau cover for my short bed. In brief, no one makes tonneau covers or bed covers for the Comanche, so we're relegated to next best sizes for other truck models. neverrust.net has this useful reference table for finding next best fits. I had Claude gin up a quick bounds check against that. I took another quick pass this evening to make it more share-able as a gist. I'm providing that more for posterity than anything. Use with your own measurements at your own risk! Running the script with the measurements I took off my '91 Eliminator yielded this output: Beds with outside length 71.5-75 in. and outside width 55-60.5 in.: Make Model Years Outside LxW Inside LxW ---------- ----------------------------------------------- --------- ----------- -------------- CHEVY/GMC GM Compact/Midsize Truck, S10/Sonoma, Short Bed 1982-1993 75 x 60.25 71.25 x 55.375 DATSUN D-50 Short Bed 1962-1971 74.5 x 58.5 ? x ? DODGE Dodge Compact Truck, Ram 50 Short 1987-1997 74.5 x 60 ? x ? JEEP Commanche Short Bed 1986-1996 75 x 60 ? x ? MAZDA Cab Plus 1986-1993 74.5 x 60 75 x 50 MITSUBISHI Triton, Short Bed 1987-1996 74.5 x 60 72 x 55.75 NISSAN Nissan Short Bed 1985-1986 74 x 58.5 72 x 53.5 NISSAN Nissan Short Bed 1983-1984 75 x 60 73 x 55 8 of 124 beds matched. Another 41 in the chart have no outside dimensions listed and couldn't be checked. Bed dimensions courtesy of NeverRust: https://neverrust.net/cross-reference-chart-for-pickup-truck-bed-size-dimensions/ It's not especially novel information, but this at least corroborated that the 1st gen S-10 was a damn close fit, enough that I opted to act on it. I ended up purchasing this "DNA Motoring New Upgrade Truck Bed Top Hard Solid Tri-Fold Tonneau Cover Compatible with 82-93 S10 / 82-90 S15 / 91-93 Sonoma 6Ft Bed, TTC-HARD-039" off of Amazon. Here's a photo from my build thread along with some additional fitment photos. The lip of my tailgate is beat up, and it needs new bumpers (which I have from Key Parts), leaving a pinky finger sized gap in the center. If I wanna be especially particular (and I especially am), the cover was a hair small when I got it and has since settled to the best I could ask for. In conclusion: Based on the above chart and my anecdote of a single successful purchase, I'd say the best proxy size to shop for is a 1st gen S-10.
  6. ZF 8HP70 transmission swaps have been gaining traction. Aftermarket controllers are on the market now as well as adapters. Google trends shows interest has especially taken off in 2024, for what that data point’s worth. The advantage there is necessarily a lot more gearing than crank horsepower, but I think for daily driving conditions that’d be more desirable. A lot of newer sport cars have venerable 0-60 times and aren’t all too different from a 4.0L equipped MJ in terms of power output and weight. What they have is dramatically more gears and better driveline efficiency. That said it’s still largely uncharted waters, far from plug and play. Not even sure if the dimensions would work, but they seem close.
  7. TIL about infrared keyless entry, thank you! It also has this through the glass antenna, which I reckon was for some car phone or police scanner. There’s also a whole bunch of extra wiring under the rear bench, with this plug labeled “to changer”.
  8. And Now, for something completely different. My desire for Daisy has always been something approaching an OEM+ build, although I wouldn't have known to call it that when I first started. As of yesterday, I've taken a massive step towards that. The fuel pump buzzes like there's 10,000 angry bees in the trunk. The leaf springs are flat. She death wobbles at highway speeds on innocuous bumps. There's questionable speaker wires run about. A swift kick would make her floors no more. 10 minutes from home, the front brakes turned a spectacular smoke show. Dear ComancheClub members, I give you, a fully loaded, clapped out, 1992 Jeep Cherokee XJ Limited. Black leather seats! I plan to have them professionally restored, great expense withstanding: Overhead console! Not sure what that black dot is in the middle. Select-Trac! Here's the full options list: and the door sticker: Still has a Jeep Eagle badge too. My plan is to part it out and make the ultimate factory-optioned Comanche. I had some reservations about parting out a such a highly optioned Cherokee, but after a thorough inspection and an... eventful drive home, this is without a doubt the best possible out come.
  9. Progress update! My truck was optioned with the interior firewall liner which was getting in the way, and I finally came to terms with pull the dash so I could work properly. Safe to say I'll be taking care of any "while I'm here" items while I'm here. Pulling the dash and HVAC module was a surprisingly modular affair, and not too tricky given time to spare. Huge shout-out to this guide on Cherokee Forum and Pete and Mintuit's callouts here! I bought an right angle air drill to get at the difficult to reach spot welds, specifically an Aircat 4337. I also got a cheap harbor freight non-contact tachometer to set the speed closer to what Blair recommends for their spot weld cutters (not to exceed 500 RPM). I'd been using electric drills and "that seems about right" prior, but even that had been too fast in retrospect. I wish I'd done this from the start, because I'm getting through these spot welds at a far more consistent rate now.
  10. Removing seam sealer has been a struggle bus. Best method I’ve found thus far is a hot and sharp chisel, welding gloves, and a respirator for the fumes. Does a good job of lifting the seam sealer w/o damaging the e-coat underneath.
  11. Finally got it out, holy moly. Here’s the removed piece for reference. The 3 spot welds you indicated didn’t go all the way through — seemingly. I had an additional 4th spot weld which I unwittingly removed through sheer force of chisel. That one was support-to-floor.
  12. Making incremental progress, damn this is a lot of work… I’ve removed most of the driver side longitudinal floor support, providing a look at the interior of the frame rail. It’s mostly clean primer with some surface rust. That’ll clean up nicely with some abrasives, Ospho, and 2K epoxy primer. For all the damn work this takes, I’m buying a stroker motor someday.
  13. Found them on my truck, adding here as a data point. Ignore the crossed out cut on the right
  14. I'd say I've learned two key takeaways from all of this: The best (not necessarily the most convenient) extractor for a stripped bolt is a welder. This induction heater is well worth its cost for restoration and general use. I've been especially adverse to using an open torch to free these fasteners, for fear of damaging my interior wire harnesses and factory e-coat. The asphalt undercoating also sponges up petroleum products and is soaked with motor oil, so I regard that as a fire hazard as well. Compared to a torch, induction heating works on fasteners from the inside-out, gets heat into the threads faster, keeps it far more localized, and removes the combustion risks of an open flame. It's a genuinely useful piece of kit I cannot recommend enough.
