mjben
    Fort Collins, CO
1984 profile views
mjben's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. View from my balcony in Fort Lauderdale last week.
  2. LOTS of good info on that here...
  3. I put a set of Continental DWS's on the TH when the stock Pirelli Scorpion run-flats were toast. We put them on a lot of Audi's at work and have had good luck all around with them. Might be worth a look.
  4. Correct. Pollard (in the mouth) is (was) actually the name of the dealership.
  5. Best I can do. It was already cropped from a much larger image of a truck I no longer have...
  6. Someone please do this with a Comanche! Ok not really... 🤣🤣🤣
  7. Is it just me, or does it look like it's been "repaired" in the middle? Definitely doesn't look $499.95 nice. (or right)
  8. Got mine this afternoon. Awesome!!! Thanks Pete!
  9. I have reached out to him on FB. Excellent response and customer service as stated. Highly recommend him and his products. Trying changing color now. I forgot it even did that! It must be an RGB LED not an incandescent bulb. I've got it on white now, (was green to match everything else) we'll see what happens! Thanks all for the responses!
  10. I've searched around a bit to no avail. Does anyone know if there is a replaceable bulb in the R.E.M.? Mine has started to intermittently have no backlight to the gauges. I can still (barely) see the readouts, but the actual backlight comes and goes...
  11. mjben
    1JTMP65P3JT074730
    Just realized I have not posted this one here yet! 1988 Jeep Comanche Pioneer - AKA "PB&J" 4.0l / AW4 / NP231 / D30 / D35 (for now - in the process of putting together disc brakes on an MJ D44) / LWB Current Location: Fort Collins, Colorado Status: In the rotation as a daily/bad weather snow beater (We don't use salt around here...) Notes: Has front and fuel tank skids, Honey/Tan interior, cloth/vinyl bench, vinyl pocketed door cards with hockey stick arm rests. 3 pane rear slider window. Leather wrapped 3 spoke wheel on a tilt column. Column shift, cruise, intermittent wipers, dealer installed A/C, AM/FM cassette - Everything works. Original paint from the decals up, re-sprayed at some point from the decals down in the factory "Coffee". Seems like a semi rare color. Including this one, I've only ever seen 3 in person. I believe JeepDriver's was also originally this color. Bought in May 2016 with 83k original miles. Now has a bit over 86K. Added ~5" bastard lift on short arms front, General Spring custom Metric Ton lift spring pack in rear. 31x10.50R15 Yokohama Geolanders on black steel "D" window wheels. 97+ mirrors, T-case skid, Krusty hitch, 21 slot grille, Nick-in-times R.E.M., tinted windows, Meanlemons bored throttle body and battery cables, and a sweet home made poop pipe overflow bottle which takes a regular radiator cap that I rescued from a junkyard MJ. Surely other things I'm forgetting. When I first bought this truck, I had intended on it being a 3-6 month flip. Didn't care for the color or the LWB. It's since really grown on me and it has just ended up being too good to let go of! Current owner: Me
