Porquer
Everything posted by Porquer
  1. Quick question: did all Comanches come with a carpeted panel behind the seat on the back wall of the cab, or was that an option?
  2. Today I took some parts off of a donor pump power steering pump for my power steering installation. The pump on top is the one I got from @garyweb3. That’s the one that will be installed. The one on the bottom is one that I got from a local guy on marketplace. He said it came off a YJ with the 4.2. I didn’t think the 4.2 had serpentine belts, but 🤷‍♂️ I’ll be using a bracket and pulley from this pump. It’s not exactly the right pulley, but I think it will work. The market place pump also had hoses still attached with the pressure switch! Score! I’ll take the switch to work, put some pressure to it, and see if it functions. The brackets, pulley and hardware will all be cleaned. The pulley and brackets will get black powder coat or paint.
  3. Any plans for the old engine and transmission? Never mind, I see you’re out in CO.
  4. @pizzaman09 Thanks! It’s a great and useful little truck. I’m trying to drive it as much as a I can before road salt appears. You’re in Ohio too, right? I never see other Comanches in my area.
  5. Fall colors are hitting peak
  6. I’ve used it on aircraft to help me track down service bulletins that I know exist, but can’t find. I like using it to locate original sources of info.
  7. Used the Comanche to help set up for a local festival where my wife was selling flowers. At the festival was a JD Model A that was supercharged. Complete with PVC tubing 🤔 must be low boost. Picked up a power steering pump that had a pulley, bracket, and pressure switch for my power steering retrofit. I’m almost done collecting parts! Power steering isn’t far off now!
  8. My advice is to drive a 2.5. Then your 4.0 will feel great!
  9. I see a lot of parts I’d like to have.
  10. I’m looking for a picture of a power steering pump pulley from a 2.5 (serpentine) Anyone have some pics?
  11. Went to Menards and got 850 lbs of retaining wall blocks. The little 2.5 and AX4 did pretty well! My left rear springs sagged noticeably more than the right. I’m sure they’re both worn out. The heavier load also confirmed that my clutch is near the end of its life. Not bad for 232k miles on what might be the original clutch! The blocks will be used to finish a retaining wall around our soon-to-be green house.
  12. Sorry to hijack this, but are the pulleys the same? Will a pulley from the non PS bracket fit on the PS pump?
  13. You have a pulley for a 2.5 PS pump? The one in the picture looks like an idler. I’ll take it if you have it.
  14. I’m looking for one too. I’m retrofitting power steering to my 87 2.5. Is it a simple switch to ground? I’ve considered using a switch from a later non Renix 2.5 and splicing in a new connector. I’m not sure that the operating pressures are the same though.
  15. Porquer
    1J7FT26S1NL148750
    Found while visiting River Falls, WI. Not sure if it’s a 91 or 92.
  16. Where did you send your seatbelts?
  17. Nice! Hope the rest of your training goes well. It’s a lot of work! I’ve never flown a Cheif. Champs are nice to fly and still relatively attainable as far as airplanes go.
  18. Very cool! Why did you do at Belanca? I grew up near the Twin Cities
  19. Very good! It’s a 1945 7AC champ. My dad bought it with some friends back around 2005. It’s the first plane he ever owned, and the first plane I ever flew. He sold it in 2022, and shortly after that it was totaled in a ground loop. He bought it from the insurance company, and now we are doing a much needed full rebuild. If there’s interest, and if I have time, I may start a thread!
  20. I removed the Sportruck decals. I’m liking the plain white work truck look. As far as appearance goes, the only things I would like to do are get larger tires to fill the wheel wells, re-finish the wheels and add some dress-up rings, and re-paint all of the black trim pieces to match the each other. it seems to run well, except at idle. It sounds and smells like it only idles on three cylinders. The weird thing is that it feels smooth and adequately powerful while driving around, like it’s firing on all four cylinders.
  21. @ghetdjc320 I’m gathering parts to convert my 87 2.5 from manual steering to power steering. The wiring is already there, so it’s just a matter of finding the parts. I’m having trouble finding the switch in a wiring diagram, but I found it in a schematic, and it connects to C227. I assume it is a simple on/off pressure switch to ground. I may be able to get one from a different vehicle if the threads and closing pressure are the same. I’m in a bit of a junkyard desert.
  22. My understanding is that it tells the ECU to increase throttle to avoid stalling under high power steering pump loads.
  23. Porquer
    1J7FT26L3KL592717
    Looked at this one a long time ago on market place, but I don’t have any photos. It was out in Washington.
  24. I’m looking for a power steering pressure switch, and it seems that they are no longer sold new. Has anyone used a newer style one, and spliced in a new connector? Or is there a source for these that I’m not finding?
