75sv1
Everything posted by 75sv1
Its been a while. I haven't done any work on the truck. I did put the Cherokee back on the road. I just wasn't selling any parts off of it, except nickle and dime stuff. So around Novermber, I bought some parts, windshield, hood, fender etc. There were other problems, but it is on the road and driving OK. So, I'll need to get the interior and doors from another Cherokee. It kind of helps out, though as I need a vehicle to get parts with. My Contour and MB240d get cramped for parts. One of the parts holding me up is a Ford 8.8. I did go to the PnPs in Indy this past weekend. It was raining on and off. I was looking for tires for the Cherokee P225-75-R15s. I didn't see any I liked. I did pick up an antena and a CD player for the Cherokee, $27. It had a tape player before. I wnet to the next one. I hadn't been there before. It did list a FS Grand Cherokee a few months back. It was still there and had the front axel. Someone had taken the springs, so that was a big help. I wondered the yard and there were three Comanches. I pulled the taillights from them. One had buckets (red), I pulled them. They are a bit worn though. I pulled some grey interior parts, the B-pillars and bottom piece, with seatbelts. $114. I went back to pull the GC's front axel. They were one vehicle away from taking it to the crusher. It didn't take to long to pull it. One of the yarg guys put it in back on the yard truck and took it to the front. I paid for it, and we loaded it into the Cherokee. $214. It was heavy, or I was fairly weak from rain and pulling stuff. Overall a good day. I might go back next weekend. I still need to get a Ford 8.8. I did order 4:1 gear set for the Dana 300. There is a sale on the first 50 sets ordered. It won't get here till May. Still, it was $150 off. I have some other work to get done. I still have to get the NSS off the Cherokee. Its on there. I did get a new one off of E-Bay, $50 shipped. The Contour is down. I think it blew a fuel pump. I have the parts. Its just been cold and rainy here. Tom
The brackets off your bench seat should work. I do have a set of brackets, without the rails, that might be available. I'll know next week. I got a set of bucket seats at the P-N-P this weekend. There were three Comanches at one of the Indy PnP. I grabed all the taillights. Tom
columbus IN
75sv1 replied to baldntatted's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I can inspect this for anyone interested in it, that has a bit of a drive. I also have some spare tailights. I'll throw in a set, that is useable, but damaged. I have other sets that are good, but haven't determined a price yet. Tom -
Might try: http://car-part.com/
h/o 4.0 block with renix intake will it look?
75sv1 replied to asm4mcc's topic in MJ Tech: Modification and Repairs
I have seen some write ups on this. I think you will need to have the bottom of the intake welded up or weld material added. Then the face of it machined. Then do a port match. If you put the exhaust gasket from the HO onto the Renix intake, then I think you will get a good idea of where material should be added, and what you will need to grind out. Tom -
Self etching or Sandable Primer?
