derf
Everything posted by derf
  1. If you're overly concerned, you can swap out for longer studs. I don't have the part number off hand but it's a straightforward process. As long as they're torqued properly and you use blue (not red) locktite, you should be good to go.
  2. Got a chance to take a picture of the bolts in question. They are more like 11 and 1 than 10 and 2.
  3. The biggest issue is trying to use it behind bigger engines. For normal use behind a normal 2.5, it's fine.
  4. Two of the bolts may be inverted torx, or E-Torx. It's best to get the right socket for them. They're at about 10 o-clock and 2 o-clock on the bellhousing. This is a reasonably priced set. https://www.amazon.com/SEDY-14-Pieces-Female-Socket-External/dp/B08DF4PRZF/ref=mp_s_a_1_4?dib=eyJ2IjoiMSJ9.zzu9jJFWQt6hZ2lamUZlckpUx5bZwFqzTCMIoK2SPDOPJVy_QnFfA21T7Be0k4pq2ENWKIkk3pyp1-W377NGBc9XyPp1NRVOGByGep5gKdxqtKADdJH4vXplXv3d43jqeSVDxcb5xseJY8bLfzfT6fxdkjSS8rmkcV33PXSOe3_NGSzGRTiISsU1YJ05YvyJnA89X0mfsEkQ1Nr7WnnPMQ.i3gKRL_sVZihT4NpKbHfNEr-7-3IMeUbhMb8pF_RCIw&dib_tag=se&keywords=inverted+torx+socket+set&qid=1779769601&sr=8-4
  5. You need a different output shaft in the transmission and an adapter that you can bolt the transfer case to. Both can be found with a little bit of searching.
  6. An extension and a wobble socket. https://www.amazon.com/gp/aw/d/B00XCQAGKS?psc=1&ref=ppx_pop_mob_b_asin_title
  7. I'll give it a little bit before parting it out. Remind me middle of next month.
  8. The Day The Earth Stood Still (1951, not the 2008 one) Really a great social commentary that still rings true today. Dr. Strangelove or: How I Learned to Stop Worrying and Love the Bomb Brilliant dark comedy that demonstrated the absurdity of the cold war. Idiocracy Not intended to be a documentary but it ended up being one
  9. Came out of a 1987 MJ. 203,xxx miles Shifts smoothly. Comes with bellhousing, 4.0 flywheel and transmission mount if you want it. I can throw in the rear driveshaft from the same shortbed or just the slip yoke if you want it. $50 takes it all. Located in South Denver. I will be driving from Denver to South Carolina and back Memorial day weekend and can transport it along that route.
  10. Now that the CJ is mostly mobile, I'm going to get started on this project in earnest. First step is to strip the silver donor for parts. I'm keeping the engine and wiring, as well as some of the interior and at least part of the bed. Some of the good metal is going to @aris_garage_builds for the 4.0 swap. The donor is in the garage and I've started the tear down process.
  11. The book is good too. Slightly different ending.
  12. You're better off without the manual in the JL. The clutch design is really sub par. And the transmission itself isn't the best out there.
  13. Very nice.
  14. After the first fire, the heater core let go. I ordered a replacement. In the short term I bypassed it. But I got to take it around the neighborhood and gas it up.
  15. Hmmmm... I'm going to be in the vicinity in late July...
  16. The computer needed to self adjust a little and it settled into a pretty smooth running engine. But it's alive again!
  17. I still have to run through emissions testing. But I'm down once that's done.
  18. Had a minor setback. The vacuum booster moves the master cylinder forward. I bent the lines going to the new cylinder and ended up breaking one of them. Ordered a set of replacement lines specifically for the power brake CJ. And a new proportioning valve while I was at it. I got the full line kit but opted to skip doing all of them. Getting the front to back line out is hard. So is the passenger side front. Anyway, got the new lines in and bled. Next step is to try to do a first fire tomorrow.
  19. You know you want to. All the cool kids are doing it!
  20. Neither do I. Neither do I. Neither do I. Neither do I. Neither do I. Neither do I. Neither do I. Neither do I. Neither do I. Neither do I....
  21. I'm staying stock on mine. Renix likely has fewer options than HO, but they are similar so I'm not sure how much croses over between them. I do have spare Renix intake and exhaust manifolds that look stock. They'll be available in the next couple of weeks.
