75sv1
Everything posted by 75sv1
BBK throttle body leaking shaft seals
75sv1 replied to knever3's topic in MJ Tech: Modification and Repairs
I've resealed a few HO TBs. I think there is some instructions from someone else , yeah somewhere. There are two O-rings on both sides. Sometimes the shaft is fretted though. I would take out the o-rings, clean out the bearings and regrease them. Then put in new orings. The originals look to be Teflon. I forget what I used. It was not your regular black Buna-N. I think a fluorocarbon. -
Saw one outside Harrison, IN. Had a towing companies logo on it.
Depends on if the thermostat is fail open or fail close. Also, depends on ambient air temp. So, fail open and winter, at say 32 F, I'd run about 135 F.
Um, No. That what dowel plus and epoxy are for.
If you are good in metal, then you'd probably do good in wood.
I had a Motorad fail open on me within a year. I have some Carrols NOS I bought off of ebay. A bit of a tight fit. Also, Flowcooler has revived the Robert Shaw line.
To Electric Fan or Not To Electric Fan
75sv1 replied to TeKdo's topic in MJ Tech: Modification and Repairs
I have triple fans in my XJ. I used the aluminum 'housing' from dirt bound. I used SPAL fans and a K_Suspension controller. I do have some controllers from Nick-n-Time. My radiator doesn't have the bung to use the ones I ordered from him. I think I'd like his setup better though. Also, K-Suspension has the 'housing' too. I think. I think I dropped about 5 degrees of temp running above 40 mph. Actually, with out any fans in there, I run a bit less. I normally run about 205-210F. I haven't run much in City traffic or 'Wheeling' with this setup. So, I'd be hesitant if that is your build. I did try and use a Left and Right hand electrical fans stock XJs. The newer ones put out 1200 to 1400 CFM with the curved blades. I just couldn't come up with one from a RH drive. Also, maybe run a front mounted pusher fan. ??? -
My experience is that the harness will give about twice the light. Also, the H4 housings will give about twice the light (with out the harness). With an Autopal, Hella, Bosch and CIBIE, and harness, I'd say 4X. Daniel Stern use to sell the CIBIEs. He now sells a Japanese made ones. He rates them better.
I think the MJ and Scrambler running is worth mor than the XJ. XJs are 'easily' found for sale. My only slant to keep it, would be if it is rust free. Also, it would depend on what you think you'd get for it.
Rookie Water Pump Replacement
75sv1 replied to AnotherOldJeepGuy's topic in MJ Tech: Modification and Repairs
The Fan "Pulley' also has a bearing in it. Its hard to find. I have ordered some from Gopher Supply in New Mexico. I forget the PN. -
Also, NAPA has the tube listed: Engine Water Pump Inlet Tube NOE 8257002 | Buy Online - NAPA Auto Parts I used 2000 XJ for the vehicle. -
For both tightening and loosening of the nuts. I also like a screwdriver with a square or hex shaft. Gives a flat to go against the nut(s). -
The nuts for the water pump pulley and the mechanical fan, I use a large flat bladed screw driver between two of the nuts. It keep the pulley(s) from rotating. I use a box end wrench. -
I'd look at the hub bearings or since yours is an '88 the front wheel bearings.
I am thinking of cutting out the baffle from a 96+ VC and adapt it to a 93-95 ZJ. Just thinking, haven't looked at both side by side.
All engine have a bit of blow-by. It is 'excessive' blow-by that might cause issues. My though on why oil gets into the air filter box, is leaks in the system. Or the CCV tube is blocked or restricted to much. So, the engine is drawing air into the airbox, instead of drawing air from the airbox. I'd check Dino's 4.0 page on how he set up his catch can.
I'd put a catch can to the rear tube. I'd also 'upgrade' to a latter XJ "big Tube' CCV. If oil is puking into the air filter, there is a leak in your system. You could put one of the 'Hot Rod' type Valve Cover filter.
The 93-95 ZJ VC is aluminum. It has the oil towers like the RNEX and HO. It has the CCV grommets like the later steel covers.
I did measure both intake and exhaust manifold flanges. About .485.
Thermostat opening temp opinions
75sv1 replied to hgeranium's topic in MJ Tech: Modification and Repairs
I run a 195-197 F thermostats. I have been running 205 to 210. MPG is discussion on its own. Some say a 205F Thermostat gets better MPG. Also, a lot of this depends on ambient air temp. I have had a few thermostats stuck open or even come apart. -
I have seen them on another XJ in the PnP in New Ringgold. I think last year. Also, Banks claims there's is the only exhaust manifold with the same thickness as the Intake manifold. I just gave away or 'back' the two stock XJ manifolds I have. I might see if there is any difference between the Thorely and the Banks I have. I might be able to measure a stock one.
Yes, much different than the ones I had on my '98's and 2000 XJs.