75sv1 replied to drase's topic in MJ Tech: Modification and Repairs
Why not do the first coat with the self etching, then a coat or two with the sandable primer? Tom -
The auto wiring will work. There is a writeup on Jeep.com, I think on this. It a lot more work in my opinion though. Tom
There are a few problems to deal with when swapping in an HO, in place of the Renix. First is the TB, the next is the fuel lines (fuel rail or fuel log). The bolt pattern is different from the Renix to the HO. I don't of anyone making an adapter plate presently. The other solution is to use the HO TB and adapt the electronics of the Renix to it. I think HESCO sells a kit for that. I think its $100.00 though. I looked into d oing that at one time. The mod didn't look difficult. You might to a web search. The bolt tabs for the Renix and HO fuel rails are different. So are the locations of the fuel lines. The HOs are both at the front. The Renix has one at the front and one at the rear. My plan was to use an HO fuel rail and use fuel line to connect the metal lines from a '95 to the metal fuel lines at the frame rail in the MJ. Not as hard as it sounds. Of course you have to swap on your electronics such as distributor. Basically, you can swap on any year head, onto any year block. The latter blocks from '96 up have locator dowel holes. That would affect you with the '92 block. So, you could swap on your Renix head. I swapped on a '95 head onto an '03 block. The engine mounting bracket holes should be the same up to at least '00. I had problems with my '03, but adapted it. A spacer and cut and welded an ear off one sides bracket. If you are close to IN, I have a '95 block that could be salvaged, for free. As far as the pilot bearing bushing, I would check with Advanced Adapters. Tom
I should have one for an '88. Tom
I've kind of stalled out on this. I worked on my Ford Contour SVT for about 2 weeks. I hit a racoon a few years back. It took out the AC condensor and bent the radiator. I changed all the hoses, water pump and some other stuff. I finally, have AC in it. Then I have to work on my MB 240D. It wasn't starting, took a long time cranking to get it started. I adjusted the valves, then replaced some of the glow plugs. I think ti was the glow plugs. Then I finished up some of the stereo install. Still, a little bit of work there. I did get to a pick-n-pull this weekend in Indy. There are two of them there. I couldn't find the one. I made it to the one on 16th St. I was looking for 2dr seats. There was on XJ with 2dr seats. One the steel bracket was broken, the other missing the plastic bezel. I did walk the yard. There is a red MJ 4cyl there. I nabbed the one taillight sitting in the bed. It had a dark gray interior. It was 2wd. The bed had some rust, but could have been salvageable. Also had the rear bumper. I little bent, and I don't remeber the plastic ends being there. I did get a few XY parts. I got the overhead consul for an 98 XJ. I plan to fit it into the Comanche. I'll have to do some cutting on it. I didn't see the wiring piece for it though, nor did I get the sensors in the engine bay. I also got the steering wheel from it. It has the Cruise control buttons. The actuator was crushed, and I didn't get the wiring piece from the steering wheel into the dash. I did look at some Ford 8.8s. It was hot, so I skipped seriously looking at them, nor getting one out. I'll wait a few weeks, and go earlier in the day. I saw one on my neighbors there. He has a tan Comanche. He talked about buying the 4.0L out of the XJ. Never know. Tom
I do have a TB listed in the ForSales: viewtopic.php?f=24&t=23974 Tom
Back about 2000, I transfered from the machine shop to drafting. I was driving an '85 Ford Tempo. It was my DD and a beater. I had a '96 Ford Contour as my good car. The Tempo had some trans problem for the second time. The body was rusty, and I didn't want to put the money into it. I think I was looking for an early Ford Bronco, a Scrambler etc. Those were fetching a bit of money back then. I did test drive a '74 Bronco, but I thought the work needed to it was a bit much. I was driving through a small town near me and spotted the Comanche. I took it for a test drive, and was surprised at the power it had. It did need some work. I paid $1400 and then had about $400 to $600 in suspension seal and general maintenace. I put a header on it, as I broke the factory header, trying to replace the exhaust gasket. It drove fine for a couple of years. I used it during the construction of an addition onto my house. Even then I was planning on some upgrades and adding 4X4. The Master clutch let go, and I replaced it. A few weeks latter the slave clutch went. I already had planned a NV 3550 swap. It was a bit tougher than planned. Then a '95 wiring swap, with the '03 block and '95 head. Now its a '98 wiring swap, with '98 doors, fenders, interior etc. Dana 300 TC, 4.5 lift and some other stuff. Need to get back onto that build. I have a '00 Ford Contour SVT and my good car. A MB 240D as my DD. I am hoping to get the Comanche back on the road for winter time. Tom
Might be careful of the Toyota. I have heard they are having rust problems on their frames. Tom
Another option to the OP, is to port match or see about the feasability of a port match of the Renix intake to the HO head. Some people have port matched the 99+ intake manifolds to Renix heads. They only end up with 1/16 or so of wall thickness on the lower wall. I think that is a bit thin. I'd try and keep 3/16th to a 1/4 wall thickness. Also, there are expxies that are used by motor builders to reshape intake ports. Might see about using them instead of welding. Tom
