derf
Everything posted by derf
  1. derf
    Tesla's new truck
    I'm sure it's a towing beast. For about 50 miles.
  2. Yeah, I have steel toe boots I wear when I'm working in the garage.
  3. There may have been an episode where "someone I know" was trying to take the door off his wrangler and it was stuck. When it let go, that individual may or may not have lost his grip on the door and dropped it on his toes while wearing sandals. It may have broken two of the toes and required about 8 stitches. But I'm not admitting anything.
  4. I'm looking at doing something very similar with mine. I agree that .120 wall would be a lot better than .25. That has to be a heavy mother of a rack.
  5. I bought the pair of MJs for chump change, knowing that they both had rear end damage. I was already planning on doing the aftermarket bumper anyway. May as well get the good parts to someone who can use them.
  6. I might could come up with one. I have a factory bumper that's not in great shape and it will be replaced with something else like a JCR that has its own brackets. But I can't get to it to take it apart until this coming weekend. The bracket looks like it's still straight. The bumper took a hit on the passenger side though.
  7. derf
    Tinted Windows
    That's pretty standard in every state. Something like 35% tint or so on the front side windows. Nothing below the AS1 line on the front windshield. Back windows can be as dark as you want.
  8. The 4.0 has port fuel injection and the 2.5 in that year would have throttle body injection. The biggest difference is where the injectors sit. In the 4.0, there is one fuel injector for each cylinder, stuck into each intake manifold runner right before it enters the head. In the 2.5 you have only one injector (or maybe two) sitting on top of the throttle body instead. It's like they took a carburetor, cut out the fuel bowl and venturies and attached a fuel injector or two on top of the throttle plate. Both systems are computer controlled and have things like oxygen senors, pressure or airflow sensors (depending on how the computer is set up), throttle position sensors, idle air control valves, etc. The parts may not interchange, of course, with each having a unique part to accomplish the same task.
  9. Yeah, lots of "while we're in there" work is being done. The injectors are being tested since this is the 200K mile maintenance. Lots of other stuff too.
  10. That sucks. I got to help put in a new head on my buddy's other CRD Liberty. We did the ARP head studs while we were at it.
  11. derf
    Tesla's new truck
    Is it just me or does it look like the illegitimate child of a DeLorian and a Pontiac Aztec?
  12. Maybe good for the tow rig but useless for a rock crawler.
  13. Yeah, that certainly is out of date at best. I doubt they've updated many of their articles in years. And yes, you never want to fully trust a company that has a vested interest in selling you something. Always check multiple sources. What would be a better resource for things like that?
  14. Can you give an example or two?
  15. I found Novak to be very helpful when I was doing the 700R4 swap onto the 401 in my J10. They helped me get the flex plate issues figured out. The issue was with mixing up 360 measurements with the 401 when making the flex plate they source which put the starter ring out of position. A few emails and we had everything worked out. And when I did the LS in my old CJ, the Novak mounts were one of the few trouble free parts of that install. I have heard a few people say bad things about Novak but I can't find any real actual examples of their parts being crap. I'd be interested in seeing some real world examples.
  16. The timing marks on the timing gears really are only there to help you put it together quickly and easily. There's nothing magical about the marks. They are only there to make it easy for the installer. You can ignore the marks altogether as long as you make sure the cam and crank are in the right position and everything bolts together. Of course, some engines have specific alignment pins, keyways, or bolt patterns that force you to only put it on one way and that forces the marks to line up. But it's not a huge deal as long as the cam and crank are in time with each other.
  17. Not much of a change. But really, 80-90% of your braking comes from the front brakes, especially on a pickup truck with a light rear end. When you're braking going into a corner, almost all of the weight transfers to the front and that's where brake upgrades really help. Going with bigger rotors and calipers make a huge difference in the front. In the rear, there's only so much you can do before you lock up the rear tires.
  18. Disks will help a lot with fade so in a race truck they would be a good upgrade.
  19. KJ axles have a bunch of bracketry to support their triangulated 3 link with coil springs. You'd have to cut it all off, which isn't difficult with a torch. Having done a disk brake swap, I have to say that the braking performance is a wash at best. Sure, swapping pads is a ton easier than doing drums and for that, I'm happy I did the swap. But how often do you really swap pads on the rear axle anyway? Keep in mind also that if you change the gear ratio in the back, you need to also swap gears in the front to match. So if you go with a 3.73 KJ axle, you need to drop 3.73's in your front.
  20. Custom exhaust, probably headers unless you can find manifolds that actually fit. Radiator input/output is backwards between the 4.0 and LS. There are Chevy conversion radiators out there that bolt right in. Different versions of the LS (Corvette, GTO, Camaro, truck) have different accessory positions and intake manifolds that affect what is easy and what is difficult to swap. The narrow frame rails of the XJ mean the truck accessories and intake manifolds aren't as easy to swap. But the engines are cheaper. You'll want to grab everything from the donor that you can. You'll need to reflash the computer, at least to get rid of the anti-theft cut out. Beyond that, there's tons of write ups on swapping LS engines into almost everything. Google is your friend.
  21. A friend of mine recently encountered death wobble. The upper track bar bolt came loose and she had a ton of play. Tightened it back up and her death wobble went away completely. The tires were balanced fine. The rest of the suspension was fine. The ball joints aren't new but they aren't worn out. We would have replaced them except for the fact that the DSPO (Dip "Stick" Previous Owner) welded them in... /facepalm. I've experienced death wobble twice myself and had two different solutions required, replacing various worn suspension and/or steering components. What I've learned over the years is that there are many causes and manifestations of death wobble. The entire steering and suspension system is just that. A whole system. Anything that allows a feedback loop will lead to death wobble in one way or another. It can appear as a side to side shimmy. It can also show up as a bouncing up and down rhythm where the axle "flexes" back and forth. I got to watch a buddy in my rear view mirror as his death wobble kicked in. The whole front axle was bouncing as if on a pivot. As one side came up, the other side tire hit the ground and bounced, causing it to come up and the other side coming down and hitting. Back and forth, back and forth. It was pretty impressive. Bottom line is that if you have death wobble, you need to check everything. Ball joints, control arm bushings, tie rod and drag link ends, track bar bushings, swaybar links, tire balance. Check all of it. If anything is worn or out of spec, fix it. Then when you fixed your death wobble, you can pay attention to the steering stabilizer.
  22. I had the same issue with my J10 pickup and a couple of Grand Wagoneers. The key sets are all stock GM parts. Though it is possible that there is more than 1 "standard" GM door and/or ignition lock so a "standard" GM lock may not fit if it's the wrong standard.
  23. Do what you need to do and take care of yourself. We can wait as long as it takes.
  24. Start with the first one. Then keep posting more.
  25. It probably can. But I'd assume that getting the adjusting sleeve away from the passenger side means it's not likely to hit anything else while turning and flexing.
