eaglescout526
Administrators
    13
  1. Oh you won’t get in trouble with any of the mods. If you post in the wrong spot we will simply move it and let ya know what we’ve done.
  2. VINs don’t really get moved to project threads. I can move a couple of the posts and start a new thread for ya in the projects.
  3. Hell if we had that we could easily be making ROMs for performance and making our own performance ECUs or economy ECUs. We could have some genuine fun with Renix if we understood the ROM.
  4. It’s actually not that complicated. It sounds complicated and foreign at first but it’s pretty straight forward.
  5. Those Chrysler ones are just as rare as the AMC scan tool.
  6. Yeah! Just look up GM or Bendix buckle rebuild.
  7. Small little fix. Finally got the reverse lights working. The original NSS I presume stopped working the time I owned it. Replaced it and that one remained on in all gear selections. Finally got around to replacing it again and I now have functioning reverse lights!
  8. Holy crap!! Where has a year come and gone on this car?! And it’s also its birth month as it comes to a close.
  9. Well the 2.8 is a 60* pattern and it’s shared with the 2.5L. So any GM 2.8 or 3.4 should have a transmission you’re looking for.
  10. Damn that’s a clean ISA
  11. Does the ISA return to start position after shut down?
  12. No problem! That adjustment procedure is straight from an AMC|Jeep manual.
  13. Those bolts look like they’re out. Try pushing them through from the other side. But if you say the brakes are seized, then that’s probably why they’re fighting you to come off.
  14. Took the eagle to the orphan show. Absolutely bonkers how many studebakers and Hudson’s were there. 6 AMCs including myself were there. Two jeeps. A thrashed SJ and a CJ and 2 Willy’s trucks. There was three wagonaires too so now I’ve seen 4 of those in my life. Then this gem showed up and I’m pretty sure we all lost first place lol Then I stopped off at the Glendale mural
  15. On the topic, anyone ever seen an 84-86 with such?
  16. I think early MTs were 4/1. Course they could be swapped in at any point since I see there’s a 35 on your MJ. Or even a towing package could’ve had those leafs without having the metric ton payload.
  17. Those look like factory leafs. If I had to say, I think someone removed those retainer bolts to give the springs a new shot at life without being so compressed together.
  18. Like the swap was meant to be.
  19. Well if it helps, heat. AZ destroyed the plastic cover on mine and it’s just flaking off. All of the trip starts out as chrome and just got more or less plastic dipped for the black trim.
  20. Still looks like factory suspension. Metric ton springs out back. Could be just old replacement rancho shocks.
  21. Added some speakers
  22. Hope you called them out for not being first in line to buy it whole.
  23. Fun fact. The pressure from this switch will tell the ECU to cycle off the AC for extra power to power the Ps.
  24. What happens if you back off the tension to factory spec?