Fair enough. Now I will lean towards a full replacement for the OP. Since He is in PA, I remeber state inspections. I did live there a few years. I don't remeber them letting you off of anything or much. It really depends on the EGR. If the inspection is a sight inspection or a tailpipe emmissions inspection. Basiaclly, is the ERG ain't there no pass. That would complicate swapping in an HO motor. You would somehow adapt the Renix manifold or cut and weld the ERG port of the Renix manifold onto the HO's manifold. I did breifly look into this. Also, removal of the EGR is against EPA Federal regulations. I seriously doubt you'd get caught, though. Except if your state has inspections. Chear up PA has way more trout streams than IN. Swapping in a newer motor is OK with the EPA. I'd check it out with an inspection station first though. Now, during my build or swap, I did go into the direction of '95 wiring etc. I got the parts, but stalled out on that. I was also thinking about an interior update etc. I kind of lucked into a wrecked '98 Cherokee, for $500. I figured at that point, it would be easier to swap in that wiring, mainly for the instrument panel wiring. I also figured I'd be money ahead, since buying parts individually can get a lot more expensive. Also, I will be selling the engine and trans and other parts. Even if you go to a Pick-n-Pull. Still, it depends on the avialability of a donor and its condition of parts you'd need. Tom
First, OP Look here: http://www.rockmodified.com/Tech/TB/tb_perf.htm I didn't see a listing on HESCO's website for the wiring conversion. I remember it being $125. "it also requires more thinking, and more keeping track of parts. you get more power with a H.O. electrical setup." You sure its the electrical stuff that makes more power? I think the torque is like 2 ft-lbs more and 12 hp more. Maybe its the heads and larger bore of the TB? You you mean I can't put on headers, flow the head, bore the TB etc on a Renix and get more power than a Stock HO? How about a stroker Renix? Think it would make more HP than a stock HO? I also don't see it as more work or more complex than swapping out all the wiring, removing the dash etc. A few more notes on the complete thread. I do see a listing for a chasiss control box for auto trans. This is also listed as a trans computer. There are also writeups on how to convert auto wiring to manual wiring. I don't know if I'll go that route or not. I did get a partial manaul engine wiring harness for a '98. I did read that the auto EMC will run a manaul engine, but you will get an engine code. I did buy an EMC for a manual engine. Tom
http://www.naxja.org/forum/showthread.p ... wap&page=2 See post #18. I just skimmed the thread. That is basically how I was going to do mine. I should have a '95 fuel lines and possibly the fuel rail if the OP goes this route. My opinion is it would be a lot less work than swapping all the wiring, dash etc. Many have done it and had good results. Tom
that only gives you a renix-controlled high output. it is ALOT more dicking around for one, and it's an inferior operating system as well. The OP wanted to know what or how to swap in an HO motor in place of a Renix. Everyone else was saying to do a full swap of wiring. That to me is a lot of work. I know, I am in that process. I did look into doing the wiring etc. for this swap. So, I'd say a lot less dickering around. The Renix might be inferior to an extent, but still gets the job done. There are some pluses to the Renix. Some of the Stroker guys like the anti-knock sensor the Renix has, and the HO doesn't. Also, the stock Renix gets a bit better mpg. I think mainly due to the EGR. Tom
Might look at Car-Part.com. I did a search for the Philly region. They go for $25-$35. Its not worth my time at the moment to pull the one I have on an engine. Tom
I think if you look around the net you will find that you can swap just the HO motor into your bay. You will have to delete the EGR valve. SO, if you have emmisions visual inspection in your state, then its probably a no-go. The other problem is the Throttle body. The Renix won't bolt onto the HO intake. The HO won't directly plug into the Renix wiring. There are two solutions. The first an adapter plate. The other is to modify the wiring. I don't think anyone makes an adapter plate, presently. Someone use to. If you have acces to a mill, I think you could make one yourself. I have seen writeups and some firm sold a wiring kit for HO motor to Renix. Might look at Rusty's Off Road. Might do a search on JeepForum.com. Tom
I use a Mach3 blade. I do have fairly sensitive skin. I don't have a thick beard. my chin hair is fairly wirery though. I have used a few electric razors. They were cheaper ones. One was a Braun, but a lower end model. As others have said, they don't get as close of a shave. I have heard a few good coments about the Panasonic wet/dry. I haven't used it though. I now shave in the shower. This seems to help quite a bit, to get a good shave. I also use a natural shaving cream. I use 'Kiss My Face' brand. It comes in a pump bottle. I wash my face in the shower, then lather and then shave. Tom
if my truck was made in 85, does that make it and 85 manche?
