75sv1
Everything posted by 75sv1
The RENIX seems to get better MPG. I used to get about 25 mpg from calculations. ZI don't think the rear end was original. So, I roughly calculated from mile markers what distance the OD was actually. I then calculated about a 23 mpg. That was an '88 with 4.0 and a manual. Manuals of that era seemed to get about 2 mpg better.
So, an OTK Trackbar. Some have used them, and ran the stock steering. From what I was told, that does improve the steering. I have run cross over steering with the OTK trackbar. Way better than stock. I do run the cross over in the lower position.
I've only tracked Highway(18 to 20), open road (14-16) and towing (12-14).
I swapped in some rear shocks from a WJ into one of my '98 XJs. I did swap out the bushings to ones that fit the XJ. I might have taken out the old ones. Also, some of the Hardware stores have a selection of long steel bushings.
4.0l oil pump screen install
75sv1 replied to tarmac2dirt's topic in MJ Tech: Modification and Repairs
I used the specific tool. I tapped it in place. Also, try and clock it like the original. Also, I remember using some type of sealant, locktite stuff. I think the same stuff I used for the freeze plugs. -
I only did the flat surfaces. Then used the stock. There is some 'discussions' on weather a full coverage or spot coverage. I plan to 'fill in' the 'depressions' on the hood. Then use the stock piece to cover that up. I have to work on the fuel tank, fuel pump on the Avalanche. I have fuel leaking. I think its one of the plastic lines. After that I might do some experimenting.
I also intend to add some Dynamat Under hood material.
I put some of the peel and stick sound deadening on the hood of my Avalanche. Then put on the factory hood insulation. I think it helped a bit.
I would wonder about a Late Model wiring upgrade or an aftermarket controller. Or swap in the new Chrysker straight 6.
40 HP would be stroker territory. 20 HP, maybe. The Jeep 4.0L was done fairly good from the factory. Some will say 15-20 HP from the head. Hornbrod did get 12 HP at the rear wheel from a 99+ Intake. So, 16 HP at the Flywheel. His motor was a stroker though. On a stock motor you might see 5-8 HP. That is a might. A bore TB did help with some drivability issues on my lifted '98 XJ. Mainly on incline grades in WV. Regearing to 4.10s with 31's help too.
258 Expansion plug replacement
75sv1 replied to JZLAJeep's topic in MJ Tech: Modification and Repairs
Also, NAPA might have individual plugs for sale. -
Someone did a Ford 5.0 Comanche a while back on this board. It was Fly Yellow. The V6 with an aluminum block would be awesome. Less weight. Plenty of power.
Must be a 'Dog Day Afternoon'. Well, (Some)One Flew Over the Cuckoo's Nest' to ask such a question. Yeah, Its 19, 19 ,1975. And if Bruce had won an Oscar, well he would have needed a Bigger Boat. And it was just 5. Sort of like the Year. Of course a 1975 Bricklin SV-1. Maybe it needs a stable mate. A Lancia Stratos. For some Championship caliber. 'We are the Champions, Of the World'. For 'One of these night' and no 'Jive Talking', a Stutz Bearcat. Since it might not have fine Carinthian leather, we'll get the Barry White shag carpeted trunk option. Oh, we need a handy go getter. Is its Wayne's World? Its party time. Keeping it AMC. A Pacer. Well, we will need to 'Pick Up the Pieces'. Must be a Jeep. So, a J10, J20 or 400? What to choose?
Jeep 2, Japan 0. How's that for a World Cup.
I did have an issue with an SKF unit bearing. I thought it was the Shaefler unit. The tire puckered a bit. Both were purchased from NAPA.
Um, Star Wars New Hope. Blade Runner. Jaws. RUSH. Alien. Deer Hunter. Indiana Jones. The A Team.
For some reason, Ford Explores have their following. Also, Ford rangers and Chevy S-10s.
I have not done it myself. I have had the manifolds, and put them on a '95 head. I doubt they last long, a start leaking very soon.
The two piece cast manifolds are for the smaller exhaust ports of the 0331 heads. There is about 1/16 'wall' if used on earlier heads. Not much sealing area. I think Pace Setter and possibly Clifford has headers for the RENIX. I did use a RENIX, and have a Cliford (bolted on, but not used).
Haven't done it myself. I would coat the portion going into the ground with a tar sealant. I do have plenty of examples in WV of post just put into the ground. Also, you might coat the top of the post. Or put some type of cap on it. My mailbox post rotted away. Neighbor Daughter-in-Law hit it while moving. She was really upset about it. Replaced it with an aluminum post the neighbor had. Took some convincing to the DiL that it wasn't her fault.
What I did, is initially upgraded to a '91-95 HO VC. It allowed a larger hose. You also need to the 97+ fitting to the intake manifold. The 93-95 GC (Grand Cherokee) has the CCV fitting of the latter 97-up steel VCs. I did do the Cruiser 'upgrade' to them. The 91--95 HO VCs and the 93-95 GC VC have the aluminum inner towers. Another possibly 'solution' is to put on a 'breather' to the front hole of the VC. Thus the air filter box won't be sucking air and oil into the filter. Some use a hose to space the breather a bit from the VC. Also, you can use RTV in place of the VC gasket.
Heat won't damage anything in the area. Just get the bolt or nut to a dark red, if you can. Also, you can try and grind off the nut. Then spray with a rust buster.
I run two on my Chevy Avalanche. I run a Radiant and another, UMD ???. I do catch some oil. Maybe a teaspoon every 500 miles. I run about 10:1 compression, with 88 octane. If a higher compression, then possibly run a catch can. On the 4.0L, most run the catch can on the rear CCV tube. If oil in the air filter, then its either the rear CCV tube needs upgrade to 97+ or its blocked up with crude. On mine, I used the FlePro rubber gasket. Upgraded to a 93-95 CG valve cover.
