13
Power steering pressure switch
eaglescout526 replied to 70barracuda's topic in MJ Tech: Modification and Repairs
it does two things, increases the amount of fuel the engine takes and disengages the compressor. -
Here we go again! A 1986 Eagle
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Oh that’s quite the gamble. I’m surprised it wasn’t on the SJ sooner. Course I bet the design really didn’t ask for the need or a rear wiper. -
Does the FSJ have a rear wiper? I feel like I have never seen a rear wiper on an SJ. -
The Eagle now has a rear wiper arm from an XJ!! So Carter and I went back and forth on this on what feels like forever. Debating on if an XJ rear arm will work. It does. Not the correct spline count but clean up the splines and throw some lube on it and it will go. Oh hey thats wrong. Its not going to wipe or sit right. So I drilled out the rivet, separated the fold Hammered out the bend and bent it to the other way, reassembled, with a self tapping screw of the small size to fit the holes. Clamped the fold back over. Voila!! It will now wipe the correct way. Hopefully other Eagle owners see this. -
Does teamcherokee still have their NOS supply? -
Intermittent wiper module repaired
eaglescout526 replied to The86manche's topic in MJ Tech: Modification and Repairs
I think it’s the wire in the column somewhere. Cause I checked the wiper motor and the switch and even swapped switches too and still the same results. And I did have to root around with the column and its ignition switch so it’s probably that wire that goes there. I even did a continuity test from that wire to body and it grounds out so I know where it lies. Just need to pull the XJ out and address it. -
Ooo I got one. My 84 XJ one day was working fine for the wiper module, something got wet and now it won’t work right. It just constantly cycles and keeps tripping the circuit breaker. And I’ve tried other modules and some work and some don’t even though they all test fine in my MJ. So I’ve got some digging to do for the wiring but that’s and example. -
https://ebay.io/m/Pn7n4d AMC era TPS.
Added interior door handle stuff.
Got the AC charged up and blowing cold. No more leaks.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
What do you think Jeep was thinking?
eaglescout526 replied to fiatslug87's topic in MJ Tech: Modification and Repairs
Probably more information lights. Since it’s 91 only who actually knows what Chrysler was planning. -
1/2” in diameter for the arm. Looks pretty similar. I’ll take it and shoot you a PM in a bit.
I swear while working at Ford I have seen a jack handle in similar length and likeness to our jack handles.
Oh also those jack rod clips are supposedly in the rear upper section of the XJ holding the harness.
Let’s get her front and center. I’ve been driving her on and off while working with the Eagle and chunk having a dying/dead battery. However! The suction side schrader valve finally decided to fail. So I had to let the 134 leak out, replace the valves and now I’m sitting waiting while it holds vacuum pretty well. So hopefully no more leaks.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Chunk, A 1984 XJ
I miss driving this Jeep. Just replaced the battery cause it was old and failed and finally and I mean FINALLY fixed the exhaust leak at the manifold. The leak was the flange to manifold problem. I tried to make the flange flat against the manifold and it just never seemed to work. I happened to pull the pipe out again for work and looked up and saw the manifold studs tweaked inward. So I moved the studs out and got a flush mount to the pipe and manifold and now I have no more leak. Woot! -
I sent you a PM
That is a good question! I’ll get back with you on that. I think I have two or three idiot light clusters so I’ll compare what I got and see what the best is. As for a price. $15? I dont know. We can discuss that later.
Dana/Perfect Circle cruise control field depot calibrator
eaglescout526 replied to MJPIA's topic in The Pub
Ohhhh so cool. Much easier than jacking the rear wheels of my MJ up and testing each module haha. -
Ooooo some exciting stuff!!
I think I have a couple from some idiot light clusters that should suit just fine.
Which era of lens do you need?
I think I’ve got a set just collecting dust.
Need help finding replacement clips
eaglescout526 replied to jodawill's topic in MJ Tech: Modification and Repairs
Chrysler has a modern part number for that clip. I remember posting it somewhere when someone was also looking for the same clip.