75sv1 replied to MancheKid86's topic in The Pub
'It's gonna be extremely difficult to sell a car in January if you don't start working on it in December. Many vehicles, especially new models, are introduced as the next year model. I had a 1964 1/2 Mustang, and a 1968 240Z if you go by the date of manufacture' From what I've read, the Mustang was introduced in Mid year. So, 64-1/2 is correct on a Mustang. I did have a '96 Contour made in late '95. I remeber the TB gasket didn't match what the auto parts stores sold. I had to go to the dealer. I think Ford released the car in '94 in Europe. Then '95 in the US. Those had some differences in wiring and emmisions items. Tom -
As for transfer case, there are differences in the spline count. 21 and 23, I think. I think yours is 21. I remeber that 87-88 used the 21 count. I think some of the later 4 cyl. used a 21 count spline. I can't remeber how the fuel line came off. Sorry. Now as for oil going into the filter. Search for the topic 'Blow-By'. Its not really blow-by but its what Jeep 4.0Lers refer to this condition by. I have gone through this myself. I was useing about 1-1.5 qt per week. It was probably 250 miles per week. I did the usual of new CCV lines etc. It helped for a while. My solution was to up grade to a 'nwer' valve cover. I used a 91-95 valve cover. The 90 degree elbows are suppose to handle the oil better. The later pressed steel ones are suppose to be better than that. I have recently bought a late '95 valve cover. It has the 'grommet' style CCV fitting like the latter pressed steel ones. I also did a big hose late style CCV hose mode like seen on MADXJ site. I had to cut and splice the hose to fit the Renix intake. Its a bit longer. I think most of the problem is caused by the valve cover gasket not sealing well. I tried a few cork gaskets. The worked for a while then lost their compression. I would probably try a FelPro rubber/cork gasket. I would put some gasket seal on the gasket to valve cover surfaces, to bond it to the valve cover. I also was on a thread on Jeep.com board. One poster said there was an 'unofficial' factory mod. You cut the oil towers inside the valve cover 2 inches shorter. Then drill a 1/2 hole on each of the two towers, another 2 inches up and on the rear side (or rear side of engine). I think Pete posted a link to a CC post on the same subject in the Jeep.com post. Tom
You might let us know what year Comacnhe you have. I'd look at GreatLakes XJ for a FSM for your year in a Cherokee. Or buy a FSM for yours. Two things, check that power is getting to the coil. Then check the coil itself. They do go bad. Tom
Well, I was on vacation last week. Just before that, I got the Cherokee running. I put in a MSD ignition coil. I went to PA and DC. DC for a cousins wedding. Then to PA. I finally caught a trout on the LeTort. It was onyl 6 incher, but a trout. I also went to Harry Pull-a-Part in Hazelton PA. I hadn't been there in about 8 years. I was searching for Comanche Bucket seats. There were two Comacnhes there. I pull a set of tail lights and the rear interior panel. Someone had beaten me to the bucket seats on the one. I did get a late '95 valve cover. There were two others and another with the clunker orange paint on it. These have the late styel CCV groments. They also have the older style tower shields. I'll try and post some pictures later of the different styles of valve covers. I have a 91-early 95 and a later stamped steel one. Tom
