SatiricalHen Posted May 26, 2020 Share Posted May 26, 2020 Alright, here’s the game. You are going to a junkyard. No specific part you’re after, a junkyard you’ve never been to before. You can only bring one single tool to the junkyard. What do you bring? What is the “most useful” tool in your opinion. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Dzimm Posted May 26, 2020 Share Posted May 26, 2020 Depends.. Jeep related, a 10mm wrench. In reality, probably a crescent wrench. Otherwise, a recipe saw. Reason being is I can cut everything around the part I need and haul it home to use the correct tool. Or is that cheating? Link to comment Share on other sites More sharing options...
500 MJ Posted May 26, 2020 Share Posted May 26, 2020 BFH! Link to comment Share on other sites More sharing options...
SatiricalHen Posted May 26, 2020 Author Share Posted May 26, 2020 Depends.. Jeep related, a 10mm wrench. In reality, probably a crescent wrench. Otherwise, a recipe saw. Reason being is I can cut everything around the part I need and haul it home to use the correct tool. Or is that cheating? I was thinking a pocketable tool or something, but I’ll let it slide. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SatiricalHen Posted May 26, 2020 Author Share Posted May 26, 2020 BFH! You just like breaking stuff, don’t you?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Dzimm Posted May 26, 2020 Share Posted May 26, 2020 3 minutes ago, SatiricalHen said: I was thinking a pocketable tool or something, but I’ll let it slide. Sent from my iPhone using Tapatalk you mean it's not normal to carry a recip in your pocket? Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 26, 2020 Share Posted May 26, 2020 13mm ratchet wrench. Link to comment Share on other sites More sharing options...
mjben Posted May 26, 2020 Share Posted May 26, 2020 Leatherman. Link to comment Share on other sites More sharing options...
Original 87 Posted May 26, 2020 Share Posted May 26, 2020 The one between your ears. Its the best one we all own. Otherwise If you look around its amazing how many tools you can find at the yard. Link to comment Share on other sites More sharing options...
mjeff87 Posted May 26, 2020 Share Posted May 26, 2020 My Irwin combination screwdriver. I have a couple of them...one for the 'yard bag, one for the garage, and one for "inside the house" work (that isn't all greasy, LOL) https://shop.rplumber.com/c/hand-tools/screwdrivers-nut-drivers/screwdrivers/p/9-in-1-multi-tool-screwdriver Link to comment Share on other sites More sharing options...
gogmorgo Posted May 26, 2020 Share Posted May 26, 2020 Knipex pliers. Link to comment Share on other sites More sharing options...
Pete M Posted May 26, 2020 Share Posted May 26, 2020 1 hour ago, mjben said: Leatherman. same Link to comment Share on other sites More sharing options...
89 MJ Posted May 26, 2020 Share Posted May 26, 2020 Either channel lock pliers or a Sawzall Link to comment Share on other sites More sharing options...
jdog Posted May 27, 2020 Share Posted May 27, 2020 https://ezred.com/product/14-mini-master-set/ does this count? Link to comment Share on other sites More sharing options...
JMO413 Posted May 27, 2020 Share Posted May 27, 2020 Vise Grips Link to comment Share on other sites More sharing options...
watchamakalit Posted May 27, 2020 Share Posted May 27, 2020 CASH Link to comment Share on other sites More sharing options...
Torq_Shep Posted May 27, 2020 Share Posted May 27, 2020 Vice grips... Duh. Screw driver would be dumb because every yard I have ever been to I have managed to find a screw driver =P Link to comment Share on other sites More sharing options...
Pete M Posted May 27, 2020 Share Posted May 27, 2020 11 hours ago, watchamakalit said: CASH Link to comment Share on other sites More sharing options...
coheed Posted May 28, 2020 Share Posted May 28, 2020 I think I'd third a Leatherman. Mine has come in handy way more times than I thought it would. Link to comment Share on other sites More sharing options...
Gouda Posted May 28, 2020 Share Posted May 28, 2020 On 5/26/2020 at 3:49 PM, gogmorgo said: Knipex pliers. You beat me to it Link to comment Share on other sites More sharing options...
gogmorgo Posted May 28, 2020 Share Posted May 28, 2020 16 minutes ago, Gouda said: You beat me to it Used to think Channellocks were the cat’s @$$ until I discovered them. There’s still a handful of cases where the Channellocks are ahead, but for turning bolt heads you’ll have a tough time finding a set of pliers better than the Knipex. Link to comment Share on other sites More sharing options...
