asm4mcc
    locust gap pa, 17840
  • Interests
    wheeling
asm4mcc's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. this worked thanks for the info
  2. i just replaced my 4.0 motor with just a 4.0 and i think i messed up the injector wiring any help would be great?
  3. i want to swap my renix for a h/o motor can any one tell me what i all need i got the engine and wiring
  4. has been a long time but i got the comanche done and since i rolled it and just blow it up in a big mudd hole sumthin blow a hole in the oil pan but i still made it through the hole but now I'm looking for a stock motor the 4.88s work great with the 36x12.5 15x10 rims and also added a snorkel
  5. h/o 4.0 block with renix intake will it look? has any done it? what is invovled?
  6. hi i have a chevy 350 and have a 89 comanche with ax15 and if i put that 350 in what do i do about the motor mounts and what do i do about a tranny
  7. it was lose bell houseing bolts
  8. well i just put my tranny in and drove it around for like 3 days and then it started making a noise when i push the clutch in all the clutch parts are brand new also this is my first m/t swap thanks 97 ax15
  9. umm i really don't kn o
  10. i jus don't understand how it works the bench only has 2 sliders and the comanche floors brakets are small then the cherokee
  11. ok but i f'ed up i jus cut those pliugs right off so i need to kno what color there are
  12. I'm just goin to the junk yard tomorrow
  13. my clutch line is cut at the slave cyclinder with an inch sticking out how to i go about run a clutch line and what do i use
  14. i swap aw4 to ax 15 yea i need to kno what colos the two wires are
  15. ok i got everything to go just need to bypass the neutural saftey switc h how and what do i do
