Everything posted by derf
That much torque can be hard on the 27 spline shafts up front. And absolutely upgrade the u-joints while you're in there. The stock joints in early XJ/MJs are weak. You'll need new shafts for the bigger joints but they're not super expensive.
1991 Gas Tank Skid Plate
derf replied to Gary from Texas's topic in MJ Tech: Modification and Repairs
Very nice. Thanks for helping me clean out my garage. -
If they don't name the SUV "Speedwagon", I'll be disappointed.
Yep. All good advice. My axle swap is different enough from a JK axle. And I'm going 4½" on my lift. My truss has a stock location track bar mount axle side. But I'm doing high steer and upgrading to 1 ton parts. I'll keep the stock pitman arm. I may decide to put a higher axle side mount for the track bar. But if I do, I start getting into the coil bucket. So it's more likely I'll drop the frame side instead. I want to upgrade that anyway and a lot of those kits build in a drop.
I'm not doing a JK axle so not 100% the same. But I'm going to set up my track bar after I finish the rest of the steering. I'll adjust either the frame side, axle side, or both once I have a drag link in place. I'll adjust what I can so they end up as parallel to each other as possible. If you have a higher mount point for the axle side of the track bar but you use a drop pitman arm, you may be good with leaving the frame side at stock height.
Meanwhile, at the FAA...
Not terrible. Getting some 90 degree magnets helps assemble the main truss. Then several C clamps while welding it in. I did forget that the lower control arm brackets have no key to place them. And the instructions don't say. So I'm going to have to do some measuring of both angles and distances before I burn them in.
Brackets on. I still have to weld in the spring bases and part of the shock mount. But it's mostly together.
Any shops in the west able to install A/C?
derf replied to Poweralth's topic in MJ Tech: Modification and Repairs
X2 If you don't have AC at all, your best bet is a donor XJ. You'll need the AC box under the dash and all the engine bay bits. Some of the parts can and should be replaced when you're in there. But starting with a donor XJ is the best bet. -
Back to the axle this weekend. Got the truss basically assembled. Once it cools down a little, I'll weld it to the axle.
There's also no shifter linkage. The shifter is directly attached to the transmission and comes through the floor into the cab.
They were an option in the CJ as early as 1983. Maybe earlier.
I'm planning a trip soon and have room to transport things for people if anyone wants me to be a courier. I'm going to be heading through TX to visit friends, then continuing on to Atlanta to visit @Pete M to pick up a tailgate, then heading home via a more direct route. I plan on leaving on Thursday 11/19 after work and getting in to new Mexico. Then on to DFW on Friday. Then most of the way to Atlanta on Saturday, finishing up the drive there on Sunday, 11/22. From there I head up through Nashville and over through St. Louis and back through to Colorado by some time on Tuesday. I'll be in an F150 and I'll have a bit of room to carry even some bulky/heavy stuff. If you want me to haul anything, let me know when and where to meet you. I still have the battery tray parts, 2WD Peugeot BA10/5, and 23 spline short input NP231 with the SYE installed. Wouldn't mind finding a home for those on the way. They are in the for sale section. The skid plates i believe are spoken for (but not finalized). My rough route:
That's the ones I have. If you want them they're yours. I'll be coming down through Amarillo to DFW then through to Louisiana on I20. If you're anywhere near there I can meet you. -
I have a couple plastic pieces. My short bed only came with the two. I'm replacing them with custom ones I'm going to make. I'm going to be heading through DFW soon if you want them. -
I have had these a long time. But they're just collecting dust now. A couple of sanders, a couple of drills, and a circular saw. They all still work. I don't know much about them except for what is on the labels and box. One of the drills has no labels. The other drill has an unreadable label beyond saying Black & Decker. $50 plus shipping from 80108.
You may want to give these a try... https://www.quadratec.com/products/16751_02.htm Edit: they are out of stock. These are more expensive but available https://www.summitracing.com/parts/ssh-bwc601?srsltid=AYCX9vKf50IjhMX93nk0YHQPQyC1YYLnbNRzB6AzCWvN7ebXaGe7D5jl
A number of those driers have a port where you screw in the pressure switch. Look for a plastic plug in the one you got. Usually up by the top. You will need to put something in that hole one way or another. On RockAuto's website, under Electrical-Switch & Relay, there is an A/C Refrigerant Pressure Switch. They're pretty cheap.
