75sv1
Everything posted by 75sv1
40 HP would be stroker territory. 20 HP, maybe. The Jeep 4.0L was done fairly good from the factory. Some will say 15-20 HP from the head. Hornbrod did get 12 HP at the rear wheel from a 99+ Intake. So, 16 HP at the Flywheel. His motor was a stroker though. On a stock motor you might see 5-8 HP. That is a might. A bore TB did help with some drivability issues on my lifted '98 XJ. Mainly on incline grades in WV. Regearing to 4.10s with 31's help too.
258 Expansion plug replacement
75sv1 replied to JZLAJeep's topic in MJ Tech: Modification and Repairs
Also, NAPA might have individual plugs for sale. -
Someone did a Ford 5.0 Comanche a while back on this board. It was Fly Yellow. The V6 with an aluminum block would be awesome. Less weight. Plenty of power.
Must be a 'Dog Day Afternoon'. Well, (Some)One Flew Over the Cuckoo's Nest' to ask such a question. Yeah, Its 19, 19 ,1975. And if Bruce had won an Oscar, well he would have needed a Bigger Boat. And it was just 5. Sort of like the Year. Of course a 1975 Bricklin SV-1. Maybe it needs a stable mate. A Lancia Stratos. For some Championship caliber. 'We are the Champions, Of the World'. For 'One of these night' and no 'Jive Talking', a Stutz Bearcat. Since it might not have fine Carinthian leather, we'll get the Barry White shag carpeted trunk option. Oh, we need a handy go getter. Is its Wayne's World? Its party time. Keeping it AMC. A Pacer. Well, we will need to 'Pick Up the Pieces'. Must be a Jeep. So, a J10, J20 or 400? What to choose?
Jeep 2, Japan 0. How's that for a World Cup.
I did have an issue with an SKF unit bearing. I thought it was the Shaefler unit. The tire puckered a bit. Both were purchased from NAPA.
Um, Star Wars New Hope. Blade Runner. Jaws. RUSH. Alien. Deer Hunter. Indiana Jones. The A Team.
For some reason, Ford Explores have their following. Also, Ford rangers and Chevy S-10s.
I have not done it myself. I have had the manifolds, and put them on a '95 head. I doubt they last long, a start leaking very soon.
The two piece cast manifolds are for the smaller exhaust ports of the 0331 heads. There is about 1/16 'wall' if used on earlier heads. Not much sealing area. I think Pace Setter and possibly Clifford has headers for the RENIX. I did use a RENIX, and have a Cliford (bolted on, but not used).
Haven't done it myself. I would coat the portion going into the ground with a tar sealant. I do have plenty of examples in WV of post just put into the ground. Also, you might coat the top of the post. Or put some type of cap on it. My mailbox post rotted away. Neighbor Daughter-in-Law hit it while moving. She was really upset about it. Replaced it with an aluminum post the neighbor had. Took some convincing to the DiL that it wasn't her fault.
What I did, is initially upgraded to a '91-95 HO VC. It allowed a larger hose. You also need to the 97+ fitting to the intake manifold. The 93-95 GC (Grand Cherokee) has the CCV fitting of the latter 97-up steel VCs. I did do the Cruiser 'upgrade' to them. The 91--95 HO VCs and the 93-95 GC VC have the aluminum inner towers. Another possibly 'solution' is to put on a 'breather' to the front hole of the VC. Thus the air filter box won't be sucking air and oil into the filter. Some use a hose to space the breather a bit from the VC. Also, you can use RTV in place of the VC gasket.
Heat won't damage anything in the area. Just get the bolt or nut to a dark red, if you can. Also, you can try and grind off the nut. Then spray with a rust buster.
I run two on my Chevy Avalanche. I run a Radiant and another, UMD ???. I do catch some oil. Maybe a teaspoon every 500 miles. I run about 10:1 compression, with 88 octane. If a higher compression, then possibly run a catch can. On the 4.0L, most run the catch can on the rear CCV tube. If oil in the air filter, then its either the rear CCV tube needs upgrade to 97+ or its blocked up with crude. On mine, I used the FlePro rubber gasket. Upgraded to a 93-95 CG valve cover.
'Currently someone found a GM EV1 and is in the process of restoring it with help from GM'. I think they found it in a parking garage in the Carolinas. Technically, GM leased the EV1's. So, GM took them back and probably crushed them. Not sure of the legal aspect of the one acquired. Probably since it was past 7 years, or such, sold as an abandoned vehicle. On the gearing and manual trans. Most of them 1st gear was just a bump gear. Just got you going. Sort of the save the clutch from people who didn't know how to shift a manual trans.
NP231 J Rebuild /overhaul kit ?
75sv1 replied to BlackComanche89's topic in MJ Tech: Modification and Repairs
I think NOVAK has a complete kit. I think I bought some lower price kit. Then ended up having to buy other parts. The total price was not much difference. And that's not including shipping. I'd try and get a kit with KOYO or Nachi bearing. National, SKF and Timken would be a plus. -
??? + Lindsey Buckingham. I'm listening to Elton John, Best of #2.
Yeah, such a good song. To have Stevie Nick and ??? as back up at that time is amazing.
Jeep 4.0 Automatic not changing gears.
75sv1 replied to Gradinen's topic in MJ Tech: Modification and Repairs
Try unplugging the TCU. Then shift manually. It will not have kick down. You will need to slow down to down shift. I've always unplugged the TCU and left the fuses intact. If it doesn't work, then I'd say something mechanically wrong with the trans. Check the fluid with the engine not running. It should be up on the 'Z' bends. The start the engine. The fluid level should drop. See if it is down in the 'fill' range. If this doesn't happen, then probably the pump in the trans is not working. -
There should be a fuse for the transmission. You can pull that. Then see if it shifts manually. If it does, then its electronics. Then you should check the ohms of the solenoids. There would be three of them. 13 ohms +/-3. There should be a plug up by the trans dipstick, to access the wires. The other is the speed sensor. Yours should have one. I haven't worked on the earlier autos. Should be a hall effect sensor. On or Off. You need an analog Volt meter with ohms. The connectors are also on the same wiring connection up by the trans dipstick. You need to turn the shaft of the transmission. -
Part of College isn't what you learn, but to learn how to learn. Congrats. We had a Business degree doing engineering work. She moved on to Wall Street.
There's a Pinto Station wagon in a town near by. Yet, point taken. You don't see many 80s, 90s, 2000s vehicles around. Yet, XJs, TJs and old Pickups are still around. Used to be a few MB Diesels that ran around. Haven't seen them lately. I do own a '15 Volt. It was cheaper to but my Volt with less miles than a Chevy Cruze. The Volt sold for more.
How does the 'turn over' rate compare to luxury vehicles? The cost of electrics keep them out of 'normal' buyers reach. I do have a Chevy Volt. When I drive it to work and back, its about $20 a month. When using gas, its about $20 a week.
