75sv1
Everything posted by 75sv1
I don't think the '95 head is that much of an improvement over a 96+. The '96 plus will have holes for the dowel pin in the 96+ block. I'm the only one I know who has had issues with a '95 head interfering with those dowel pins. You did mention that you were going to port and polish the heads. I am not sure if you plan to go with larger valves? Upgrade the camshaft? Also, a 'bored' Throttle Body does help some.
Re-Seal my sealed beam light
75sv1 replied to AnotherOldJeepGuy's topic in MJ Tech: Modification and Repairs
I'd get some H4 Autopals as a replacement. Not sure on the cost presently. In my guestimation, the wiring harness doubles the light output. H4 headlights double that. If you want higher quality H4 headlights, Hella, Bosch and Daneil Sterns carries some from Japan. -
Should I replace these suspension parts?
I have used the Mevotech Blue bushings. I like them. They seem stiff like a polyurethane one. I have used the NAPA links. They are good. The last ones, I replaced the bushings with red polyurethane ones. I had both laying around. I was having issues with the front end lifting. Very weird. I was using ZJ links. I didn't have the top bushings in there. So, some sort of binding. I wasn't the only one to notice it. -
There is one pictured in Hagerty's Magazine this month. Its owner is in TX. Also, they did an article on the XJ. How it changed the auto world.
I see some pristine ones around here. Yeah, prices can be high for those. They and mine have issues with the AFM lifters and the transmissions. The 6L80E is not cheap to rebuild.
Harmonic balancer, timing chain. Oil pump. Stock valve spring up to '95 should be good for .450 lift. I'd have new cam bearings installed. Check the wear for the distributor. New cap, rotor and wires. Brass cap and rotor.
I have dome Ford 4 holes, and 12 holes. The engine seemed to run smoother with the Ford 4 holes. I did not notice and MPG or power increase. With the 12 holes, I originally noticed a power increase. Then with in a week it was back to stock power. ???? I do think the ECU corrects back to its 'normal' as best it can. Also, injectors are rated to a fuel flow rate and pressure. So, without tuning the ECU to the change, it is questionable as to any improvements or not. There are some who have upped there Fuel regulator PSI, and had good results.
Oh, Chevy Avalanche. I like mine.
I guess most of you haven't had to deal with 'Rolling Coal'?
Might check the speed sensor. Should be one. The latter 98+ have two. I had a failure like yours. I replaced the shift solenoid. Did a Transgo shift kit. Nada. Neighbor did a scan test. Couldn't check the speed sensor, but everything else checked good. Replace the rear one. Trans worked.
An explorer was captured by a tribe of cannibals. They ate eat him. Everything except this thing. Why? They heard "Things go better with Coke."
ked up an 80 AMP Castle Creations Thunderbird controller and an ATXi 2820-8 motor for $20 this past weekend. I'll have to see if the motor is big enough for a Great Planes Stuka I bought. The Speed Controller will be an upgrade from the off shore one. I put a Thunderbird in a Flyzone FW-190. Really helped.
Pellas were rated very high some years back. Still, might be.
Its been a while since I installed windows in my house. I used Kolbe and Kolbe and some Marvin windows. I did 2 pane windows back then. I'd go 3 pane, especially where you are at. The place I delt with was a distributor. So a bit better pricing. I shimmed then level, then nailed them in place. Mine was new construction. I remember they had exterior flanges, that have nail slots. Also, tape seamed those flanges. Then I uses the spray foam. I used the 'hard stuff in the corners. Then the soft stuff on the top and side, from the inside. I am doing vinyl windows on my Mobile home in WV. Still, not cheap.
I don't think that's piston slap. (shiny oil)
75sv1 replied to brucecooner's topic in MJ Tech: Modification and Repairs
Also, there is an installation tool, to install the harmonic balancer. The stock bolt is a bit short. It is not advised to smack or hammer on the harmonic balancer. Cast Iron can be brittle. A bit loner bolt from the hardware store might do. Also, if you pull the head off, then check for cylinder wear. Look at the top of the cylinder. See if there is a ridge or not. -
On the harmonic balancer. There was some squealing with the accessory belt. I did not catch the harmonic balancer for some time. You can put a white line mark crossing the hub and outer ring. If the out line of that moves, then its bad. Mine was past bad. I'd look at the elastomer. If any cracks in it, replace it. They are $40 to $50. I do replace the timing chains on mine. If you get the cover off, the chain should not deflect more than 1 inch. That is from pushed in and pushed out. Get a set and not just the chain. The 'silent' or stock chain might be stronger than the roller chains. At least according to an article I read. The issue is at 5K RPM. A silent chain starts to stick. I do have a 2000 XJ with about 280K. I don't know if the head has been changed. It was OK. I have been around two of them, that the head cracked at 80K. They were well maintained. Seems the #6 cylinder has more issues with cracked pistons. I'd pull the valve cover and check the rocker arms. If OK, then the oil pan. A bit of a pain if not lift. Then the head. Or just pull the whole engine and inspect. See if it needs work and what work. I mentioned Car-Parts Inc in my previous post. Still, Junkyard motors can be iffy. I got burned on mine. Head was warped and someone put a boatload of Barrs Seal in it. -
Mine was that the harmonic balancer went bad. I suggest on replacing it. The copper flakes is probably one of the bearings going bad. I'd think the main thrust bearing. That's what went bad on mine, when the harmonic balancer went bad. I snagged another crankshaft from a neighbor, and the bearings. The bearings looked new. The original crankshaft had damage to the thrust bearing surface. I have a few machine shops left in my area that do engines. I'd have the cam bearing replaced if you take the engine out. Another option is Car-Pats Inc. You can search for parts in your region or across the US, Mexcio and Canada. -
Also, check the wobble on the distributor shaft. You should not feel 'any'. I think the specs are .001.
Does it have an O2 sensor? Also, I'd check the cap and rotor. Get a brass terminal one if you can.
Wrangler???
My need for one, is that I jump started a Dodge Neon probably 20 years ago. Yeah, before they came out. It blew my brake light switch in my 96 Ford Contour. Then I had electrical issues after that. Maybe the squirrel that popped out from under the hood, has a doings in that. I'd have to check, which one I have. It has bailed me out a few times. And others.
What Is Torque? Torque Explained For Cars
'the 2.1-liter turbodiesel-equipped models from 1984–1987 has them beat, if only in terms of valuation spike. The indirect-injection four-cylinder used an aluminum block and head and produced a paltry 85 hp and 132 lb-ft of torque. That’s the same torque output as the base 2.5-liter four-cylinder and almost 20 percent less power. Um, torque is power. HP is the 'power' in a time frame.
BBK throttle body leaking shaft seals
75sv1 replied to knever3's topic in MJ Tech: Modification and Repairs
I think I used Nitrile orings. Nitrile Butadiene has a higher temp rating.
