I never really though about a flip kit. I think there are other options on a Passenger side drop. I haven't really looked at that problem in a while. My main concern at the present is the Ford 8.8 and what I need to do to get an even lift, Front and rear. Rusty's list a 4.5" lift kit. Then the rear springs on their site says 4" lift. I didn't know about Hell Creek spring options. The Metric Ton springs with their long AAL might work. I just didn't see link to it on their website.
I was originally looking at DPG for some front spring or RE setup. Still, a bit expensive. I might have to see what the rear lift nets and then match springs to that. Spacer or the adjustable spacer might work out. Mine will be a daily driver, so some ride comfort is wanted/needed.
Tom
I did a websearch:
'74-'79 Wagoneer Narrow-Track Dana 44
Differential Location: Passenger side
Lug Pattern: 6-on-5.5
Good For: At about 60 inches wide it's a good streetable swap for most Jeeps with a passenger drop T-case
Pros: Very common in wrecking yards, heavy-duty axle tubes, cheap, easy to convert to other popular lug patterns with bolt-on junkyard parts
Cons: Will need to outboard mount leaf springs if used on CJ or YJ
Identified By: Stop sign like diff cover, spring-under housing, 60 inches wide
'74-'79 Cherokee Chief/J-Truck Wide-Track Dana 44
Lug Pattern: 6-on-5.5 and 8-on-6.5 (some truck)
Good For: It's basically a full-width axle (66 inches wide), good for light-duty full-width conversions on CJs, YJs, TJs, XJs and others with a swapped in passenger side drop T-case
Pros: Fairly common, heavy-duty axle tubes, easy to convert to other popular lug patterns with bolt-on junkyard parts
Cons: Will need to outboard-mount leaf springs if used on CJ or YJ, spring-under housing
Identified By: Stop sign like diff cover, spring-under housing, 66 inches wide
So at least one option. Maybe a few inches wide and the bolt pattern is different. Still, doable.
